2014-11-14, 00:44
Trying again as i Answered someones Question about my repo's and the POST was binned....Sorry about that (new to posting on this forum) but if i can get some help will appreciate.
Hi Everyone.
After a little advice please , I have been using XBMC/Kodi since April and have had luckily little issues/problems with the program.
I use an Mx box i purchased then install my own Kodi, I have done a few boxes for family and friends (I have 3 in my home) but the latest one i have done it to all of a sudden stopped working and the addons went blank.
The program would load up as a new installation each time i started it, I did then notice a circle top right of my home screen this is the symbol to say that space was running low.
I checked my apps and data and Kodi was 4.8GB of data, checking all my other boxes they are all around 2GB and running smooth so the problem seems to be that data is building up after only a week of use. After deleting the data it worked again and i had to reinstall the Repo's obviously.
So my question is have i done something wrong on my set up (maybe Kodi is a little different to xbmc as i install the same Repo's each time) or could it be a setting of the box i have missed or even maybe a one off. I have searched around and couldnt find any info or setting on this and although the boxes are only 8GB 2 I have had since June (changed the program on the first box) and the data seems not to move and have this issue.
Many thanks for your time.
Hi Everyone.
