Full Version: Stop Start Stop Start
Hi Guys,
I am very new to RPI and after searching the internet I can find no other references to this issue so I'm hoping you can help. I have installed on a Raspberry PI (Model B+) the following build of CarPC .. http://engineering-diy.blogspot.co.uk/20...-2014.html
Everything works except in XBMC i'm finding that playing any type of media, it pauses and then plays then pauses and then plays again - all on its own! - every two seconds. Please see log below.
18:11:30 T:3044163584   DEBUG: ProcessMouse: trying mouse action leftclick
18:11:30 T:3044163584   DEBUG: Adding file /home/pi/Music/Batman.mp3 to music playlist
18:11:30 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
18:11:30 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
18:11:30 T:3044163584   DEBUG: CPlayerCoreFactory::GetPlayers(/home/pi/Music/Batman.mp3)
18:11:30 T:3044163584   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
18:11:30 T:3044163584   DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
18:11:30 T:3044163584   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
18:11:30 T:3044163584   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
18:11:30 T:3044163584   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
18:11:30 T:3044163584   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
18:11:30 T:3044163584   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
18:11:30 T:3044163584   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
18:11:30 T:3044163584   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
18:11:30 T:3044163584   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
18:11:30 T:3044163584   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
18:11:30 T:3044163584   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
18:11:30 T:3044163584   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
18:11:30 T:3044163584   DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
18:11:30 T:3044163584   DEBUG: CPlayerCoreFactory::GetPlayers: adding audiodefaultplayer (3)
18:11:30 T:3044163584   DEBUG: CPlayerCoreFactory::GetPlayers: for video=0, audio=1
18:11:30 T:3044163584   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: PAPlayer (3)
18:11:30 T:3044163584   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
18:11:30 T:3044163584   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
18:11:30 T:3044163584   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: OMXPlayer (4)
18:11:30 T:3044163584   DEBUG: CPlayerCoreFactory::GetPlayers: added 3 players
18:11:30 T:3044163584   DEBUG: CFileCache::Open - opening </home/pi/Music/Batman.mp3> using cache
18:11:30 T:2858415168  NOTICE: Thread FileCache start, auto delete: false
18:11:30 T:2858415168    INFO: CFileCache::Process - Hit eof.
18:11:30 T:3044163584    INFO: AudioDecoder: File is queued
18:11:30 T:3044163584   DEBUG: AudioDecoder::GetReplayGain - Final Replaygain applied: 1.000000, Track/Album Gain 89.000000, Peak 0.000000
18:11:30 T:3042620480   DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
18:11:30 T:3044163584    INFO: PAPlayer::PrepareStream - Ready
18:11:30 T:3044163584   DEBUG: PlayFile : OpenFile succeed, play state 1
18:11:30 T:2936009792  NOTICE: Thread PAPlayer start, auto delete: false
18:11:30 T:2936009792   DEBUG: PAPlayer::Process - Playback started
18:11:30 T:3034231872    INFO: CActiveAESink::OpenSink - initialize sink
18:11:30 T:3034231872   DEBUG: CActiveAESink::OpenSink - trying to open device PI:Analogue
18:11:30 T:2936009792   DEBUG: OnPlayBackStarted : play state was 1, starting 0
18:11:30 T:3034231872   DEBUG: CAESinkPi:SetAudioProps hdmi_stream_channels 0 hdmi_channel_map 00000008
18:11:30 T:3034231872   DEBUG: CAESinkPi:Initialize Format:15 Channels:2 Samplerate:44100 framesize:8 bufsize:35280 bytes/s=352800.00
18:11:30 T:3034231872   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100 m_handle 0xaad5a5b0
18:11:30 T:3034231872   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.audio_render) - port(100), nBufferCountMin(1), nBufferCountActual(2), nBufferSize(17640), nBufferAlignmen(16)
18:11:30 T:3034231872   DEBUG: CActiveAESink::OpenSink - SinkPi Initialized:
18:11:30 T:3034231872   DEBUG:   Output Device : Analogue
18:11:30 T:3034231872   DEBUG:   Sample Rate   : 44100
18:11:30 T:3034231872   DEBUG:   Sample Format : AE_FMT_FLOAT
18:11:30 T:3034231872   DEBUG:   Channel Count : 2
18:11:30 T:3034231872   DEBUG:   Channel Layout: FL,FR
18:11:30 T:3034231872   DEBUG:   Frames        : 4410
18:11:30 T:3034231872   DEBUG:   Frame Samples : 8820
18:11:30 T:3034231872   DEBUG:   Frame Size    : 8
18:11:30 T:3044163584   DEBUG: CGUIInfoManager::SetCurrentSong(/home/pi/Music/Batman.mp3)
18:11:30 T:3044163584   DEBUG: Loading additional tag info for file /home/pi/Music/Batman.mp3
18:11:31 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
18:11:31 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
18:11:31 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnPause from xbmc
18:11:31 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPause
18:11:32 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
18:11:32 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
18:11:34 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnPause from xbmc
18:11:34 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPause
18:11:36 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
18:11:36 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
18:11:38 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnPause from xbmc
18:11:38 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPause
18:11:40 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
18:11:40 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
18:11:41 T:3044163584   DEBUG: ------ Window Deinit (Pointer.xml) ------
18:11:42 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnPause from xbmc
18:11:42 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPause
18:11:44 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
18:11:44 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
18:11:46 T:3044163584    INFO: input device was unplugged HID 1241:1177
18:11:46 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnPause from xbmc
18:11:46 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPause
18:11:48 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
18:11:48 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
18:11:50 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnPause from xbmc
18:11:50 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPause
18:11:51 T:3044163584   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib-arm.so)
18:11:51 T:3044163584   DEBUG: Unloading: ImageLib-arm.so
18:11:52 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
18:11:52 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
18:11:54 T:3044163584    INFO: Found input device /dev/input/event0
18:11:54 T:3044163584    INFO: opened device 'HID 1241:1177' (file name /dev/input/event0), m_bSkipNonKeyEvents 0
18:11:54 T:3044163584 WARNING: no keymap support (requires /dev/tty0 - CONFIG_VT)
18:11:54 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnPause from xbmc
18:11:54 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPause
18:11:56 T:3044163584   DEBUG: ------ Window Init (Pointer.xml) ------
18:11:56 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
18:11:56 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
18:11:57 T:2900358208   DEBUG: Thread JobWorker 2900358208 terminating (autodelete)
18:11:58 T:3044163584   DEBUG: CAnnouncementManager - Announcement: OnPause from xbmc
18:11:58 T:3044163584   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPause
18:11:59 T:3044163584   DEBUG: ProcessMouse: trying mouse action leftclick
18:11:59 T:3042620480   DEBUG: CActiveAE::DiscardStream - audio stream deleted
18:11:59 T:3042620480   DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
18:11:59 T:2858415168   DEBUG: Previous line repeats 3 times.
18:11:59 T:2858415168   DEBUG: Thread FileCache 2858415168 terminating
18:11:59 T:2936009792   DEBUG: OnPlayBackStopped : play state was 2, starting 0
18:11:59 T:2936009792   DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
18:11:59 T:2936009792   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
18:11:59 T:2936009792   DEBUG: Thread PAPlayer 2936009792 terminating
18:11:59 T:2936009792  NOTICE: Thread JobWorker start, auto delete: true
18:11:59 T:2936009792   DEBUG: DoWork - Saving file state for audio item /home/pi/Music/Batman.mp3
18:12:06 T:3044163584   DEBUG: ProcessMouse: trying mouse action leftclick
18:12:06 T:3044163584   DEBUG: Activating window ID: 10000
18:12:06 T:3044163584   DEBUG: ------ Window Deinit (MyMusicSongs.xml) ------
18:12:06 T:3044163584   DEBUG: ------ Window Init (Home.xml) ------
18:12:06 T:2858415168  NOTICE: Thread LanguageInvoker start, auto delete: false
18:12:06 T:2858415168    INFO: initializing python engine.
18:12:06 T:2858415168   DEBUG: CPythonInvoker(6, special://skin/scripts/check_calibration.py): start processing
18:12:06 T:3044163584   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib-arm.so)
18:12:06 T:3044163584   DEBUG: Loading: /usr/local/lib/xbmc/system/ImageLib-arm.so
18:12:07 T:2858415168  NOTICE: -->Python Interpreter Initialized<--
18:12:07 T:2858415168   DEBUG: CPythonInvoker(6, special://skin/scripts/check_calibration.py): the source file to load is "special://skin/scripts/check_calibration.py" ("/home/pi/.xbmc/addons/skin.CarPC-touch/scripts/check_calibration.py")
18:12:07 T:2858415168   DEBUG: CPythonInvoker(6, special://skin/scripts/check_calibration.py): setting the Python path to /home/pi/.xbmc/addons/skin.CarPC-touch/scripts:/home/pi/.xbmc/addons/script.module.simplejson/lib:/usr/local/share/xbmc/addons/script.module.pil/lib:/home/pi/.xbmc/addons/script.common.plugin.cache/lib:/home/pi/.xbmc/addons/script.module.simple.downloader/lib:/usr/local/share/xbmc/addons/xbmc.debug/:/home/pi/.xbmc/addons/script.module.parsedom/lib:/home/pi/.xbmc/addons/script.module.xbmcswift2/lib:/home/pi/.xbmc/addons/script.module.feedparser/lib:/usr/local/share/xbmc/addons/script.module.pysqlite/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/gtk-2.0:/usr/lib/pymodules/python2.7
18:12:07 T:2858415168   DEBUG: CPythonInvoker(6, special://skin/scripts/check_calibration.py): entering source directory /home/pi/.xbmc/addons/skin.CarPC-touch/scripts
18:12:07 T:2858415168    INFO: CPythonInvoker(6, special://skin/scripts/check_calibration.py): script successfully run
18:12:07 T:2858415168    INFO: Python script stopped
18:12:07 T:2858415168   DEBUG: Thread LanguageInvoker 2858415168 terminating
18:12:12 T:3044163584   DEBUG: ------ Window Deinit (Pointer.xml) ------
18:12:29 T:2936009792   DEBUG: Thread JobWorker 2936009792 terminating (autodelete)
18:12:37 T:3044163584   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib-arm.so)
18:12:37 T:3044163584   DEBUG: Unloading: ImageLib-arm.so
18:15:30 T:3044163584   DEBUG: ------ Window Init (Pointer.xml) ------
This is happening without me pressing any buttons, the file type, music, video, if the media is on a USB stick - makes no difference and I have no idea how to stop it happening. It only happens in XBMC because if I play it using omxplayer from a terminal window, it plays perfectly.
It's these lines in the log that worry me ...
Any help will be greatly appreciated.
Many thanks,
Shane
Any hint of where to even start looking? It's like your constantly pressing the PLAY/PAUSE button over and over again.
It does this with any skin, any file type, in both videos and music and any player (DVDPlayer, OMSPlayer & PAPlayer).
Help! Anyone?
No worries .. I found the solution,
Anyone having the same issue and your using CarPC and you don't have the two rotary controller plugged in yet, you have to comment 4 lines of code in:
/home/pi/config/gpio_description.
Shane
