Full Version: Xbmcbuntu generic IR receiver and 360 media remote don't work together
I want to use my xbmc installation with a Xbox360 media remote. I have one of the newer smaller ones. I bought one of these generic remotes (it is even mentioned in the xbmc remotes help) with IR receiver from eBay. The generic remote works with xbmc though it doesn't do all the buttons right. I know you can map these so that doesn't matter.
The problem is, that I can't get my Xbox media remote to work with the IR receiver. The remote has two functions. One is to control your television the other one is to control your xbox360 . for the TV function I can search for the right IR channel. That doesn't really help because the TV function is only two or so buttons that don't do the right things in xbmc. But they work so I guess the receiver is compatible with the remote.
So how do I get the IR receiver recognise the remote? I tried several forum posts but nothing seems to work. I set lirc to custom to try and set it up myself but no button press gets recognised from the receiver. The pre defined xbox360 media files didn't work either. I can use the generic remote that came with it but that's not a nice option.
Any ideas?
Without further details I suspect the remote / receiver you bought is a keyboard remote / receiver. Non standard.
(2014-11-12, 04:34)FishOil Wrote: [ -> ]Without further details I suspect the remote / receiver you bought is a keyboard remote / receiver. Non standard.
It is this one with the same receiver http://kodi.wiki/view/Remote_Control_Rev...MCE_remote
So would that mean it's not compatible? I can use the TV buttons on my xbox360 remote with it though.
edit: would that HP receiver work better or at all with my xbox360 media remote? https://www.amazon.de/dp/B00AYE6JDO/ref=...yub02JT0GT
edit2: It probably doesn't help much but i've opened up the IR receiver and took a picture. Any information out of that?
(2014-11-12, 09:51)Blattkube Wrote: [ -> ]It is this one with the same receiver http://kodi.wiki/view/Remote_Control_Rev...MCE_remote
I am almost certain that's a keyboard remote. It sends key presses. So I suspect the receiver is non standard as well.
