TV is working good but LiveTV just locks up the app and disconnect from Kodi. When selecting LiveTV the spinning wheel is keeping on forever. I hope it generated a complete error report for you.
rschiks I found another bug
If you have a artist name like "Cher" and a another artist named "Cher Lloyd" or "Cheryl Cole" all their album will appears in Cher
EDIT: This is really weird! Because I have "Chris Brown" and "Chris Isaak" but they are not mixed. I tried XBMC commander to see if I had same issue over their and it seems that everything was normal, even in Kodi they are not mixed.
Any idea why just Cher appears to be like this?
(2015-07-29, 23:47)Rivermeadow Wrote: [ -> ]TV is working good but LiveTV just locks up the app and disconnect from Kodi. When selecting LiveTV the spinning wheel is keeping on forever. I hope it generated a complete error report for you.
Did it work in the previous version? or has something else changed?
(2015-07-30, 02:08)Goliath2000 Wrote: [ -> ]@rschiks I found another bug If you have a artist name like "Cher" and a another artist named "Cher Lloyd" or "Cheryl Cole" all their album will appears in Cher
Yep..I have an idea. Will check it.
(2015-07-30, 06:45)rschiks Wrote: [ -> ] (2015-07-29, 23:47)Rivermeadow Wrote: [ -> ]TV is working good but LiveTV just locks up the app and disconnect from Kodi. When selecting LiveTV the spinning wheel is keeping on forever. I hope it generated a complete error report for you.
Oh I didn't have an IP-TV installed until 1.6 so I really don't know.
(2015-07-30, 07:02)Rivermeadow Wrote: [ -> ] (2015-07-30, 06:45)rschiks Wrote: [ -> ] (2015-07-29, 23:47)Rivermeadow Wrote: [ -> ]TV is working good but LiveTV just locks up the app and disconnect from Kodi. When selecting LiveTV the spinning wheel is keeping on forever. I hope it generated a complete error report for you.
Which back-end are you using?
I'm using IPTV.INK.PVR.CLIENT from iptvsaga.com. The client is working very good in Kodi. I am on Minix X8-H.
(2015-07-30, 09:09)Rivermeadow Wrote: [ -> ]I'm using IPTV.INK.PVR.CLIENT from iptvsaga.com. The client is working very good in Kodi. I am on Minix X8-H.
And which version of Kodi?
15.2 Isengard directly from Google Store.
(2015-07-30, 09:16)Rivermeadow Wrote: [ -> ]15.2 Isengard directly from Google Store.
Ok, I will see if I can reproduce the issue.
(2015-07-27, 20:57)rschiks Wrote: [ -> ] (2015-07-27, 20:26)Goliath2000 Wrote: [ -> ]@rschiks is it possible to have "movie sets" and all movies in same category as the way kodi is showing? It's much easier to have all movies in same place and if there is a movie sets then it would be easier to just click on it and display the movie set.
EDIT: and of course having a movie set separated the way you have is also good option, but I miss the option where all movies are in same place
When I get the movies from Kodi one property is the setid. So I know for all the movies which ones belong to a certain set. Maybe an extra sign added to a movie saying it belongs to a set. And when the details of that movie is shown you would also see the other movies in the set (or a new view is displayed). I need to see how this all would fit in the views (or specific views)
Thanks I hope this can be implemented! It would be wonderful to have all movies in one place and the ability to have movie sets shown like the way kodi is doing it right now.
The LiveTV anomalies are haunting me for quite a while now, so I have decided to throw everything away are took a different approach.
I think the problems mainly had to do with getting all the info in the background and processing it. As you will see in the screen shot I generate now an overview of all channels, when clicked on it will retrieve the info from that specific channel.
Maybe not a nice EPG overview like before and some people won't like it, but I think this will work in all scenarios.
This will be available in version 1.6.1.
(2015-07-27, 21:30)madmartigan57 Wrote: [ -> ]It's possible to made update for http command : if i use url scheme for example open another apps in kodi cc, actually not work.
My exemple: http command = roomie://
This http command work in safari, but not work with http command in KodiCC
For finish for the name for http command, it's possible change the name in buttons "http command" by the name of reel http? Exemple: for me, the good name for the Button is Roomie.
@madmartigan57:
I have added detection for this. If it starts with http:// or https:// it will fire as an http command. if it starts with something else, like roomie:// or fb://, it opens a scheme url.
Added this behaviour in version 1.6.1
I have submitted version 1.6.1:
- New live TV & EPG screen
- Lots of tweaks and small bug fixes
