(2016-01-09, 18:34)bsoriano Wrote: [ -> ]Great progress, thank you Richard!
In terms of playlists, would you consider having a view like the regular movies view for video playlists? I often watch movies from my Oscars playlist or my IMDb Top 250 playlist, and would love to be able to browse through the playlist in the same way I browse through movies, with posters and info. Thanks for considering this.
Regards,
Bart
A good idea.....What about the following: when getting the contents of a smart playlist I need to filter on the type movie first (a mixed playlist can also contain other things, like songs) and feed that to the movies view. The smart playlist also contains the library id, so I can get the rest of the info.
A smart playlist (as far as I have seen, but I could be wrong) does not contain art for that specific item.
Sounds good to me! Is this something that could be included in the next version? Thanks!
(2016-01-09, 20:13)bsoriano Wrote: [ -> ]Sounds good to me! Is this something that could be included in the next version? Thanks!
Can't promise
First I want to finish my list for version 2.0.
I like your idea, so that's not the issue....also need to look into how I am exactly going to do it.
No worries! If and when you include it, I will happily use the functionality
As requested I have added the "Date added" sort by option to the (recently added) episodes:
Awesome, thanks Richard! The app is looking better and better. In my mind, it will be the best Kodi iPhone remote!
Regards,
Bart
I always read the rss feed when I start Kodi, so I thought why not add it to the app.
As a Pro user
you can disable the feed (and use the full screen) or modify the feeds.
I have also added the RSS feed to the iPad version. In the Pro version you can change the settings.
