rschiks I like that you give the user so many options!
(2015-07-18, 10:57)rschiks Wrote: [ -> ]This is someone making very happy
You can change the on color for a host to either green or blue:
lol, cheers mate
@ all which do you prefer when nothing is been played ?
image one
image 2
or image three
cheer all
(2015-07-18, 11:01)Njaynl Wrote: [ -> ]Any news for the queue buttons ?
No, sorry, still on the to do list. To make a smart list parser myself will really take a lot of time.
meridius btw I like the way you created flags for each language/Subtitle selection, will you be able to have all kind of flags and do you think rschiks will be able to implement it?
I have also added the Kodi remote control buttons to the custom bottom menu bar. You can now choose from 95 buttons in total.
(2015-07-18, 11:08)rschiks Wrote: [ -> ]I have also added the Kodi remote control buttons to the custom bottom menu bar. You can now choose from 95 buttons in total.
This is great! Because one thing I like to have is fullscreen when I start a music file. I don't want to jump back and forth between remote control and select full screen each time. Perhaps this can help me or if there is a possibility to have a option whether you want full screen or not.
(2015-07-18, 11:07)Goliath2000 Wrote: [ -> ]meridius btw I like the way you created flags for each language/Subtitle selection, will you be able to have all kind of flags and do you think rschiks will be able to implement it?
i could use any any amount but I don't know what are the top 20 languages that are used on DVD and blu Rays.
(2015-07-18, 11:13)meridius Wrote: [ -> ] (2015-07-18, 11:07)Goliath2000 Wrote: [ -> ]meridius btw I like the way you created flags for each language/Subtitle selection, will you be able to have all kind of flags and do you think rschiks will be able to implement it?
in mkvtoolnix you will find all supported languange. If you want I can list them here?
could you all take a look at post 1082 changed the images which would you like best with a picture behind the text or a grey box when nothing is been played ?
thanks
(2015-07-18, 11:15)Goliath2000 Wrote: [ -> ] (2015-07-18, 11:13)meridius Wrote: [ -> ] (2015-07-18, 11:07)Goliath2000 Wrote: [ -> ]meridius btw I like the way you created flags for each language/Subtitle selection, will you be able to have all kind of flags and do you think rschiks will be able to implement it?
if you can yes as there must be a lot of languanges on dvds and blu rays
This is an example about the info I get back from Kodi about the stream details of a movie:
streamdetails = {
audio = (
channels = 6;
codec = ac3;
language = eng;
channels = 2;
codec = aac;
language = spa;
subtitle = (
language = dut;
language = eng;
language = eng;
video = (
aspect = "2.407035112380981";
codec = h264;
duration = 6546;
height = 796;
stereomode = "";
width = 1916;
As you can see the language property is the key..in this example "eng" and "spa"
rschiks yes exactly, in MkvToolNix there is a dropdown list where you can see all the languauge propertys i.e eng, spa, gre, fre and so on..
meridius hmm I really don't know how to take that list, it would be better if you download MkvToolNix and see the entire list by your self?
will do I use it all the time, so I know my way around it lol
might even take a look at blu-ray.com and see what the reviews show if there is a list
