(2015-11-12, 23:10)iorifly Wrote: [ -> ]@rschiks,
Exactly. Tvtunes, to select a movie.
Another application in television, as would select the groups?
I have in children's tv channels, HD, Newspapers etc ....
I think I can squeeze in the tvtunes option for movies in version 1.9.
The channel groups option I need to look at it.
The movie tunes option has been added. Just like the series you just need to place a theme.mp3 in de folder where your movie is residing.
I couldn't resist. I still wanted to add something nice to the Movies XL and Series XL views.
I hope you like it (of course you can disable it).
I like it! Thanks Richard.
Regards,
Bart
(2015-11-13, 21:25)bsoriano Wrote: [ -> ]I like it! Thanks Richard.
Regards,
Bart
It was something I only wanted to put in the iPhone version :-)
The animation effects have been added to both the Movies XL and Series XL
The release notes for version 1.9:
- iPad Pro support
- Theme settings are now available for non-pro users
- Added blur background option to theme settings
- Background is now blurred by default (change this setting via theme settings if not wanted)
- Search bar added to TV & Radio
- Removed XBMC references (some menu items need to be hide again)
- Option to play all songs from an artist added (enable in general settings)
- UI tweaks
- Bug fixes
Pro version:
- 2 new menu options added: Movies XL & Series XL. Highlights: designed specifically for large libraries and speed, supports CDArt, search bar, retractable info bar, multiple views, multiple animation effects, display on Kodi option (create a screen shot and display it on Kodi so that other people in the room can watch the info on the big screen), display art, data and images remain in memory (if selected)
- Advanced setting Series batch size added
- Clear offline cache option added to the maintenance menu option
- Offline cache is now per Kodi host (old offline cache files need to be removed, use clear offline cache in the maintenance menu)
- Movie tunes support added (place theme.mp3 in folder where movie resides)
What do you think about this?
The background can be blurred:
It was not that much work :-)
Will the "play all songs from this Artist" button also be added in 1.9?
I have a doubt. Efetuei purchasing the pro.
What version do I wait? 1.9 or 2.0?
Would be free = 1.9
pro = 2.0?
(2015-11-14, 21:19)McYoshi Wrote: [ -> ]Will the "play all songs from this Artist" button also be added in 1.9?
I think so. I will add an option that displays a play button over the artist cover.
(2015-11-14, 21:27)iorifly Wrote: [ -> ]I have a doubt. Efetuei purchasing the pro.
Would be free = 1.9
pro = 2.0?
It's an in-app purchase. It's for all versions. It unlocks additional features. You can even use it in the upcoming iPhone version (2.0).
(2015-11-14, 17:08)rschiks Wrote: [ -> ]What do you think about this?
Hi Richard how's you long time no chat.
Like the blur effect as it makes things easier to read. Would it be possible to put movie collections in the movies as I like to keep all my movies in one place. Just tried out the iPad pro nice device but the Wight and the lack of 3D Touch made me decide not to buy this version. Maybe the next version.
