Full Version: Kyra for Kodi
(2015-07-27, 17:53)Goliath2000 Wrote: [ -> ]
(2015-07-27, 17:49)rschiks Wrote: [ -> ]
(2015-07-27, 17:13)Goliath2000 Wrote: [ -> ]ohh one more..
4. Remote control view when music is played it says audio stream Unknown (Unknown). I guess it thinks its a movie and if I switch to touch view I don't get artist picture or fanart picture. everything is black.
if kodi doesn't know it...I will give an unknown stream. It was already there from the beginning.
And you're correct about switching to touch view: display fan art or artist picture isn't implemented (yet)
Thanks for the explanation! From what I can see Kodi knows the stream. It shows mp3.
I don't check specifically on music streams....I will put it on the to do list.
(2015-07-27, 17:43)madmartigan57 Wrote: [ -> ]I just downloaded the new version. Big up for your work. It's really great to be able to customize the application.
Only one thing missing: now it is possible to custom application, would also be able to personalize top of the remote control to put the buttons that you want at the top and bottom of the remote.
Hoping that it is possible for a future release. For me it is the only thing missing: personalized remote Smile
Congratulations again
Technically it shouldn't be a problem :-) I will put it on the list.
(2015-07-27, 17:45)Goliath2000 Wrote: [ -> ]@rschiks sorry for posting several messages, but I found one more thing. If you for instance have started an album and a song is played it would be good to highlight that song in the song list. I think meridius had a play button i.e where it shows at what song it is currently playing, right now you need to jump between remote back and forth to find out the song or have the audio stream button selected in bottom menu bar to see the title of current played song.
Will add that.
I will submit version 1.6.1 this upcoming weekend with some fixes and tweaks.
This is what I meant when you go into the options menu and back to the music view.
http://s21.postimg.org/djbjbgn9j/IMG_0022.jpg
and the season selection on series? is that hard to implent? Smile
(2015-07-27, 18:21)Goliath2000 Wrote: [ -> ]This is what I meant when you go into the options menu and back to the music view.
Fixed!
(2015-07-27, 18:28)Njaynl Wrote: [ -> ]and the season selection on series? is that hard to implent? Smile
Not hard.....but costs time, it will come in a new view Wink
(2015-07-27, 18:32)rschiks Wrote: [ -> ]
Fixed!
Wonderful! Smile
Btw, I might be blind but isn't there any back button when you have selected an album from a specific artist and then want to go back to see the other albums from that artist?
@rschiks oh I found one more thing for the cdart you need to cut out the cd from the cdart.png when displaying it. not all cdarts have transparent backgrounds. When kodi is showing cdart it does that automatically.
(2015-07-27, 18:51)Goliath2000 Wrote: [ -> ]
Fixed!
Wonderful! Smile
No, not at the moment, well, now I have some feedback...:-)
(2015-07-27, 18:55)Goliath2000 Wrote: [ -> ]@rschiks oh I found one more thing for the cdart you need to cut out the cd from the cdart.png when displaying it. not all cdarts have transparent backgrounds. When kodi is showing cdart it does that automatically.
Maybe replace them with better versions from fanart.tv. It's a lot easier to do that. For me to create code to do image detection will take a lot longer.
(2015-07-27, 19:00)rschiks Wrote: [ -> ]
ok no problem! thanks again!
will you be able to pause the rotation when the album is not played?
(2015-07-27, 19:20)Goliath2000 Wrote: [ -> ]will you be able to pause the rotation when the album is not played?
I could make a setting for that.
