After 9 days of review the new version is approved and should be available in the next few hours.
If you have any issues or suggestions you know where to find me! :-)
Next: version 1.3 :-)
Cogratulations :-)
will check it next weekend when i am back in my kodi environment.
Best Regards
I loved the app but now he is stuck at startup.
The PRO option overlaps the X (cross) so I am unable to do anything.
Also my Kodi is nit in the list anymore so he say error connecting to kodi.
Hope you can fix this for me/us (don't know if i am the only person with this issue.)
(2015-04-28, 10:40)Ventrex Wrote: [ -> ]I loved the app but now he is stuck at startup.
Can you provide a screenshot, so I can see what you mean?
I work on my ipad i hope this works
The error is possible to remove by clicking on OK but then you get 2 overlapping screens.
Ok, hmmmm...guess I know the problem. I don't have a quick fix for you right now. Seems the only solution now is to delete the app an reinstall it again.
Can't figure out why I have missed this one. Sorry for that.
The problem is when you have selected a startup screen it can start later. Going to fix that.
I guess when the connection was succesful you can remove the series screen and then close the Pro version screen.
Ow that is ok hope it is solved in the next release.
You are doing a great job making this app.
For now it worked! Remove and download solved it.
You have a new pro member now :-)
(2015-04-28, 11:41)Ventrex Wrote: [ -> ]Ow that is ok hope it is solved in the next release.
Thx for being a Pro user :-)
I have submitted version 1.2.1 which will fix this issue. When the Pro version info screen is active it won't start the startup screen.
I just purchased the PRO version hoping the in progress option will be added soon
(2015-04-28, 23:27)MrLondon Wrote: [ -> ]I just purchased the PRO version hoping the in progress option will be added soon
What do you think of the following:
That looks great! Thank you, I also eagerly wait for this feature! (200+ tv shows in my collection).
Regards,
Bart
cannot wait for that feature... hopefully not months away.
(2015-04-29, 19:00)MrLondon Wrote: [ -> ]cannot wait for that feature... hopefully not months away.
No, not months....I think within the next 2 weeks.
