(2015-07-04, 08:51)rschiks Wrote: [ -> ]Unfortunately the closing setting is a setting that is put on the app itself, like the icon and name under the icon for example. I can't control it during runtime.
Ok, thanks. The other apps give the option to 'disable sleep' with a warning that disabling can affect battery performance. Not sure what it does now. :-). Unless it stops the app being able to refresh in the background and is now a legacy option due to the settings in iOS for disabling "background refresh" per app. As you can see, I have no idea about the undelying processes etc. :-)
(2015-07-04, 11:55)DrJogalog Wrote: [ -> ] (2015-07-04, 08:51)rschiks Wrote: [ -> ]Unfortunately the closing setting is a setting that is put on the app itself, like the icon and name under the icon for example. I can't control it during runtime.
The disable sleep mode is used for example in fitness apps, so that when the iPhone falls into sleep the accelerometer and sound etc still continue working.
Hi mate.
Did not realise you started using the new theme design. Looks good.
So the square artist pictures are bigger than the box and cuts the sides off ? As this is the only way you could keep it the right size and centred it. ? If so that's a good idea as it keeps the info box the right size.
I can get you the buttons if you need them or are you not ready for them. I also need to give you the box contents layout for the dates and buttons and other items.
Did the location and sizes I have you work out for the placements.
Just been to see terminator genesis so have not looked at it today.
(2015-07-04, 18:02)meridius Wrote: [ -> ]Hi mate.
I have started the other way around. I took the background size from the remote control view. Created the info box with that height and placed the background. With the height from the background image I have created the square for the artist image. The images from fanart.tv have a higher resolution, so I scaled them down.
I have not used your locations and sizes yet. My first priority is to get everything (data from kodi) in the designated screens. This is the most work. Afterwards I can always make adjustments to locations and sizes.
The bottom menu bar is finished, it can now be used for new theme, which was a requirement. I just need to replace the current buttons with the new ones. I have no idea if you want to use other buttons like http, spaces and kodi commands in the theme.
ah right I wanted to keep that size the same so took some advice from Goliath2000 and accommodated for a square image and moved the star rating and year and this will only be for the music view
so the info bar is still the same size what you think ?
It's not final but had a quick play.
(2015-07-04, 20:02)meridius Wrote: [ -> ]ah right I wanted to keep that size the same so took some advice from Goliath2000 and accommodated for a square image and moved the star rating and year and this will only be for the music view
meridius it looks good, but I'm afraid that if the stars are under the artist picture, it could make some confusion, because its not the artist itself that is rated with 4 star, its the album.
The way you had it for the year was very beautiful. Please don't change that. I like it a lot when it was vertically. Maybe the stars could be moved above the 47 min and for the artist pic don't have anything at all under it?
I want an android version!
(2015-07-04, 21:04)nancychili Wrote: [ -> ]I want an android version!
Sorry, for now it will be iPad only.
(2015-07-04, 20:48)Goliath2000 Wrote: [ -> ] (2015-07-04, 20:02)meridius Wrote: [ -> ]ah right I wanted to keep that size the same so took some advice from Goliath2000 and accommodated for a square image and moved the star rating and year and this will only be for the music view
@meridius it looks good, but I'm afraid that if the stars are under the artist picture, it could make some confusion, because its not the artist itself that is rated with 4 star, its the album.
ok no problem I have changed it but wanted to know what info can be read from xbmc/kodi for music to maybe fill the top left box above the square image with some more info
heres the look I am nearly liking
meridius
Album details:
"title",
"description",
"artist",
"genre",
"theme",
"mood",
"style",
"type",
"albumlabel",
"rating",
"year",
"musicbrainzalbumid",
"musicbrainzalbumartistid",
"fanart",
"thumbnail",
"playcount",
"genreid",
"artistid",
"displayartist"
"mood",
"style",
Is actually something very useful, I think the idea comes from either spotify or apple music where you can sort music by having for example "dinner music" or "party" etc.
its not the same as for genre.
What is
Type is that a indication of what file type the album is eg flac or MP3
Playcount is that how many times you played the album.
What is style.
Cheers Richard
(2015-07-04, 21:28)meridius Wrote: [ -> ]What is
What is style.
Cheers Richard
Just checked the details for
Within Temptation - Mother Earth:
- Genre -> World
- Moods -> Dreamy
- Styles -> Metal
Madonna - Ray of Light:
- Genre -> Dance
- Moods -> Happy
- Styles ->Rock/Pop
Seems overkill I think the ones we have are sufficient
What about type and Playcount
Is type the format of the album and if it is foes this mean we would need a icon for every file type and is Playcount for albums or songs.
