2014-11-23, 21:55
Hello,
I've recently bought an Intel NUC HTPC for use with XBMC - my raspberry pi gave out a few months ago (D34010WYK, http://kodi.wiki/view/Intel_NUC#Core_i3-based).
I installed Ubuntu 14.10 Server, set up user "xbmc" for XBMC, and started xbmc in standalone mode. My problem is that I have no audio, to be more precise I have no Audio output device under System -> Settings -> Audio output.
The NUC is connected to a Samsung TV via HDMI cable (this worked fine on the raspberry pi with Raspbian). I do not have Pulseaudio installed since I am not using it as a desktop; when I start XBMC, the debug log shows a lot of errors about not finding Pulseaudio. Tn the GUI, under System -> Settings -> Audio output, I cannot select 'HDMI' (or anything else); the option "Audio output device" is greyed out.
Details:
I notice the debug.log contains a lot of pulseaudio errors, but shouldn't I have the "hdmi" output option regardless of using pulseaudio - shouldn't ALSA be used if pulseaudio isn't installed? Either way, should there not be the option to select hdmi as output device?
Screenshot (or rather, photo of TV): http://postimg.org/image/tfpjd01dv/
-- glitters
Details:
- debug.log: http://paste.ubuntu.com/9201268/
- XBMC installed via launchpad PPA
Code:ii xbmc 2:13.1~rc1+dfsg1-1ubuntu3 all XBMC Media Center (arch-independent data package)
ii xbmc-bin 2:13.1~rc1+dfsg1-1ubuntu3 amd64 XBMC Media Center (binary data package)
- XBMC runs in standalone mode, and is started via xbmc-startup using the following script:
Code:root@saidin:~# cat /etc/init/xbmc.conf
# xbmc-upstart
# starts XBMC on startup by using xinit.
# by default runs as xbmc, to change edit below.
env USER=xbmc
description "XBMC-barebones-upstart-script"
author "Matt Filetto"
start on (filesystem and stopped udevtrigger)
stop on runlevel [016]
# tell upstart to respawn the process if abnormal exit
respawn
script
exec su -c "xinit /usr/bin/xbmc --standalone -- -nocursor :0" $USER
end script
- Linux Distro: Ubuntu 14.10 Server
- Architecture: x86_64
- output of "aplay -l":
Code:root@saidin:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDA Intel HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: HDMI [HDA Intel HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 0: ALC283 Analog [ALC283 Analog]
Subdevices: 1/1
-- glitters
