2014-11-20, 02:57
2014-11-20, 02:57
2015-01-02, 23:02
Have you found a cure for this? I have the exact same problem and I really don't know what to check for in the debug log.
2015-01-03, 04:27
2015-01-03, 05:15
Oh... I kind of missed that,thanks for pointing it out The log # is 392212
Do you have any idea what would cause the seekbar to not disappear? Reading the log, if I understand correctly, aeon now seems to be loading it? Is it an issue with my skin, then? I tried switching skins to Confluence but I had the same result, tough...
Thanks again, this is driving me crazy, I tend to look at the bar instead of the movie!!
2015-01-03, 08:56
"Enabled Joystick: Sony PLAYSTATION®3 Controller"
Go into Settings -> System -> Input devices -> and disable joysticks.
2015-01-05, 01:57
A 100 times thank you, I was charging the controllers on my htpc! Thank you thank you thank you!
2015-01-19, 00:46
heh, I had this issue about 2 years ago with XBMC. Following the upgrade to Kodi last month, the problem re-appeared.
Thank you for rediscovering it :-)
2015-02-24, 04:09
I feel like such an idiot. Thank you for the reply... I did exactly the same thing. Plugged my playstation controllers into the HTPC then couldn't get rid of the "Seeking" bar.
Great catch, and great thanks!
(I created an account just to thank you... but I'll probably be around... LOVING Kodi!)
2015-03-03, 03:39
Yes the same thing here. Thanks for the solution
