rschiks is it possible to have "movie sets" and all movies in same category as the way kodi is showing? It's much easier to have all movies in same place and if there is a movie sets then it would be easier to just click on it and display the movie set.
EDIT: and of course having a movie set separated the way you have is also good option, but I miss the option where all movies are in same place
(2015-07-27, 20:26)Goliath2000 Wrote: [ -> ]@rschiks is it possible to have "movie sets" and all movies in same category as the way kodi is showing? It's much easier to have all movies in same place and if there is a movie sets then it would be easier to just click on it and display the movie set.
When I get the movies from Kodi one property is the setid. So I know for all the movies which ones belong to a certain set. Maybe an extra sign added to a movie saying it belongs to a set. And when the details of that movie is shown you would also see the other movies in the set (or a new view is displayed). I need to see how this all would fit in the views (or specific views)
rschiks you should change the name to full flexible app
But I must say again you have done a tremendous work so far!
(2015-07-27, 21:02)Goliath2000 Wrote: [ -> ]@rschiks you should change the name to full flexible app
Well, not there yet. After the release today I have the feeling that on certain areas I was a little bit blind :-(
So maybe one or two small releases to get things in the right track again.
After my vacation I will start on version 1.7 (which I actually was working already) and will feature the new remote control view from meridius.
It's possible to made update for http command : if i use url scheme for example open another apps in kodi cc, actually not work.
My exemple: http command = roomie://
This http command work in safari, but not work with http command in KodiCC
For finish for the name for http command, it's possible change the name in buttons "http command" by the name of reel http? Exemple: for me, the good name for the Button is Roomie.
(2015-07-27, 21:30)madmartigan57 Wrote: [ -> ]It's possible to made update for http command : if i use url scheme for example open another apps in kodi cc, actually not work.
It's not a actually a http command that you would like to execute. Url schemes have to be handled differently. That's why it's not working right now. Safari detects it's different.
I will look into this.
You can already change the name of the button. Just edit a button and give it the name you want. You will see the name under the button.
Hi Richard great job on the new release. Had a quick play and loving the new power menu and button layouts. The gfx I did for that really shines when you can actually use it. Great work on the programming.
I have not had to much time with it but will fully test it over the next couple of days to see how it works out.
Let me know when you want to test the touch side of it
(2015-07-27, 23:09)meridius Wrote: [ -> ]Hi Richard great job on the new release. Had a quick play and loving the new power menu and button layouts. The gfx I did for that really shines when you can actually use it. Great work on the programming.
I also like the new power menu a lot! :-)
(2015-07-27, 17:10)rschiks Wrote: [ -> ]@njaynl:
You could add a context button to the bottom menu bar and the user command menu in the remote control touch view.
Which remote control view are you using?
the default non touch version ...... hmmmmm maybe adding the same customize as the top and menu bar? that you create your own remote view?
(2015-07-28, 08:10)Njaynl Wrote: [ -> ] (2015-07-27, 17:10)rschiks Wrote: [ -> ]@njaynl:
This is definitely on my list! Would be a nice feature :-)
(2015-07-27, 22:07)rschiks Wrote: [ -> ] (2015-07-27, 21:30)madmartigan57 Wrote: [ -> ]It's possible to made update for http command : if i use url scheme for example open another apps in kodi cc, actually not work.
Yes the title is displayed below the button but the best would be in the button to look like other buttons. Finally, the best of the best, but I do not know if this is possible, that appears in the title of the button and that we can make a little left of the title icon
After several hours spent with the new version of KODICC, it's a real pleasure to be able to configure the buttons that you want at the top and bottom of the application. Hopefully in the next version we can do the same with the remote control (Touch Version)
