Full Version: Compile issues
Configure output
After seeing that improvements were made with timeshifting i thought i would upgrade my tvheadend,
I had to solve some dependency issues around libavcodec as it wanted version >55 and only 54 was installed.
checking for ffmpeg libraries ...                 fail
I did try the 3.9.2064 built that i created with
./configure --enable-libffmpeg_static
but it was broken.
No adapters tab in the configure section, also cwc tab was also absent. couldn't tune any muxes, so i reverted back to 3.9.692 which worked.
I deleted the config and tried with a black canvas, but could not configure the adapters as the missing tab, so no satellite config either.
I would like to get back to a working compiled version but i cant seam to get over the ffmpeg dependency.
Ubuntu 14.04.1
I have installed 3.9.2064 from the nigthly repo and only had to change the satellite config to KU10750 to get it working. Settings migrated automatically so it is looking ok atm but will only know for sure when i get home.
You don't need libav unless you want to do transcoding.
