Sam, any recent updates you're working on?
is there a link for this animation somewhere
cant find it in all this post's
Sam fisher the splash screen with the smoke circles can u shorten it a little bit it stops before the words kodi shows up will be greatly appreciated..or anybody that has the skills to do it
easy fix - get a slower device
thisiischris how can I add it to kodi , using xperience1080 Skin ?
Hi everyone !
Does anyone knows what is the max duration of a gif supported by Kodi ? I use 6 seconds gifs for my animated landscapes but it seems that they have been cut so they are shorter to fit Kodi requirements.
Can we increase this duration ?
Thanks in advance for your help !
(2016-02-28, 13:18)EgYpT Wrote: [ -> ] (2014-12-09, 01:11)fastcolors Wrote: [ -> ]
here's my "nice try" of audio over samfisher/portuga2000 combo.. of course it's just an idea and slightly loose too, but I was bored.
(this is still my favourite video combo)
Cool! Can you share it?
Can you make with the white background?
Hi, nice work!!
I show you those that I have made
