Hi Richard,
have you reviewed the possibility to switch off any online lookup and stay on the local DB for search, Artist (and the movies/shows that are in local store) and display only the local plot content ?
Would be great to have such a switch for people that like to use the local infor only.
f.e.
if you touch the artist so see the movies i would like to see the movies that i have in the local db (different title) and the plot from kodi.
right now i have the result of a online lookup and i can not select a movie and play it.
Best Regards
(2015-05-09, 08:16)Linusorg Wrote: [ -> ]Hi Richard,
f.e.
Best Regards
Yes, I have looked into that. I have put it on my to do list. It will be either in the next version or the version after that. But I definitely will add this option.
(2015-05-05, 10:34)McYoshi Wrote: [ -> ]I'd be the best I guess if you skip the step PVR and add the two options TV and Radio to the main menu. When you select said item a grid view with the channel logo's (and the name of the channel below each logo) appear. When you tap a logo, the channel starts playing.
Do you think that is possible to integrate?
@McYoshi: I have added the TV & Radio menu options. A simple grid view, when tapped it will start the channel. Both options will be available in version 1.4.
As requested I have added the possibility to wake up an additional host:
For the Pro version I have added Cinema Experience support (
link).
This can be enabled via the settings.
When enabled the option "Play with Cinema Experience" in the play menu will appear. When selected, the add-on Cinema Experience will be executed.
A new series view request has been added:
A new movies view request has been added:
Hi Team,
i just installed the app and payed for the PRO version and thus far very impressed the things i am missing so far
1. search movies from other views (selecting carrousel does not display the search bar, maybe swipe down?)
2. we have some local playlists in kodi but i can't seem to select them .. i can only create playlist from the app
Thanks for an awesome remote, after xbmc commander, them xbmcee this is totally a refreshing experience
(2015-05-10, 17:32)Njaynl Wrote: [ -> ]Hi Team,
Well, I am not a team, just one person! :-)
First of all: thanks for buying the Pro version! really appreciate it!
1. At the time I created the view I didn't think you want to search in a view like that. And the lack of space made that decision final. Of course technically it's possible. I will look into the option of adding a search bar. Maybe I will put the name of the movie on the background image itself. I have then some additional space.
2. The playlists in the app are the default ones when you select a movie (or song) and add it to the queue. You're talking about smart playlists. As far as I know there is no API call (yet) to retrieve them using the normal get playlists call.
However, it is possible to return the lists using a different method. I know they are just files. I have just created a playlist myself and was able to retrieve it. The downside of this method is adding/remove items. Now I can just play a smart playlist. Nothing more.
looking good mate I just bought your app to, I'm still designing lol
(2015-05-10, 20:08)meridius Wrote: [ -> ]looking good mate I just bought your app to, I'm still designing lol
Great! Thanks!
Looking forward to your "final" design :-)
Me to I Have had many sleepless nights trying to get the perfect design. it isn't easy on such a small screen lol
(2015-05-10, 22:40)meridius Wrote: [ -> ]Me to I Have had many sleepless nights trying to get the perfect design. it isn't easy on such a small screen lol
:-) I have also learned that at one point you should release 1.0. There are always improvements to make....it never stops.
Another request: in the albums option you can now sort by artist.
