Full Version: Kyra for Kodi
(2016-04-25, 23:41)iorifly Wrote: [ -> ]@rschiks,
Could look more affection for part of PVR?
To really test this I need some information about the setup. Which hardware/software is the best suitable for this?
Might be interesting Smile
(2016-04-26, 08:20)rschiks Wrote: [ -> ]To really test this I need some information about the setup. Which hardware/software is the best suitable for this?
Just thought I want to integrate TV into my Raspi-Kodi setup as well these days and was torn between Technotrend S2-4600 and DVBSky S960.
I expect the S960 to arrive today. Many People seem to be happy with it, even tho some had it dying after 1 week of usage?
Looking forward to use tvheadend as backend, or others if recommended?
Greetings
Sascha
This depends on your country.
     I use Argus.tv with a TeVii card dvb-s.
However you can also use the tvheadend.
You need a card for signs of tv + backend (argus.tv or tvheadend).
(2016-04-26, 13:32)iorifly Wrote: [ -> ]This depends on your country.
Thanks for the info. I will look into this.
(2016-04-26, 08:52)Zeitfraktur Wrote: [ -> ]Just thought I want to integrate TV into my Raspi-Kodi setup as well these days and was torn between Technotrend S2-4600 and DVBSky S960.
Greetings
Sascha
The price is the same over here :-)
Will there be a list view for Music (Artists, Songs) ?
Pretty Please?
(2016-05-01, 12:51)wise_rice Wrote: [ -> ]Will there be a list view for Music (Artists, Songs) ?
Pretty Please?
Yes, there will be....it's on my list Big Grin
(2016-05-01, 13:29)rschiks Wrote: [ -> ]Yes, there will be....it's on my list Big Grin
Thank you !
Dear rschiks
Please confirm whether Kodi Control Center is available for Android tv box?
(2016-05-02, 21:04)arzaz Wrote: [ -> ]Dear rschiks
If it runs Kodi you can use this remote to connect to.
Richard,
Question is it possible somehow to directly start a new menu item in kodi?
i created a item for spotify that connects to an add-on ... now i have to navigate there with the keyboard would be awesome if it can be a button in your app Smile
(2016-05-02, 21:09)rschiks Wrote: [ -> ]
Kodi already installed on my android tv box, how to install Kyra?
(2016-05-02, 21:25)Njaynl Wrote: [ -> ]Richard,
What do you mean with created an item? Do you mean a favourite?
(2016-05-02, 22:28)arzaz Wrote: [ -> ]
You can download Kyra for your iOS device here:
https://itunes.apple.com/us/app/kodi-con...?ls=1&mt=8
(2016-05-03, 06:42)rschiks Wrote: [ -> ]
No i created a menu item on the kodi menu bar ... is it possible to direct start that while using kyra? is there something for this in the API?
