Full Version: Helix RC 3 adding sources/duplicate films
Hi There
i buggered up one of my sources so removed it and now when re-adding it scans index.bdmv and movieobject.bdmv and adds the movies twice in the library
local scanner used as everything has an NFO file, a normal library update doesn't add the duplicate entry either
will try and get a log uploaded shortly
It's a bug. Should be fixed soon. See http://forum.kodi.tv/showthread.php?tid=208688
HIya
am still having this issue with RC3 has the fix gone into it yet?
The fix has already gone in, so if you are still having an issue then please post a debug log (wiki) of when Kodi scans in one of your bluray folders.
http://pastebin.com/muBJGWHd
i hope this is whats required if not please let me know Smile
i have noticed this a lot in the log also
10:50:41 T:10500 WARNING: VIDEO::CVideoInfoScanner:Tonguerocess directory 'M:\Movies1\CARS\12 Monkeys\' does not exist - skipping scan. and continues with that format for all the movies in that location also
not sure what i have done different this time around in experimenting but it appears working as use too
