2014-11-20, 03:04
2014-11-20, 05:30
Updating or removing videos (wiki)
2014-11-21, 21:02
I would like to remove all Movies and TV shows and then rescan i have to change Hard drives if i rescan it will double all movies and i don't want to go and delete each one at a time last time i just wiped my box but i don't want to do that because of mash up gone i found a way to keep it on there so it won't delete itself if i wipe it i will not be able to install again most everything still works
2014-11-21, 21:16
You won't get any kind of support to continue using your unsupported addon.
But you can go to video-files scroll to the source you want to remove, bring up the context menu [c] & remove source.
Add new source by selecting 'add source'
2014-11-22, 05:11
Same answer, it's all documented on the page Updating or removing videos (wiki). Use the "clean library" option.
2014-11-22, 15:03
thanks for you help i think i got it now
2015-08-11, 07:12
Hi all, I have the same problem but a very strange one. The source is not there anymore, but the files keep living in the Library (I've been messing around too much before....). So I would need to do a "Hard Reset" of the Video Library. How can I do that?
2015-08-11, 07:27
(2015-08-11, 07:12)Nukles Wrote: [ -> ]Hi all, I have the same problem but a very strange one. The source is not there anymore, but the files keep living in the Library (I've been messing around too much before....). So I would need to do a "Hard Reset" of the Video Library. How can I do that?
Two ways. One is to follow this: phantom source (wiki).
The other is to just use the file manager (wiki) and go into the "Profile directory" -> Database -> and delete all of the "myvideos##.db" files. Then restart Kodi. That will completely reset the video DB.
2017-01-03, 09:47
(2015-08-11, 07:27)Ned Scott Wrote: [ -> ](2015-08-11, 07:12)Nukles Wrote: [ -> ]Hi all, I have the same problem but a very strange one. The source is not there anymore, but the files keep living in the Library (I've been messing around too much before....). So I would need to do a "Hard Reset" of the Video Library. How can I do that?
I had a similar issue where I moved the location of my videos (family and music) therefore changed the paths in my Kodi shortcuts.
All was working and appeared well until I had a look in my kodi log, which was full of errors saying information could not be found regarding a video showing the old path and that it would not be added to the library.
Not being sure what the cause was I removed all my video source entries, cleaned my library, BUT still got all the errors reported in my kodi log.
So I deleted all my favourites and all my skin shortcuts thinking they may be the problem, BUT still got all the errors reported in my kodi log.
As you recommended I deleted my MyVideos99.db and all the errors in the log went away.
When I remove all my library video sources and cleaned my library, shouldn't that mean all my old references should be deleted from the kodi library database?
Now I need to re-add all my favourites and submenu options :-(
Thanks for your tip which worked a treat.
