I'm using a Logilink ID0069 wireless mouse to control my XBMC running on a MK902 Box. On this box right click is back action. Now I would like to assign contextmenu action to middle mouse button (wheel), but it has no effect if I put it in mouse.xml as
<middleclick>contextmenu</middleclick>
Also
<longclick id="0">contextmenu</longclick>
for left button is not working. Wheelup and wheeldown action can be changed in my mouse.xml, so XBMC is reading this file. Then I tried to to see the button in xbmc.log with debugging on and tail via ssh. The wheel button can not be seen in the file (but other buttons of mouse and wheelup/wheeldown). So is this a problem of XBMC or a problem of mouse or maybe MK902 box?
thanks
Rainer
Right click is also the context menu. If you click on a video or something that is context sensitive, the context menu pops up. If you right click anywhere else, it's back.
(2014-11-20, 23:05)Ned Scott Wrote: [ -> ]Right click is also the context menu.
Unfortunately not working, even it is in focus, highlighted. If I use a wireless keyboard in parallel 'C' will open context menu, when mouse cursor is on item. Any explanation or advice?
Rainer
A
debug log (wiki) would help, but I definitely do not see why a long-left-click wouldn't work...
(2014-11-21, 13:15)Koying Wrote: [ -> ]A debug log (wiki) would help, but I definitely do not see why a long-left-click wouldn't work...
Here you are, I hope it helps.
Sorry, if it is too much, I don't know what you need.
Rainer
18:39:42 T:1750886952 ERROR: CProfilesManager: error loading special://masterprofile/profiles.xml, Line 0
Failed to open file
18:39:42 T:1750886952 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:39:42 T:1750886952 NOTICE: -----------------------------------------------------------------------
18:39:42 T:1750886952 NOTICE: Starting XBMC (13.2 Git:20140817-0f3db05). Platform: ARM Android 32-bit
18:39:42 T:1750886952 NOTICE: Using Debug XBMC x32 build, compiled Aug 17 2014 by GCC 4.8.0 for ARM Android 32-bit API level 14
18:39:42 T:1750886952 NOTICE: Running on Android 32-bit API level 19 (Android, 3.0.36+ armv7l)
18:39:42 T:1750886952 NOTICE: Host CPU: ARMv7 Processor rev 0 (v7l), 4 cores available
18:39:42 T:1750886952 NOTICE: Product: rk3188, Device: rk3188, Board: rk30sdk - Manufacturer: rockchip, Brand: rockchip, Model: RKM MK902, Hardware: rk30board
18:39:42 T:1750886952 NOTICE: ARM Features: Neon enabled
18:39:42 T:1750886952 NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.xbmc/cache/apk/assets
18:39:42 T:1750886952 NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.xbmc/cache/apk/assets
18:39:42 T:1750886952 NOTICE: special://masterprofile/ is mapped to: /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/userdata
18:39:42 T:1750886952 NOTICE: special://home/ is mapped to: /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc
18:39:42 T:1750886952 NOTICE: special://temp/ is mapped to: /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/temp
18:39:42 T:1750886952 NOTICE: The executable running is: /system/bin/app_process
18:39:42 T:1750886952 NOTICE: Local hostname: localhost
18:39:42 T:1750886952 NOTICE: Log File is located: /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/temp/xbmc.log
18:39:42 T:1750886952 NOTICE: load settings...
18:39:42 T:1750886952 DEBUG: static int CAndroidFeatures::GetVersion(): android.os.Build.VERSION 19
18:39:42 T:1750886952 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
18:39:42 T:1750886952 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
18:39:42 T:1750886952 NOTICE: Found 1 Lists of Devices
18:39:42 T:1750886952 NOTICE: Enumerated AUDIOTRACK devices:
18:39:42 T:1750886952 NOTICE: Device 1
18:39:42 T:1750886952 NOTICE: m_deviceName : AudioTrack
18:39:42 T:1750886952 NOTICE: m_displayName : android
18:39:42 T:1750886952 NOTICE: m_displayNameExtra: audiotrack
18:39:42 T:1750886952 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
18:39:42 T:1750886952 NOTICE: m_channels : FL,FR
18:39:42 T:1750886952 NOTICE: m_sampleRates : 44100
18:39:42 T:1750886952 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
18:39:42 T:1750886952 ERROR: CSettingsManager: unable to load settings from special://masterprofile/guisettings.xml, creating new default settings
18:39:42 T:1750886952 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
18:39:42 T:1750886952 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
18:39:42 T:1750886952 NOTICE: Default DVD Player: dvdplayer
18:39:42 T:1750886952 NOTICE: Default Video Player: dvdplayer
18:39:42 T:1750886952 NOTICE: Default Audio Player: paplayer
18:39:42 T:1750886952 NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:39:42 T:1750886952 NOTICE: Log level changed to 0
18:39:42 T:1750886952 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
18:39:42 T:1750886952 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:39:42 T:1750886952 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
18:39:42 T:1750886952 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
18:39:42 T:1750886952 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
18:39:42 T:1750886952 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
18:39:42 T:1750886952 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtv
18:39:42 T:1750886952 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/myth/mms/udp
18:39:42 T:1750886952 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
18:39:42 T:1750886952 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
18:39:42 T:1750886952 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
18:39:42 T:1750886952 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
18:39:42 T:1750886952 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
18:39:42 T:1750886952 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
18:39:42 T:1750886952 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
18:39:42 T:1750886952 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
18:39:42 T:1750886952 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
18:39:42 T:1750886952 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
18:39:42 T:1750886952 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
18:39:42 T:1750886952 NOTICE: Loaded playercorefactory configuration
18:39:42 T:1750886952 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:39:42 T:1750886952 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:39:42 T:1750886952 INFO: creating subdirectories
18:39:42 T:1750886952 INFO: userdata folder: special://masterprofile/
18:39:42 T:1750886952 INFO: recording folder:
18:39:42 T:1750886952 INFO: screenshots folder:
18:39:42 T:1750886952 INFO: load language info file: special://xbmc/language/English/langinfo.xml
18:39:42 T:1750886952 DEBUG: trying to set locale to en_US.UTF-8
18:39:42 T:1750886952 INFO: global locale set to C
18:39:42 T:1750886952 INFO: load English language file, from path: special://xbmc/language/
18:39:42 T:1750886952 DEBUG: POParser: loaded 3162 strings from file /data/data/org.xbmc.xbmc/cache/apk/assets/language/English/strings.po
18:39:42 T:1750886952 DEBUG: SECTION:LoadDLL(libavutil-52-arm.so)
18:39:42 T:1750886952 DEBUG: Loading: /data/app-lib/org.xbmc.xbmc-2/libavutil-52-arm.so
18:39:42 T:1750886952 DEBUG: SECTION:LoadDLL(libavcodec-54-arm.so)
18:39:42 T:1750886952 DEBUG: Loading: /data/app-lib/org.xbmc.xbmc-2/libavcodec-54-arm.so
18:39:42 T:1750886952 DEBUG: SECTION:LoadDLL(libavformat-54-arm.so)
18:39:42 T:1750886952 DEBUG: Loading: /data/app-lib/org.xbmc.xbmc-2/libavformat-54-arm.so
18:39:42 T:1752145464 NOTICE: Thread ActiveAE start, auto delete: false
18:39:42 T:1752146048 NOTICE: Thread AESink start, auto delete: false
18:39:42 T:1752146048 INFO: CActiveAESink::OpenSink - initialize sink
18:39:42 T:1752146048 DEBUG: CActiveAESink::OpenSink - trying to open device AUDIOTRACK:AudioTrack
18:39:42 T:1752146048 DEBUG: CActiveAESink::OpenSink - AUDIOTRACK Initialized:
18:39:42 T:1752146048 DEBUG: Output Device : android
18:39:42 T:1752146048 DEBUG: Sample Rate : 44100
18:39:42 T:1752146048 DEBUG: Sample Format : AE_FMT_S16NE
18:39:42 T:1752146048 DEBUG: Channel Count : 2
18:39:42 T:1752146048 DEBUG: Channel Layout: FL,FR
18:39:42 T:1752146048 DEBUG: Frames : 3072
18:39:42 T:1752146048 DEBUG: Frame Samples : 6144
18:39:42 T:1752146048 DEBUG: Frame Size : 4
18:39:42 T:1752145464 DEBUG: SECTION:LoadDLL(libswresample-0-arm.so)
18:39:42 T:1752145464 DEBUG: Loading: /data/app-lib/org.xbmc.xbmc-2/libswresample-0-arm.so
18:39:42 T:1750886952 NOTICE: Running database version Addons16
18:39:42 T:1750886952 DEBUG: SECTION:LoadDLL(libcpluff-arm.so)
18:39:42 T:1750886952 DEBUG: Loading: /data/app-lib/org.xbmc.xbmc-2/libcpluff-arm.so
18:39:43 T:1750886952 NOTICE: ADDONS: Using repository repository.xbmc.org
18:39:43 T:1750886952 NOTICE: ADDONS: Using repository repository.pvr-android.xbmc.org
18:39:43 T:1750886952 DEBUG: bool PERIPHERALS::CPeripherals::LoadMappings() - loaded node "Motorola Nyxboard Hybrid"
18:39:43 T:1750886952 DEBUG: bool PERIPHERALS::CPeripherals::LoadMappings() - loaded node "CEC Adapter"
18:39:43 T:1750886952 DEBUG: bool PERIPHERALS::CPeripherals::LoadMappings() - loaded node "Pulse-Eight CEC Adapter"
18:39:43 T:1750886952 DEBUG: bool PERIPHERALS::CPeripherals::LoadMappings() - loaded node "iMON HID device"
18:39:43 T:1750886952 DEBUG: PERIPHERALS::CPeripheralBusUSB::CPeripheralBusUSB(PERIPHERALS::CPeripherals*) - using libusb peripheral scanning
18:39:43 T:1750886952 DEBUG: SECTION:LoadDLL(libcec.so)
18:39:43 T:1750886952 DEBUG: Loading: libcec.so
18:39:43 T:1750886952 ERROR: Unable to load libcec.so, reason: (null)
18:39:43 T:1750886952 DEBUG: Dll libcec.so was not found in path
18:39:43 T:1750886952 ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
18:39:43 T:1754746768 NOTICE: Thread PeripBusUSB start, auto delete: false
18:39:43 T:1750886952 NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: android
18:39:43 T:1750886952 DEBUG: bool CWinSystemEGL::CreateWindow(RESOLUTION_INFO&): Created surface of size 1280x720
18:39:43 T:1750886952 NOTICE: Current resolution: 1280x720 @ 60.00 - Full Screen
18:39:43 T:1750886952 NOTICE: Previous line repeats 1 times.
18:39:43 T:1750886952 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
18:39:43 T:1750886952 NOTICE: Found ([email protected]) at 16, setting to RES_DESKTOP at 16
18:39:43 T:1750886952 NOTICE: Checking resolution 16
18:39:43 T:1750886952 NOTICE: GL_VENDOR = ARM
18:39:43 T:1750886952 NOTICE: GL_RENDERER = Mali-400 MP
18:39:43 T:1750886952 NOTICE: GL_VERSION = OpenGL ES 2.0
18:39:43 T:1750886952 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
18:39:43 T:1750886952 DEBUG: GLES: Extension Support Test - GL_NVX_gpu_memory_info NO
18:39:43 T:1750886952 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug
18:39:43 T:1750886952 DEBUG: GLES: Extension Support Test - GL_EXT_texture_format_BGRA8888 YES
18:39:43 T:1750886952 DEBUG: GLES: Extension Support Test - GL_IMG_texture_format_BGRA8888 NO
18:39:43 T:1750886952 DEBUG: GLES: Extension Support Test - GL_APPLE_texture_format_BGRA8888 NO
18:39:43 T:1750886952 DEBUG: GL: Vertex Shader compilation log:
18:39:43 T:1750886952 DEBUG: GL: Vertex Shader compiled successfully
18:39:43 T:1750886952 DEBUG: GL: Pixel Shader compilation log:
18:39:43 T:1750886952 DEBUG: GL: Fragment Shader compiled successfully
18:39:43 T:1750886952 DEBUG: GUI Shader [guishader_frag_default.glsl]- Initialise successful : 0x689bc368
18:39:43 T:1750886952 DEBUG: GUI Shader [guishader_frag_texture.glsl]- Initialise successful : 0x689cce10
18:39:43 T:1750886952 DEBUG: GUI Shader [guishader_frag_multi.glsl]- Initialise successful : 0x689d7b48
18:39:43 T:1750886952 DEBUG: GUI Shader [guishader_frag_fonts.glsl]- Initialise successful : 0x689d6d48
18:39:43 T:1750886952 DEBUG: GUI Shader [guishader_frag_texture_noblend.glsl]- Initialise successful : 0x68a1cd10
18:39:43 T:1750886952 DEBUG: GUI Shader [guishader_frag_multi_blendcolor.glsl]- Initialise successful : 0x68a22038
18:39:43 T:1750886952 DEBUG: GUI Shader [guishader_frag_rgba.glsl]- Initialise successful : 0x68a27880
18:39:43 T:1750886952 DEBUG: GLES: Extension Support Test - GL_OES_EGL_image_external YES
18:39:43 T:1750886952 DEBUG: GUI Shader [guishader_frag_rgba_oes.glsl]- Initialise successful : 0x68a2cc60
18:39:43 T:1750886952 DEBUG: GUI Shader [guishader_frag_rgba_blendcolor.glsl]- Initialise successful : 0x68a32390
18:39:43 T:1750886952 DEBUG: CWinSystemEGL::CreateNewWindow: No need to create a new window
18:39:43 T:1750886952 INFO: GLES: Maximum texture width: 4096
18:39:43 T:1750886952 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
18:39:43 T:1750886952 INFO: load default splash image: /data/data/org.xbmc.xbmc/cache/apk/assets/media/Splash.png
18:39:43 T:1750886952 DEBUG: SECTION:LoadDLL(libImageLib-arm.so)
18:39:43 T:1750886952 DEBUG: Loading: /data/app-lib/org.xbmc.xbmc-2/libImageLib-arm.so
18:39:43 T:1750886952 INFO: load keymapping
18:39:43 T:1750886952 INFO: Loading special://xbmc/system/keymaps/appcommand.xml
18:39:43 T:1750886952 INFO: Loading special://xbmc/system/keymaps/gamepad.xml
18:39:43 T:1750886952 INFO: Loading special://xbmc/system/keymaps/joystick.xml
18:39:43 T:1750886952 NOTICE: No Joystick name specified, loading default map
18:39:43 T:1750886952 NOTICE: Previous line repeats 35 times.
18:39:43 T:1750886952 INFO: Loading special://xbmc/system/keymaps/keyboard.xml
18:39:43 T:1750886952 INFO: Loading special://xbmc/system/keymaps/mouse.xml
18:39:43 T:1750886952 INFO: Loading special://xbmc/system/keymaps/remote.xml
18:39:43 T:1750886952 INFO: Loading special://xbmc/system/keymaps/touchscreen.xml
18:39:43 T:1750886952 INFO: Loading special://masterprofile/keymaps/mouse.xml
18:39:43 T:1750886952 ERROR: static uint32_t CButtonTranslator::TranslateMouseCommand(const char*): Can't find mouse command longclick
18:39:43 T:1750886952 INFO: Loading special://profile/keymaps/mouse.xml
18:39:43 T:1750886952 INFO: GUI format 1280x720, Display 1280x720 @ 60.00 - Full Screen
18:39:43 T:1750886952 DEBUG: guilib: Fill viewport on change for solving rendering passes
18:39:43 T:1750886952 DEBUG: SECTION:LoadDLL(libcurl.so)
18:39:43 T:1750886952 DEBUG: Loading: /data/app-lib/org.xbmc.xbmc-2/libcurl.so
18:39:43 T:1750886952 NOTICE: Running database version Addons16
18:39:43 T:1750886952 DEBUG: void CDatabaseManager::Initialize(bool), updating databases...
18:39:43 T:1750886952 NOTICE: Running database version ViewModes6
18:39:43 T:1750886952 NOTICE: Running database version Textures13
18:39:43 T:1750886952 NOTICE: Running database version MyMusic46
18:39:43 T:1750886952 NOTICE: Running database version MyVideos78
18:39:43 T:1750886952 NOTICE: Running database version TV22
18:39:43 T:1750886952 NOTICE: Running database version Epg7
18:39:43 T:1750886952 DEBUG: void CDatabaseManager::Initialize(bool), updating databases... DONE
18:39:43 T:1750886952 INFO: DPMS: not supported on this platform
18:39:43 T:1750886952 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
18:39:43 T:1750886952 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
18:39:43 T:1750886952 INFO: Unloading old skin ...
18:39:43 T:1750886952 INFO: load skin from: /data/data/org.xbmc.xbmc/cache/apk/assets/addons/skin.confluence (version: 2.2.20)
18:39:43 T:1750886952 INFO: load fonts for skin...
18:39:43 T:1750886952 INFO: Loading fonts from /data/data/org.xbmc.xbmc/cache/apk/assets/addons/skin.confluence/720p/Font.xml
18:39:43 T:1750886952 DEBUG: POParser: loaded 148 strings from file /data/data/org.xbmc.xbmc/cache/apk/assets/addons/skin.confluence/language/English/strings.po
18:39:43 T:1750886952 INFO: Loading skin includes from /data/data/org.xbmc.xbmc/cache/apk/assets/addons/skin.confluence/720p/includes.xml
18:39:44 T:1750886952 INFO: load new skin...
18:39:44 T:1750886952 INFO: Loading user windows, path /data/data/org.xbmc.xbmc/cache/apk/assets/addons/skin.confluence/720p
18:39:44 T:1750886952 DEBUG: Load Skin XML: 32.74ms
18:39:44 T:1750886952 INFO: initialize new skin...
18:39:44 T:1750886952 DEBUG: guilib: Fill viewport on change for solving rendering passes
18:39:44 T:1750886952 INFO: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
18:39:44 T:1750886952 DEBUG: Load Pointer.xml: 2.69ms
18:39:44 T:1750886952 DEBUG: bool CTextureBundleXBT::OpenBundle() - Opened bundle /data/data/org.xbmc.xbmc/cache/apk/assets/addons/skin.confluence/media/Textures.xbt
18:39:44 T:1750886952 DEBUG: Alloc resources: 43.07ms (2.78 ms skin load)
18:39:44 T:1750886952 INFO: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
18:39:44 T:1750886952 DEBUG: Load DialogVolumeBar.xml: 4.85ms
18:39:44 T:1750886952 DEBUG: Alloc resources: 6.56ms (5.01 ms skin load)
18:39:44 T:1750886952 INFO: Loading skin file: DialogKaiToast.xml, load type: LOAD_ON_GUI_INIT
18:39:44 T:1750886952 DEBUG: Load DialogKaiToast.xml: 5.81ms
18:39:44 T:1750886952 DEBUG: Alloc resources: 6.02ms (6.01 ms skin load)
18:39:44 T:1750886952 INFO: Loading skin file: DialogMuteBug.xml, load type: LOAD_ON_GUI_INIT
18:39:44 T:1750886952 DEBUG: Load DialogMuteBug.xml: 2.40ms
18:39:44 T:1750886952 DEBUG: Alloc resources: 2.51ms (2.51 ms skin load)
18:39:44 T:1750886952 INFO: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
18:39:44 T:1750886952 DEBUG: Load DialogSeekBar.xml: 19.47ms
18:39:44 T:1750886952 DEBUG: Alloc resources: 24.08ms (19.61 ms skin load)
18:39:44 T:1750886952 INFO: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
18:39:44 T:1750886952 DEBUG: Load DialogBusy.xml: 4.23ms
18:39:44 T:1750886952 DEBUG: Alloc resources: 4.38ms (4.35 ms skin load)
18:39:44 T:1750886952 INFO: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
18:39:44 T:1750886952 DEBUG: Load DialogExtendedProgressBar.xml: 4.45ms
18:39:44 T:1750886952 DEBUG: Alloc resources: 4.69ms (4.66 ms skin load)
18:39:44 T:1750886952 INFO: Loading /data/data/org.xbmc.xbmc/cache/apk/assets/addons/skin.confluence/sounds/sounds.xml
18:39:44 T:1750886952 INFO: skin loaded...
18:39:44 T:1750886952 DEBUG: JSONRPC: JSON schema type stereoscopicmode references an unknown type GUI.Stereoscopy.Mode
18:39:44 T:1750886952 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
18:39:44 T:1750886952 INFO: JSONRPC: Adding type "GUI.Property.Value" to list of incomplete definitions (waiting for "GUI.Stereoscopy.Mode")
18:39:44 T:1750886952 INFO: JSONRPC: Resolving incomplete types/methods referencing GUI.Stereoscopy.Mode
18:39:44 T:1750886952 DEBUG: JSONRPC: JSON schema type definition references an unknown type Setting.Details.Setting
18:39:44 T:1750886952 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
18:39:44 T:1750886952 INFO: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
18:39:44 T:1750886952 INFO: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
18:39:44 T:1750886952 INFO: JSONRPC v6.14.3: Successfully initialized
18:39:44 T:1750886952 DEBUG: ADDON: Starting service addons.
18:39:44 T:1784487440 NOTICE: Thread LanguageInvoker start, auto delete: false
18:39:44 T:1784487440 NOTICE: Previous line repeats 1 times.
18:39:44 T:1784487440 INFO: initializing python engine.
18:39:44 T:1750886952 DEBUG: Activating window ID: 12999
18:39:44 T:1784488856 INFO: initializing python engine.
18:39:44 T:1750886952 DEBUG: ------ Window Init (Startup.xml) ------
18:39:44 T:1750886952 INFO: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
18:39:44 T:1750886952 DEBUG: Load Startup.xml: 7.56ms
18:39:44 T:1750886952 DEBUG: Alloc resources: 7.76ms (7.75 ms skin load)
18:39:44 T:1750886952 INFO: removing tempfiles
18:39:44 T:1750886952 NOTICE: initialize done
18:39:44 T:1750886952 NOTICE: Running the application...
18:39:44 T:1784941008 NOTICE: Thread LanguageInvoker start, auto delete: false
18:39:44 T:1784941008 INFO: initializing python engine.
18:39:44 T:1750886952 DEBUG: Activating window ID: 10000
18:39:44 T:1750886952 INFO: GLES: Enabling VSYNC
18:39:44 T:1750886952 INFO: GLES: Selected vsync mode 10
18:39:44 T:1750886952 DEBUG: ------ Window Deinit (Startup.xml) ------
18:39:44 T:1750886952 DEBUG: ------ Window Init (Home.xml) ------
18:39:44 T:1750886952 INFO: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
18:39:44 T:1784488856 DEBUG: CPythonInvoker(1, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/default.py): start processing
18:39:44 T:1784487440 DEBUG: CPythonInvoker(0, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck/service.py): start processing
18:39:44 T:1784941008 DEBUG: CPythonInvoker(2, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/default.py): start processing
18:39:44 T:1784488856 NOTICE: -->Python Interpreter Initialized<--
18:39:44 T:1784488856 DEBUG: CPythonInvoker(1, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/default.py): the source file to load is "/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/default.py"
18:39:44 T:1784941008 NOTICE: -->Python Interpreter Initialized<--
18:39:44 T:1784941008 DEBUG: CPythonInvoker(2, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/default.py): the source file to load is "/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/default.py"
18:39:44 T:1784488856 DEBUG: CPythonInvoker(1, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/default.py): setting the Python path to /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simplejson/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.beautifulsoup/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/script.module.pil/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/xbmc.debug/:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.parsedom/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.xbmcutil/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.xbmcswift2/lib:/:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6/lib-dynload
18:39:44 T:1784488856 DEBUG: CPythonInvoker(1, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/default.py): entering source directory /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader
18:39:44 T:1784488856 DEBUG: CPythonInvoker(1, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/default.py): instantiating addon using automatically obtained id of "script.module.simple.downloader" dependent on version 2.1.0 of the xbmc.python api
18:39:44 T:1784941008 DEBUG: CPythonInvoker(2, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/default.py): setting the Python path to /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simplejson/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.beautifulsoup/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/script.module.pil/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/xbmc.debug/:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.parsedom/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.xbmcutil/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.xbmcswift2/lib:/:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6/lib-dynload
18:39:44 T:1784941008 DEBUG: CPythonInvoker(2, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/default.py): entering source directory /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache
18:39:44 T:1784941008 DEBUG: CPythonInvoker(2, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/default.py): instantiating addon using automatically obtained id of "script.common.plugin.cache" dependent on version 2.1.0 of the xbmc.python api
18:39:44 T:1784487440 NOTICE: -->Python Interpreter Initialized<--
18:39:44 T:1784487440 DEBUG: CPythonInvoker(0, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck/service.py): the source file to load is "/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck/service.py"
18:39:44 T:1750886952 DEBUG: Load Home.xml: 395.20ms
18:39:45 T:1750886952 DEBUG: Alloc resources: 474.91ms (395.42 ms skin load)
18:39:45 T:1786133608 NOTICE: Thread JobWorker start, auto delete: true
18:39:45 T:1784487440 DEBUG: CPythonInvoker(0, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck/service.py): setting the Python path to /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simplejson/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.beautifulsoup/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/script.module.pil/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/xbmc.debug/:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.parsedom/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.xbmcutil/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.xbmcswift2/lib:/:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6/lib-dynload
18:39:45 T:1784487440 DEBUG: CPythonInvoker(0, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck/service.py): entering source directory /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck
18:39:45 T:1786133608 DEBUG: CRecentlyAddedJob::UpdateMusic() - Running RecentlyAdded home screen update
18:39:45 T:1750886952 DEBUG: no profile autoexec.py (/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/userdata/autoexec.py) found, skipping
18:39:45 T:1750886952 DEBUG: void CNetwork::NetworkMessage(CNetwork::EMESSAGE, int) - Starting network services
18:39:45 T:1750886952 NOTICE: starting zeroconf publishing
18:39:45 T:1786981488 NOTICE: Thread ZerocconfEmbedded start, auto delete: false
18:39:45 T:1786981488 DEBUG: ZeroconfEmbedded - processing...
18:39:45 T:1787296104 NOTICE: Thread JobWorker start, auto delete: true
18:39:45 T:1750886952 NOTICE: ES: Starting event server
18:39:45 T:1864944504 NOTICE: Thread EventServer start, auto delete: false
18:39:45 T:1864944504 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:39:45 T:1750886952 INFO: JSONRPC Server: Successfully initialized
18:39:45 T:1864944504 NOTICE: UDP: Listening on port 9777
18:39:45 T:1787296104 DEBUG: ZeroconfMDNS: identifier: servers.jsonrpc-tpc type: _xbmc-jsonrpc._tcp name:XBMC (localhost) port:9090
18:39:45 T:1786950200 NOTICE: Thread TCPServer start, auto delete: false
18:39:45 T:1787296104 DEBUG: ZeroconfMDNS: identifier: servers.eventserver type: _xbmc-events._udp name:XBMC (localhost) port:9777
18:39:45 T:1750886952 NOTICE: Current resolution: 1280x720 @ 60.00 - Full Screen
18:39:45 T:1750886952 DEBUG: CWinSystemEGL::CreateNewWindow: No need to create a new window
18:39:45 T:1750886952 NOTICE: GL_VENDOR = ARM
18:39:45 T:1750886952 NOTICE: GL_RENDERER = Mali-400 MP
18:39:45 T:1750886952 NOTICE: GL_VERSION = OpenGL ES 2.0
18:39:45 T:1750886952 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
18:39:45 T:1786950784 NOTICE: Thread JobWorker start, auto delete: true
18:39:45 T:1750886952 DEBUG: GLES: Extension Support Test - GL_NVX_gpu_memory_info NO
18:39:45 T:1750886952 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug
18:39:45 T:1750886952 DEBUG: GLES: Extension Support Test - GL_EXT_texture_format_BGRA8888 YES
18:39:45 T:1750886952 DEBUG: GLES: Extension Support Test - GL_IMG_texture_format_BGRA8888 NO
18:39:45 T:1750886952 DEBUG: GLES: Extension Support Test - GL_APPLE_texture_format_BGRA8888 NO
18:39:45 T:1750886952 DEBUG: GUI Shader - Tried to Initialise again. Was this intentional?
18:39:45 T:1784487440 DEBUG: CPythonInvoker(0, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck/service.py): instantiating addon using automatically obtained id of "service.xbmc.versioncheck" dependent on version 2.1.0 of the xbmc.python api
18:39:45 T:1786133608 DEBUG: GetRecentlyAddedAlbumSongs() query: SELECT songview.* FROM (SELECT idAlbum FROM albumview ORDER BY idAlbum DESC LIMIT 10) AS recentalbums JOIN songview ON songview.idAlbum=recentalbums.idAlbum
18:39:45 T:1786133608 DEBUG: bool CMusicDatabase::GetRecentlyAddedAlbums(VECALBUMS&, unsigned int) query: select * from albumview where strAlbum != '' order by idAlbum desc limit 10
18:39:45 T:1786133608 DEBUG: CRecentlyAddedJob::UpdateVideos() - Running RecentlyAdded home screen update
18:39:45 T:1784488856 INFO: CPythonInvoker(1, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/default.py): script successfully run
18:39:45 T:1864890712 NOTICE: Thread RSSReader start, auto delete: false
18:39:45 T:1864890712 DEBUG: CurlFile::Open(0x70936c80) http://feeds.xbmc.org/xbmc
18:39:45 T:1864890712 INFO: void XCURL::DllLibCurlGlobal::easy_aquire(const char*, const char*, XCURL::CURL_HANDLE**, XCURL::CURLM**) - Created session to http://feeds.xbmc.org
18:39:45 T:1750886952 INFO: GLES: Enabling VSYNC
18:39:45 T:1750886952 INFO: GLES: Selected vsync mode 10
18:39:45 T:1786133608 DEBUG: int CVideoDatabase::RunQuery(const CStdString&) took 75 ms for 10 items query: select * from movieview ORDER BY dateAdded desc, idMovie desc LIMIT 10
18:39:45 T:1786133608 DEBUG: int CVideoDatabase::RunQuery(const CStdString&) took 7 ms for 0 items query: select * from episodeview ORDER BY dateAdded desc, idEpisode desc LIMIT 10
18:39:45 T:1786133608 DEBUG: int CVideoDatabase::RunQuery(const CStdString&) took 4 ms for 0 items query: select * from musicvideoview ORDER BY dateAdded desc, idMVideo desc LIMIT 10
18:39:45 T:1786133608 DEBUG: CRecentlyAddedJob::UpdateTotal() - Running RecentlyAdded home screen update
18:39:45 T:1864890712 DEBUG: Got rss feed: http://feeds.xbmc.org/xbmc
18:39:45 T:1864890712 DEBUG: RSS feed encoding: UTF-8
18:39:45 T:1864890712 DEBUG: Parsed rss feed: http://feeds.xbmc.org/xbmc
18:39:45 T:1864890712 DEBUG: CurlFile::Open(0x70936c80) http://feeds.xbmc.org/latest_xbmc_addons
18:39:45 T:1784487440 DEBUG: Version Check: Version 0.2.0 started
18:39:45 T:1784488856 INFO: Python script stopped
18:39:45 T:1784488856 DEBUG: Thread LanguageInvoker 1784488856 terminating
18:39:45 T:1784941008 NOTICE: StorageServer Module loaded RUN
18:39:45 T:1784941008 NOTICE: StorageClient-2.5.4 Starting server
18:39:45 T:1864890712 DEBUG: Got rss feed: http://feeds.xbmc.org/latest_xbmc_addons
18:39:45 T:1864890712 DEBUG: Parsed rss feed: http://feeds.xbmc.org/latest_xbmc_addons
18:39:45 T:1864890712 DEBUG: CurlFile::Open(0x70936c80) http://feeds.xbmc.org/updated_xbmc_addons
18:39:46 T:1864890712 DEBUG: Got rss feed: http://feeds.xbmc.org/updated_xbmc_addons
18:39:46 T:1864890712 DEBUG: RSS feed encoding: UTF-8
18:39:46 T:1864890712 DEBUG: Parsed rss feed: http://feeds.xbmc.org/updated_xbmc_addons
18:39:46 T:1864890712 DEBUG: Thread RSSReader 1864890712 terminating
18:39:46 T:1864890712 NOTICE: Thread JobWorker start, auto delete: true
18:39:46 T:1786981488 DEBUG: ZeroconfMDNS: XBMC (localhost)._xbmc-jsonrpc._tcp.local. registration removed
18:39:46 T:1786981488 DEBUG: ZeroconfMDNS: XBMC (localhost)._xbmc-events._udp.local. registration removed
18:39:46 T:1787296104 DEBUG: virtual bool CImageLoader::DoWork() - took 128 ms to load special://masterprofile/Thumbnails/c/c9a3098b.jpg
18:39:46 T:1786950784 DEBUG: virtual bool CImageLoader::DoWork() - took 140 ms to load special://masterprofile/Thumbnails/c/c4d6ec0f.jpg
18:39:46 T:1786133608 DEBUG: virtual bool CImageLoader::DoWork() - took 112 ms to load special://masterprofile/Thumbnails/6/63481bb1.jpg
18:39:50 T:1750886952 DEBUG: bool CApplication::ProcessMouse(): trying mouse action leftclick
18:39:50 T:1750886952 DEBUG: Activating window ID: 10004
18:39:50 T:1750886952 DEBUG: ------ Window Deinit (Home.xml) ------
18:39:50 T:1750886952 DEBUG: ------ Window Init (Settings.xml) ------
18:39:50 T:1750886952 INFO: Loading skin file: Settings.xml, load type: KEEP_IN_MEMORY
18:39:50 T:1750886952 DEBUG: Load Settings.xml: 43.53ms
18:39:50 T:1750886952 DEBUG: Alloc resources: 48.13ms (43.92 ms skin load)
18:39:50 T:1750886952 DEBUG: Unfocus WindowID: 10004, ControlID: 9000
18:39:50 T:1864890712 DEBUG: virtual bool CImageLoader::DoWork() - took 101 ms to load special://skin/backgrounds/settings.jpg
18:39:51 T:1784487440 DEBUG: Version Check: Version installed {u'major': 13, u'tag': u'stable', u'minor': 2, u'revision': u'20140817-0f3db05'}
18:39:51 T:1784487440 DEBUG: Version Check: Version available {u'major': u'13', u'extrainfo': u'final', u'tagversion': u'', u'tag': u'stable', u'addon_support': u'yes', u'minor': u'2', u'revision': u'20140817-0f3db05'}
18:39:51 T:1784487440 DEBUG: Version Check: There is no newer stable available
18:39:51 T:1784487440 INFO: CPythonInvoker(0, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/service.xbmc.versioncheck/service.py): script successfully run
18:39:51 T:1784487440 INFO: Python script stopped
18:39:51 T:1784487440 DEBUG: Thread LanguageInvoker 1784487440 terminating
18:39:52 T:1750886952 DEBUG: bool CApplication::ProcessMouse(): trying mouse action leftclick
18:39:52 T:1750886952 DEBUG: Activating window ID: 10016
18:39:53 T:1750886952 DEBUG: ------ Window Deinit (Settings.xml) ------
18:39:53 T:1750886952 DEBUG: ------ Window Init (SettingsCategory.xml) ------
18:39:53 T:1750886952 INFO: Loading skin file: SettingsCategory.xml, load type: KEEP_IN_MEMORY
18:39:53 T:1750886952 DEBUG: Load SettingsCategory.xml: 38.40ms
18:39:53 T:1750886952 DEBUG: Alloc resources: 108.33ms (38.57 ms skin load)
18:39:53 T:1750886952 DEBUG: Unfocus WindowID: 10016, ControlID: -100
18:39:56 T:1750886952 DEBUG: bool CApplication::ProcessMouse(): trying mouse action leftclick
18:39:56 T:1750886952 DEBUG: Unfocus WindowID: 10016, ControlID: -96
18:40:01 T:1750886952 DEBUG: bool CApplication::ProcessMouse(): trying mouse action leftclick
18:40:01 T:1750886952 NOTICE: Log level changed to 2
18:40:01 T:1750886952 NOTICE: Enabled debug logging due to GUI setting. Level 2.
18:40:01 T:1750886952 DEBUG: Unfocus WindowID: 10016, ControlID: -80
18:40:01 T:1750886952 DEBUG: ------ Window Init () ------
18:40:01 T:1750886952 DEBUG: Alloc resources: 0.02ms (0.02 ms skin load)
18:40:06 T:1750886952 DEBUG: Keyboard: scancode: 0x04, sym: 0x0008, unicode: 0x0000, modifier: 0x0
18:40:06 T:1750886952 DEBUG: bool CApplication::OnKey(const CKey&): backspace (0xf008) pressed, action is Back
18:40:06 T:1750886952 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
18:40:06 T:1750886952 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
18:40:06 T:1750886952 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
18:40:06 T:1750886952 DEBUG: ------ Window Init (Settings.xml) ------
18:40:06 T:1750886952 DEBUG: Window Settings.xml was already loaded
18:40:06 T:1750886952 DEBUG: Alloc resources: 0.48m
18:40:07 T:1750886952 DEBUG: Keyboard: scancode: 0x04, sym: 0x0008, unicode: 0x0000, modifier: 0x0
18:40:07 T:1750886952 DEBUG: bool CApplication::OnKey(const CKey&): backspace (0xf008) pressed, action is Back
18:40:07 T:1750886952 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
18:40:07 T:1750886952 DEBUG: ------ Window Deinit (Settings.xml) ------
18:40:07 T:1750886952 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
18:40:07 T:1750886952 DEBUG: ------ Window Init (Home.xml) ------
18:40:07 T:1750886952 DEBUG: Window Home.xml was already loaded
18:40:07 T:1750886952 DEBUG: Alloc resources: 9.72m
18:40:13 T:1750886952 DEBUG: SECTION:UnloadDelayed(DLL: libImageLib-arm.so)
18:40:13 T:1750886952 DEBUG: Unloading: libImageLib-arm.so
18:40:16 T:1750886952 INFO: void XCURL::DllLibCurlGlobal::CheckIdle() - Closing session to http://feeds.xbmc.org (easy=0x6f725ef8, multi=0x6f6a2378)
18:40:20 T:1750886952 DEBUG: bool CApplication::ProcessMouse(): trying mouse action leftclick
18:40:20 T:1750886952 DEBUG: Activating window ID: 10025
18:40:21 T:1750886952 DEBUG: ------ Window Deinit (Home.xml) ------
18:40:21 T:1750886952 DEBUG: ------ Window Init (MyVideoNav.xml) ------
18:40:21 T:1750886952 INFO: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
18:40:21 T:1750886952 DEBUG: Load MyVideoNav.xml: 225.41ms
18:40:21 T:1750886952 DEBUG: Alloc resources: 250.15ms (225.58 ms skin load)
18:40:21 T:1750886952 DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/video/)
18:40:21 T:1750886952 DEBUG: ParentPath = [addons://sources/video/]
18:40:21 T:1892967152 NOTICE: Thread BackgroundLoader start, auto delete: false
18:40:21 T:1750886952 DEBUG: Activating window ID: 11112
18:40:21 T:1750886952 DEBUG: ------ Window Init (custom_SideMenuHelp.xml) ------
18:40:21 T:1750886952 INFO: Loading skin file: custom_SideMenuHelp.xml, load type: KEEP_IN_MEMORY
18:40:21 T:1750886952 DEBUG: Load custom_SideMenuHelp.xml: 3.61ms
18:40:21 T:1750886952 DEBUG: Alloc resources: 3.78ms (3.73 ms skin load)
18:40:21 T:1892967152 DEBUG: Thread BackgroundLoader 1892967152 terminating
18:40:28 T:1750886952 DEBUG: bool CApplication::ProcessMouse(): trying mouse action leftclick
18:40:29 T:1750886952 DEBUG: Unfocus WindowID: 11112, ControlID: 100
18:40:29 T:1750886952 DEBUG: Unfocus WindowID: 10025, ControlID: 550
18:40:29 T:1750886952 DEBUG: ------ Window Deinit (custom_SideMenuHelp.xml) ------
18:40:29 T:1864890712 DEBUG: SECTION:LoadDLL(libImageLib-arm.so)
18:40:29 T:1864890712 DEBUG: Loading: /data/app-lib/org.xbmc.xbmc-2/libImageLib-arm.so
18:40:30 T:1787296104 DEBUG: virtual bool CImageLoader::DoWork() - took 170 ms to load special://masterprofile/Thumbnails/f/f47ebae1.jpg
18:40:30 T:1786133608 DEBUG: virtual bool CImageLoader::DoWork() - took 101 ms to load special://masterprofile/Thumbnails/2/2ffb3c23.jpg
18:40:37 T:1750886952 DEBUG: bool CApplication::ProcessMouse(): trying mouse action mousedrag
18:40:38 T:1787296104 DEBUG: Previous line repeats 24 times.
18:40:38 T:1787296104 DEBUG: virtual bool CImageLoader::DoWork() - took 129 ms to load special://masterprofile/Thumbnails/f/f47ebae1.jpg
18:40:38 T:1750886952 DEBUG: bool CApplication::ProcessMouse(): trying mouse action mousedrag
18:40:39 T:1750886952 DEBUG: Previous line repeats 10 times.
18:40:39 T:1750886952 DEBUG: Unfocus WindowID: 10025, ControlID: 550
18:40:44 T:1750886952 DEBUG: bool CApplication::ProcessMouse(): trying mouse action leftclick
18:40:44 T:1750886952 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.science.friday/)
18:40:44 T:1750886952 DEBUG: ParentPath = [addons://sources/video/]
18:40:44 T:1786950784 DEBUG: bool XFILE::CPluginDirectory::StartScript(const CStdString&, bool) - calling plugin Science Friday('plugin://plugin.video.science.friday/','1','')
18:40:44 T:1786950784 DEBUG: bool XFILE::CPluginDirectory::WaitOnScriptResult(const CStdString&, int, const CStdString&, bool) - waiting on the Science Friday (id=3) plugin...
18:40:44 T:1864512456 NOTICE: Thread LanguageInvoker start, auto delete: false
18:40:44 T:1864512456 INFO: initializing python engine.
18:40:44 T:1864512456 DEBUG: CPythonInvoker(3, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.science.friday/addon.py): start processing
18:40:44 T:1864512456 NOTICE: -->Python Interpreter Initialized<--
18:40:44 T:1864512456 DEBUG: CPythonInvoker(3, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.science.friday/addon.py): the source file to load is "/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.science.friday/addon.py"
18:40:44 T:1864512456 DEBUG: CPythonInvoker(3, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.science.friday/addon.py): setting the Python path to /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.science.friday:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simplejson/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.beautifulsoup/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/script.module.pil/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.simple.downloader/lib:/data/data/org.xbmc.xbmc/cache/apk/assets/addons/xbmc.debug/:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.parsedom/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.xbmcutil/lib:/mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.xbmcswift2/lib:/:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.xbmc-2.apk/assets/python2.6/lib/python2.6/lib-dynload
18:40:44 T:1864512456 DEBUG: CPythonInvoker(3, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.science.friday/addon.py): entering source directory /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.science.friday
18:40:44 T:1864512456 DEBUG: CPythonInvoker(3, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.science.friday/addon.py): instantiating addon using automatically obtained id of "plugin.video.science.friday" dependent on version 2.1.0 of the xbmc.python api
18:40:44 T:1864512456 NOTICE: #### plugin.video.science.friday ####
18:40:44 T:1864512456 DEBUG: POParser: loaded 27 strings from file /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.module.xbmcutil/resources/language/English/strings.po
18:40:44 T:1864512456 NOTICE: http://www.sciencefriday.com/about/about-science-friday.html
18:40:44 T:1864512456 NONE: UrlHash = 081be9c8242bc8481934b44c10103f0b
18:40:44 T:1864512456 NOTICE: Cache Not Valid
18:40:45 T:1750886952 DEBUG: ------ Window Init (DialogBusy.xml) ------
18:40:45 T:1750886952 DEBUG: Window DialogBusy.xml was already loaded
18:40:45 T:1750886952 DEBUG: Alloc resources: 0.01m
18:40:45 T:1864512456 NONE: 200 - OK
18:40:45 T:1864512456 DEBUG: POParser: loaded 5 strings from file /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.science.friday/resources/language/English/strings.po
18:40:45 T:1786950784 DEBUG: bool XFILE::CPluginDirectory::WaitOnScriptResult(const CStdString&, int, const CStdString&, bool)- plugin returned successfully
18:40:45 T:1864512456 INFO: CPythonInvoker(3, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.science.friday/addon.py): script successfully run
18:40:45 T:1864512456 INFO: Python script stopped
18:40:45 T:1864512456 DEBUG: Thread LanguageInvoker 1864512456 terminating
18:40:45 T:1866412032 NOTICE: Thread BackgroundLoader start, auto delete: false
18:40:45 T:1750886952 DEBUG: Unfocus WindowID: 10025, ControlID: 50
18:40:45 T:1866412032 DEBUG: Thread BackgroundLoader 1866412032 terminating
18:40:45 T:1750886952 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
18:40:47 T:1786950784 DEBUG: static CStdString CTextureCacheJob::GetImageHash(const CStdString&) - unable to stat url /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.science.friday/fanart.jpg
18:41:00 T:1750886952 DEBUG: Keyboard: scancode: 0x04, sym: 0x0008, unicode: 0x0000, modifier: 0x0
18:41:00 T:1750886952 DEBUG: bool CApplication::OnKey(const CKey&): backspace (0xf008) pressed, action is Back
18:41:00 T:1750886952 DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/video/)
18:41:00 T:1750886952 DEBUG: ParentPath = [addons://sources/]
18:41:00 T:1866983696 NOTICE: Thread BackgroundLoader start, auto delete: false
18:41:00 T:1866983696 DEBUG: Thread BackgroundLoader 1866983696 terminating
18:41:01 T:1750886952 DEBUG: SECTION:UnloadDelayed(DLL: libImageLib-arm.so)
18:41:01 T:1750886952 DEBUG: Unloading: libImageLib-arm.so
18:41:01 T:1750886952 DEBUG: Keyboard: scancode: 0x04, sym: 0x0008, unicode: 0x0000, modifier: 0x0
18:41:01 T:1750886952 DEBUG: bool CApplication::OnKey(const CKey&): backspace (0xf008) pressed, action is Back
18:41:01 T:1750886952 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
18:41:01 T:1750886952 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
18:41:01 T:1750886952 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
18:41:01 T:1750886952 DEBUG: ------ Window Init (Home.xml) ------
18:41:01 T:1750886952 DEBUG: Window Home.xml was already loaded
18:41:01 T:1750886952 DEBUG: Alloc resources: 6.90m
18:41:07 T:1750886952 DEBUG: bool CApplication::ProcessMouse(): trying mouse action leftclick
18:41:07 T:1750886952 DEBUG: Activating window ID: 10111
18:41:07 T:1750886952 DEBUG: ------ Window Init (DialogButtonMenu.xml) ------
18:41:07 T:1750886952 INFO: Loading skin file: DialogButtonMenu.xml, load type: KEEP_IN_MEMORY
18:41:07 T:1750886952 DEBUG: Load DialogButtonMenu.xml: 32.83ms
18:41:07 T:1750886952 DEBUG: Alloc resources: 35.56ms (33.01 ms skin load)
18:41:10 T:1750886952 DEBUG: bool CApplication::ProcessMouse(): trying mouse action leftclick
18:41:10 T:1750886952 DEBUG: Unfocus WindowID: 10111, ControlID: 2
18:41:10 T:1750886952 DEBUG: Unfocus WindowID: 10000, ControlID: 20
18:41:10 T:1750886952 DEBUG: CAnnouncementManager - Announcement: OnQuit from xbmc
18:41:10 T:1750886952 DEBUG: GOT ANNOUNCEMENT, type: 8, from xbmc, message OnQuit
18:41:10 T:1750886952 NOTICE: Storing total System Uptime
18:41:10 T:1750886952 NOTICE: Saving settings
18:41:10 T:1750886952 NOTICE: stop all
18:41:10 T:1864890712 DEBUG: Thread JobWorker 1864890712 terminating (autodelete)
18:41:10 T:1787296104 DEBUG: Thread JobWorker 1787296104 terminating (autodelete)
18:41:10 T:1786950784 DEBUG: Thread JobWorker 1786950784 terminating (autodelete)
18:41:10 T:1786133608 DEBUG: Thread JobWorker 1786133608 terminating (autodelete)
18:41:10 T:1750886952 NOTICE: stop player
18:41:10 T:1750886952 INFO: stopping PVRManager
18:41:10 T:1750886952 DEBUG: void CNetwork::NetworkMessage(CNetwork::EMESSAGE, int) - Signaling network services to stop
18:41:10 T:1750886952 NOTICE: ES: Stopping event server
18:41:10 T:1750886952 DEBUG: void CNetwork::NetworkMessage(CNetwork::EMESSAGE, int) - Waiting for network services to stop
18:41:10 T:1750886952 NOTICE: stopping zeroconf publishing
18:41:10 T:1750886952 DEBUG: ZeroconfMDNS: Shutdown services
18:41:10 T:1750886952 DEBUG: ZeroconfMDNS: Removed service servers.eventserver
18:41:10 T:1750886952 DEBUG: ZeroconfMDNS: Removed service servers.jsonrpc-tpc
18:41:10 T:1786950200 DEBUG: Thread TCPServer 1786950200 terminating
18:41:10 T:1864944504 NOTICE: ES: UDP Event server stopped
18:41:10 T:1864944504 DEBUG: Thread EventServer 1864944504 terminating
18:41:10 T:1754746768 DEBUG: Thread PeripBusUSB 1754746768 terminating
18:41:10 T:1750886952 NOTICE: stop sap announcement listener
18:41:10 T:1750886952 NOTICE: clean cached files!
18:41:10 T:1750886952 NOTICE: unload skin
18:41:10 T:1750886952 INFO: Unloading old skin ...
18:41:10 T:1750886952 DEBUG: ------ Window Deinit () ------
18:41:10 T:1750886952 DEBUG: ------ Window Deinit (Home.xml) ------
18:41:10 T:1750886952 DEBUG: void CTextureBundleXBT::Cleanup() - Closed bundle
18:41:10 T:1750886952 DEBUG: ADDON: Stopping service addons.
18:41:10 T:1784941008 NOTICE: StorageServer-2.5.4 Closed down
18:41:10 T:1784941008 INFO: CPythonInvoker(2, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/default.py): script successfully run
18:41:10 T:1750886952 DEBUG: CPythonInvoker(2, /mnt/internal_sd/Android/data/org.xbmc.xbmc/files/.xbmc/addons/script.common.plugin.cache/default.py): script termination took 212ms
18:41:10 T:1784941008 INFO: Python script interrupted by user
18:41:10 T:1784941008 DEBUG: Thread LanguageInvoker 1784941008 terminating
18:41:10 T:1750886952 DEBUG: GUI Shader - Destroying Shader : 0x689bc340
18:41:10 T:1752145464 DEBUG: Thread ActiveAE 1752145464 terminating
18:41:10 T:1752146048 DEBUG: Thread AESink 1752146048 terminating
18:41:10 T:1750886952 NOTICE: stopped
18:41:10 T:1750886952 NOTICE: destroy
18:41:10 T:1750886952 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6871d900 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:10 T:1750886952 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6895b288 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:10 T:1750886952 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x68802c18 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:10 T:1750886952 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x6878fba0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
18:41:10 T:1750886952 NOTICE: unload sections
18:41:10 T:1750886952 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
18:41:10 T:1750886952 DEBUG: Previous line repeats 1 times.
18:41:10 T:1750886952 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:41:10 T:1750886952 DEBUG: object 0 --> 0 instances
18:41:10 T:1750886952 DEBUG: object 1 --> 0 instances
18:41:10 T:1750886952 DEBUG: object 2 --> 0 instances
18:41:10 T:1750886952 DEBUG: object 3 --> 0 instances
18:41:10 T:1750886952 DEBUG: object 4 --> 0 instances
18:41:10 T:1750886952 DEBUG: object 5 --> 0 instances
18:41:10 T:1750886952 DEBUG: object 6 --> 0 instances
18:41:10 T:1750886952 DEBUG: object 7 --> 0 instances
18:41:10 T:1750886952 DEBUG: object 8 --> 0 instances
18:41:10 T:1750886952 DEBUG: object 9 --> 0 instances
18:41:10 T:1750886952 DEBUG: SECTION:UnloadAll(DLL: libavutil-52-arm.so)
18:41:10 T:1750886952 DEBUG: Unloading: libavutil-52-arm.so
18:41:10 T:1750886952 DEBUG: SECTION:UnloadAll(DLL: libavcodec-54-arm.so)
18:41:10 T:1750886952 DEBUG: Unloading: libavcodec-54-arm.so
18:41:10 T:1750886952 DEBUG: SECTION:UnloadAll(DLL: libavformat-54-arm.so)
18:41:10 T:1750886952 DEBUG: Unloading: libavformat-54-arm.so
18:41:10 T:1750886952 DEBUG: SECTION:UnloadAll(DLL: libswresample-0-arm.so)
18:41:10 T:1750886952 DEBUG: Unloading: libswresample-0-arm.so
18:41:10 T:1750886952 DEBUG: SECTION:UnloadAll(DLL: libcpluff-arm.so)
18:41:10 T:1750886952 DEBUG: Unloading: libcpluff-arm.so
18:41:10 T:1750886952 DEBUG: SECTION:UnloadAll(DLL: libcurl.so)
18:41:10 T:1750886952 DEBUG: Unloading: libcurl.so
18:41:10 T:1750886952 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
18:41:10 T:1750886952 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
18:41:10 T:1750886952 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
18:41:10 T:1750886952 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
18:41:10 T:1750886952 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
18:41:10 T:1750886952 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
18:41:10 T:1750886952 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
18:41:10 T:1750886952 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
18:41:10 T:1750886952 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
18:41:10 T:1750886952 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
18:41:10 T:1750886952 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
18:41:10 T:1750886952 NOTICE: application stopped...
18:41:11 T:1750877816 DEBUG: PVRManager - destroyed
18:41:11 T:1750877816 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
