Full Version: Library - removed item does not return after update
Hi
For about a few weeks I am noticing that I cannot get item (read item as movie,episode,etc) back to the library with updateing library.
For example: you select remove item from library and choose not to be deleted from disk, then you run update library
Before this process would return item into library, but now it doesnt.
I am running latest nightlies Kodi on Windows 8.1
Does anyone have a clue what is going on?
Thank you in advance
UPDATE: i have posted this also under general support since friend of my told me he has the same problem on cubiebox... so it is not windows related.
