great addon thank you for sharing it ! may you add the access to "following videos option" available on the webapp
thank you
(2015-09-17, 17:56)Zombi Wrote: [ -> ]great addon thank you for sharing it ! may you add the access to "following videos option" available on the webapp
thank you
I added it as a feature request to examine on implementing. It should be fairly easy to implement.
https://github.com/ddurdle/KODI-MediaFire/issues/3
I am getting login errors on windows PC? Can anyone confirm if the add-on is still working?
(2016-01-28, 19:16)dmdsoftware Wrote: [ -> ]I will test
Any progress and +1 for playing back the files we are 'following' ?
Looks like they rewrote the API and the plugin will need a re-write.
(2016-02-06, 15:37)dmdsoftware Wrote: [ -> ]Looks like they rewrote the API and the plugin will need a re-write.
That explains the issue. Thanks for checking it out . Appreciated
Will you be working on this add-on and make it work again?
I started working on it yesterday but I won't know until later today how far along it is (and how much longer until it is complete).
Good news, the plugin is fixed up. I have some more testing to do. It should be pushed out for release sometime Monday.
(2016-02-08, 05:03)dmdsoftware Wrote: [ -> ]New version v0.2.0 with the login fix.
I only have one "Following" source and tested against that, and it worked fine. Results may vary with lots of sources.
http://dmdsoftware.net/repository.ddurdl...-0.2.0.zip
Working Beautifully!
Following is working fine as well!
Great work yet again.
Only request is Transcoding quality selection
