Full Version: XBMCbuntu sees my wifi-card but doesn't connect?
Pages: 1 2
Hi all,
I'm trying to install XBMCbuntu on an older computer. I have to use wifi as the computer will be quite far from my router. I have a TP-Link TL-WN725N USB wifi-adapter, and the XBMCbuntu-installer sees it but it won't let my connect with it. I'll type in the password and hit connect but nothing happens.
XBMCbuntu also sees an old PCI wifi-adapter (b/g only) and if I type in the password for my wifi I'm able to click connect, but eventually it just times out.
I also tried a Netgear WNA3100 wifi-adapter but that doesn't even come up in the list of available network adapters.
Any thoughts on this situation?
Preferably I'd like to get one of my current wifi-adapters working (the TP-Link or the Netgear), do you think that's possible?
If not can you recommend me an adapter that will definitely work?
Thanks,
nejo
Anyone?
I followed this guide (http://brilliantlyeasy.com/ubuntu-linux-...r-install/) and I got my secondary adapter (TP-Link WN725N) to work.
Sadly XBMC seems a bit laggy on my system Sad
No one can help for the lags as nobody knows your system specs.
And I suppose it isn't XBMC. The cause might be the WiFi connection. But as fritsch said...we need more info
CPU: AMD Athlon Xp 5600+ (I think)
RAM: 4GB
GFX: Nvidia Geforce 8800GTS
XBMCbuntu is installed on a Kingston 8GB USB-stick.
Yeah, your GPU does not support vdpau decoding.
Video -> Acceleration, choose Method: Software and enable multi threaded decoding.
Post a Debug Log please. If you are lucky, you have that one:
Quote:GeForce 8800 GTS 512 0x0600 A
which has vdpau support
If I'm not mistaken I have the 512mb version. Can you find that out with the .log file?
I'm trying to follow the guide in the link you gave me, but when I try to upload the log file I get an error message saying that the LogUploader-plugin failed?
Then upload via ssh:
sudo apt-get install pastebinit
cat ~/.xbmc/temp/xbmc.log | pastebinit
Enable debuglogging in xbmc before, then play some videos, then do the commands.
(2014-11-21, 14:11)fritsch Wrote: [ -> ]Then upload via ssh:
You have a PM
I don't read PMs.
(2014-11-21, 14:57)fritsch Wrote: [ -> ]I don't read PMs.
http://paste.ubuntu.com/9147194/
That's a log with decoding method: software
Quote:13:03:35 T:139711710713600 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
13:03:35 T:139711710713600 DEBUG: CDVDVideoCodecFFmpeg::Open() Keep default threading 3 by videoplayer.useframemtdec
sudo apt-get install vdpauinfo
vdpauinfo | pastebinit
"Error creating VDPAU: device 1"
http://paste.ubuntu.com/9148427/
DISPLAY=:0 vdpauinfo | pastebinit
with the very same user that is currently running your xbmc session.
Pages: 1 2
