2014-11-18, 18:27
2014-11-18, 18:33
I'm not sure what you are talking about. Please be more clear.
2014-11-19, 00:20
This might be the same problem I am having, I have Kodi installed on a windows 8.1 PC and was accessing my SMB shares (win 8.1 PC) fine on beta 2. As soon as I upgraded to beta 3 the shares were no longer accessible. Kodi kept prompting me for password which I entered but still made no difference and continued to ask for the password. I cleaned the library and re addded the shares and it worked again. I have just come back from work to watch some tv episodes and after restart it is doing the same thing again, cant access files "do i want to remove from library".
2014-11-19, 05:53
He's probably talking about not being able to view your network in Kodi. I'm running the Kodi DSPlayer version and when I add a video location I actually have to add SMB share and then select it, I'm unable to browse my network and just select a folder. Not a huge deal, I know where everything is located.
2014-11-19, 07:20
No, the shares are right there in Kodi. Kodi cant access them. It cant communicate with the host, It's like the media has been moved. It works for a while if you re add the media but then after a while it loses it again and will not scan the libraries.
2014-11-19, 07:41
What's awhile? I've been running this version for 3 weeks and it's pretty much rock solid except for a few minor annoyances.
2014-11-19, 08:39
A while as in I watched a movie it was o.k. powered down the system then next time i turned it on (1 day later) it wouldn't scan the libraries. and couldnt access the SMB shares? I have been using Beta 1 then 2 with no problems. Very strange. Also, when i tried to re add the shares to re scan in to library it asked me for the network password which i entered correctly but it wouldn't accept it and kept asking for the password again and again. Sorry if I can't explain in the right technical terms but i'm very much just a user.
2014-11-19, 11:24
Thanks David, never made a log before, will try and do one when i get home from work.
