Full Version: [Solved] boost/shared Present But Cannot Be Compiled - cross compiling
Hi all, after the failure of the native compile on armhf machine, i'm trying to cross compile kodi, but after hours of fight i'm still getting this error
Quote:checking boost/shared_ptr.hpp usability... no
checking boost/shared_ptr.hpp presence... yes
configure: WARNING: boost/shared_ptr.hpp: present but cannot be compiled
configure: WARNING: boost/shared_ptr.hpp: check for missing prerequisite headers?
configure: WARNING: boost/shared_ptr.hpp: see the Autoconf documentation
configure: WARNING: boost/shared_ptr.hpp: section "Present But Cannot Be Compiled"
configure: WARNING: boost/shared_ptr.hpp: proceeding with the compiler's result
configure: WARNING: ## ------------------------------------ ##
configure: WARNING: ## Report this to http://issues.kodi.tv ##
checking for boost/shared_ptr.hpp... no
configure: error: Could not find a required library. Please see the README for your platform.
Searching the net i haven't found a way to solve (or disable) that requirement...i installed all the possible libboost (dev too) but nothing happens Sad
here are the logs:
bootstrap
configure
sorry, but i'm understandig if and what i'm missing Confused
Cheers
Tk
try the relevant files, config.log and config.log.err. they will hold the details.
looks like you're missing a C++ cross compiler. Try g++-arm-linux-gnueabi(hf)
Yessss....g++-arm was the missed package Confused
Installed, but now it give me a python errorSad
Quote:checking for a version of Python >= '2.1.0'... yes
checking for a version of Python >= 2.4... yes
checking for the distutils Python package... yes
checking for Python include path... -I/usr/include/python2.7
checking for Python library path... -L/usr/lib -lpython2.7
checking for Python site-packages path... /usr/lib/python2.7/dist-packages
checking python extra libraries... -lssl -lcrypto -lssl -lcrypto -L/usr/lib -lz -lpthread -ldl -lutil
checking python extra linking flags... -Xlinker -export-dynamic -Wl,-O1 -Wl,-Bsymbolic-functions
checking consistency of all components of python development environment... no
configure: error: in `/home/tokka/cubie-cc/kodi':
configure: error:
Could not link test program to Python. Maybe the main Python library has been
installed in some non-standard library path. If so, pass it to configure,
via the LDFLAGS environment variable.
Example: ./configure LDFLAGS="-L/usr/non-standard-path/python/lib"
ERROR!
You probably have to install the development version of the Python package
for your distribution. The exact name of this package varies among them.
(python-dev and python2.7-dev are installed)
Be patients please, is my first cross compile and i haven't found a full guide about to make it...if you have one to link me i'll appreciate Smile
i'm considering too to change the thread title for further issues...or it's better i open a new one?
Thanks guys Smile
having the same issue here
did you find any solution ?
you need to cross compile python as well
