2014-11-12, 20:11
Hi all,
I have a Android box (Minix X7), and use XBMC to play my media via SAMBA share on my NAS.
It works almost flawless, excepts for a couple of movie files. This error is so ackward because, it only happens on the same movie (i've tried with different file versions). Somehow, these movies are, Edge of Tomorrow, and Chef.
What I see when I try to play this movies is the following.
https://docs.google.com/file/d/0B7uE9qDG...edit?pli=1
Here is a sample of my xbmc.log
18:11:31 T:1751274768 DEBUG: virtual bool CGUIWindowVideoBase::OnPlayMedia(int) smb://NAS/Movies/Chef.2014.720p.BluRay.x264-SPARKS[rarbg]/Chef.2014.720p.BluRay.x264-SPARKS.mkv
18:11:31 T:1751274768 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
18:11:31 T:1751274768 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
18:11:31 T:1751274768 DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
18:11:31 T:1751274768 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
18:11:31 T:1751274768 DEBUG: CPlayerCoreFactory::GetPlayers(smb://NAS/Movies/Chef.2014.720p.BluRay.x264-SPARKS[rarbg]/Chef.2014.720p.BluRay.x264-SPARKS.mkv)
18:11:31 T:1751274768 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
18:11:31 T:1751274768 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
18:11:31 T:1751274768 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
18:11:31 T:1751274768 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
18:11:31 T:1751274768 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
18:11:31 T:1751274768 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
18:11:31 T:1751274768 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
18:11:31 T:1751274768 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
18:11:31 T:1751274768 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
18:11:31 T:1751274768 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
18:11:31 T:1751274768 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
18:11:31 T:1751274768 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
18:11:31 T:1751274768 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
18:11:31 T:1751274768 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
18:11:31 T:1751274768 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
18:11:31 T:1751274768 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
18:11:31 T:1751274768 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
18:11:31 T:1751274768 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
18:11:31 T:1751274768 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
18:11:31 T:1751274768 NOTICE: DVDPlayer: Opening: smb://NAS/Movies/Chef.2014.720p.BluRay.x264-SPARKS[rarbg]/Chef.2014.720p.BluRay.x264-SPARKS.mkv
18:11:31 T:1751274768 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:11:31 T:1751274768 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to -250 msec
18:11:31 T:1751274768 DEBUG: LinuxRendererGL: Cleaning up GL resources
18:11:31 T:1751274768 DEBUG: SECTION:LoadDLL(libswscale-2-arm.so)
18:11:31 T:1751274768 DEBUG: Loading: /data/app-lib/org.wasser.xbmc-2/libswscale-2-arm.so
18:11:31 T:1789025760 NOTICE: Thread DVDPlayer start, auto delete: false
18:11:31 T:1789025760 NOTICE: Creating InputStream
18:11:31 T:1789025760 DEBUG: CFileCache::Open - opening <Movies/Chef.2014.720p.BluRay.x264-SPARKS[rarbg]/Chef.2014.720p.BluRay.x264-SPARKS.mkv> using cache
18:11:31 T:1789025760 DEBUG: CSmbFile::Open - opened Movies/Chef.2014.720p.BluRay.x264-SPARKS[rarbg]/Chef.2014.720p.BluRay.x264-SPARKS.mkv, fd=10000
18:11:31 T:1866151184 NOTICE: Thread FileCache start, auto delete: false
18:11:31 T:1751274768 DEBUG: ------ Window Init (DialogBusy.xml) ------
18:11:31 T:1751274768 DEBUG: Window DialogBusy.xml was already loaded
18:11:31 T:1751274768 DEBUG: Alloc resources: 0.01m
18:11:31 T:1751274768 DEBUG: SECTION:UnloadDelayed(DLL: libImageLib-arm.so)
18:11:31 T:1751274768 DEBUG: Unloading: libImageLib-arm.so
18:11:32 T:1789028576 NOTICE: script.tv.show.next.aired: ### getting series info for #259669 - Da Vinci's Demons
18:11:32 T:1789025760 DEBUG: static void CUtil::ScanForExternalSubtitles(const CStdString&, std::vector<CStdStr<char> >&): Searching for subtitles...
18:11:32 T:1789025760 DEBUG: int XFILE::CSMBDirectory::OpenDir(const CURL&, CStdString&) - Using authentication url smb://USERNAME:PASSWORD@NAS/Movies/Chef.2014.720p.BluRay.x264-SPARKS%5brarbg%5d
18:11:33 T:1789028576 NOTICE: script.tv.show.next.aired: ### getting series info for #262980 - House of Cards (US)
18:11:33 T:1789025760 DEBUG: int XFILE::CSMBDirectory::OpenDir(const CURL&, CStdString&) - Using authentication url smb://USERNAME:PASSWORD@NAS/Movies/Chef.2014.720p.BluRay.x264-SPARKS%5brarbg%5d/subs
18:11:33 T:1789025760 INFO: static void CUtil::ScanForExternalSubtitles(const CStdString&, std::vector<CStdStr<char> >&): found subtitle file smb://NAS/Movies/Chef.2014.720p.BluRay.x264-SPARKS[rarbg]/subs/Chef.2014.720p.BluRay.x264-SPARKS.idx
18:11:33 T:1789025760 INFO: static void CUtil::ScanForExternalSubtitles(const CStdString&, std::vector<CStdStr<char> >&): found subtitle file smb://NAS/Movies/Chef.2014.720p.BluRay.x264-SPARKS[rarbg]/subs/Chef.2014.720p.BluRay.x264-SPARKS.sub
18:11:33 T:1789025760 DEBUG: int XFILE::CSMBDirectory::OpenDir(const CURL&, CStdString&) - Using authentication url smb://USERNAME:PASSWORD@NAS/Movies/Chef.2014.720p.BluRay.x264-SPARKS%5brarbg%5d/Subs
18:11:33 T:1789025760 INFO: static void CUtil::ScanForExternalSubtitles(const CStdString&, std::vector<CStdStr<char> >&): found subtitle file smb://NAS/Movies/Chef.2014.720p.BluRay.x264-SPARKS[rarbg]/Subs/Chef.2014.720p.BluRay.x264-SPARKS.idx
18:11:33 T:1789025760 INFO: static void CUtil::ScanForExternalSubtitles(const CStdString&, std::vector<CStdStr<char> >&): found subtitle file smb://NAS/Movies/Chef.2014.720p.BluRay.x264-SPARKS[rarbg]/Subs/Chef.2014.720p.BluRay.x264-SPARKS.sub
18:11:33 T:1789025760 DEBUG: bool CZipManager::GetZipList(const CStdString&, std::vector<SZipEntry>&) - Processing zip://%2fstorage%2femulated%2f0%2fDownload%2frepository.superrepo.org.gotham.others.adult-latest.zip/
18:11:33 T:1789028576 NOTICE: script.tv.show.next.aired: ### getting series & episode info for #95011 - Modern Family
18:11:33 T:1789025760 DEBUG: ScanArchiveForSubtitles:: Found file zip://%2fstorage%2femulated%2f0%2fDownload%2frepository.superrepo.org.gotham.others.adult-latest.zip/repository.superrepo.org.gotham.others.adult/
18:11:33 T:1789025760 DEBUG: bool CZipManager::GetZipList(const CStdString&, std::vector<SZipEntry>&) - Processing zip://%2fstorage%2femulated%2f0%2fDownload%2frepository.superrepo.org.gotham.all-latest.zip/
18:11:33 T:1789025760 DEBUG: ScanArchiveForSubtitles:: Found file zip://%2fstorage%2femulated%2f0%2fDownload%2frepository.superrepo.org.gotham.all-latest.zip/repository.superrepo.org.gotham.all/
18:11:33 T:1789025760 DEBUG: bool CZipManager::GetZipList(const CStdString&, std::vector<SZipEntry>&) - Processing zip://%2fstorage%2femulated%2f0%2fDownload%2frepository.superrepo.org.gotham.all-latest-1.zip/
18:11:33 T:1789025760 DEBUG: ScanArchiveForSubtitles:: Found file zip://%2fstorage%2femulated%2f0%2fDownload%2frepository.superrepo.org.gotham.all-latest-1.zip/repository.superrepo.org.gotham.all/
18:11:33 T:1789025760 DEBUG: bool CZipManager::GetZipList(const CStdString&, std::vector<SZipEntry>&) - Processing zip://%2fstorage%2femulated%2f0%2fDownload%2f201409201019.zip/
18:11:35 T:1789028576 NOTICE: script.tv.show.next.aired: ### getting series & episode info for #247808 - Suits
18:11:36 T:1751274768 INFO: void XCURL::DllLibCurlGlobal::CheckIdle() - Closing session to http://feeds.xbmc.org (easy=0x709e6008, multi=0x6f3b6d00)
18:11:37 T:1789028576 NOTICE: script.tv.show.next.aired: ### getting series info for #80379 - The Big Bang Theory
18:11:38 T:1789028576 NOTICE: script.tv.show.next.aired: ### data update finished
18:11:42 T:1789025760 DEBUG: ScanArchiveForSubtitles:: Found file zip://%2fstorage%2femulated%2f0%2fDownload%2f201409201019.zip/201409201019/
18:11:42 T:1789025760 DEBUG: static void CUtil::ScanForExternalSubtitles(const CStdString&, std::vector<CStdStr<char> >&): END (total time: 11415 ms)
18:11:42 T:1789025760 DEBUG: CFileCache::Open - opening <Movies/Chef.2014.720p.BluRay.x264-SPARKS[rarbg]/subs/Chef.2014.720p.BluRay.x264-SPARKS.idx> using cache
18:11:42 T:1789025760 DEBUG: CSmbFile::Open - opened Movies/Chef.2014.720p.BluRay.x264-SPARKS[rarbg]/subs/Chef.2014.720p.BluRay.x264-SPARKS.idx, fd=10001
18:11:42 T:1915209040 NOTICE: Thread FileCache start, auto delete: false
18:11:43 T:1915209040 INFO: CFileCache::Process - Hit eof.
18:11:43 T:1915209040 DEBUG: Thread FileCache 1915209040 terminating
18:11:43 T:1789025760 DEBUG: CSmbFile::Close closing fd 10001
18:11:43 T:1789025760 DEBUG: CFileCache::Open - opening <Movies/Chef.2014.720p.BluRay.x264-SPARKS[rarbg]/subs/Chef.2014.720p.BluRay.x264-SPARKS.sub> using cache
18:11:43 T:1789025760 DEBUG: CSmbFile::Open - opened Movies/Chef.2014.720p.BluRay.x264-SPARKS[rarbg]/subs/Chef.2014.720p.BluRay.x264-SPARKS.sub, fd=10001
18:11:43 T:1915209040 NOTICE: Thread FileCache start, auto delete: false
18:11:43 T:1789025760 DEBUG: bool CDVDDemuxFFmpeg::Open(CDVDInputStream*) - avformat_find_stream_info starting
18:11:56 T:1789534056 DEBUG: Thread JobWorker 1789534056 terminating (autodelete)
18:11:56 T:1919305872 DEBUG: Thread JobWorker 1919305872 terminating (autodelete)
18:11:57 T:1789552552 DEBUG: Thread JobWorker 1789552552 terminating (autodelete)
18:11:57 T:1789025760 DEBUG: CSimpleFileCache::Seek - Attempt to seek past read data
18:11:58 T:1915209040 INFO: CFileCache::Process - Hit eof.
18:11:58 T:1789025760 DEBUG: CSimpleFileCache::Seek, request seek before start of cache.
18:11:58 T:1789025760 DEBUG: bool CDVDDemuxFFmpeg::Open(CDVDInputStream*) - av_find_stream_info finished
18:11:58 T:1789025760 DEBUG: static void CUtil::GetExternalStreamDetailsFromFilename(const CStdString&, const CStdString&, ExternalStreamInfo&) - Language = '' / Name = '(External)' / Flag = '0' from smb://NAS/Movies/Chef.2014.720p.BluRay.x264-SPARKS[rarbg]/subs/Chef.2014.720p.BluRay.x264-SPARKS.sub
18:11:58 T:1915209040 DEBUG: Thread FileCache 1915209040 terminating
18:11:58 T:1789025760 DEBUG: CSmbFile::Close closing fd 10001
18:11:58 T:1789025760 DEBUG: CFileCache::Open - opening <Movies/Chef.2014.720p.BluRay.x264-SPARKS[rarbg]/Subs/Chef.2014.720p.BluRay.x264-SPARKS.idx> using cache
18:11:58 T:1789025760 DEBUG: CSmbFile::Open - opened Movies/Chef.2014.720p.BluRay.x264-SPARKS[rarbg]/Subs/Chef.2014.720p.BluRay.x264-SPARKS.idx, fd=10001
18:11:58 T:1789534056 NOTICE: Thread FileCache start, auto delete: false
