2014-12-04, 10:28
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
2014-12-04, 11:02
(2014-12-04, 10:07)Piers Wrote: [ -> ]Maybe this is where I'm getting confused - it takes around one -two seconds to load Kodi, from pressing the button to seeing the home screen. This is why I see no point in an animation longer than 2-3 seconds.
It admittedly makes a lot more sense on something like OpenELEC or Kodibuntu than on OSX or Win.
2014-12-04, 11:28
What if the animation played and when Kodi is all ready it starts to load the skin GUI on top of the animation. The whole thing plays out completely, as if it were some kind of animated background, but it starts out like a splash screen. That way you see the whole thing and it doesn't delay startup.
I don't know what would be required from a technical standpoint for that, but it's an idea.
EDIT: Of course, this would then become skin-depedant, but that might be a good thing.
2014-12-04, 15:21
2014-12-04, 15:30
(2014-12-04, 11:28)Ned Scott Wrote: [ -> ]I don't know what would be required from a technical standpoint for that, but it's an idea.
Distros can AFAIK do an upstart animation and wait to switch TTY until kodi is loaded and the animation has played. So this would be distro specific and completely outside kodi. This given that x doesn't get messed up due to this but I have a recollection that one distro did just this.
2014-12-04, 15:44
I dont think Plymouth boot splashes can have that degree of detail or complexity no even sure any current solution would support this but thats from my tinkered point of view.
2014-12-04, 19:21
Here's my two pence.... I went simple just for comparison to the other awesome examples.
720p: http://i.imgur.com/XAZ4YqY.gif
1080p: http://i.imgur.com/8SxnWdf.gif
2014-12-04, 19:41
(2014-12-04, 11:02)natethomas Wrote: [ -> ](2014-12-04, 10:07)Piers Wrote: [ -> ]Maybe this is where I'm getting confused - it takes around one -two seconds to load Kodi, from pressing the button to seeing the home screen. This is why I see no point in an animation longer than 2-3 seconds.
But not everybody using Windows or OSX launches Kodi manually. My Windows HTPC loads Kodi as the shell so I'm okay to wait another 5-10 secs after Windows has loaded.
I think a setting inside Kodi to enable/disable or use short/long version of the animation will fix everything.
2014-12-04, 19:48
2014-12-04, 20:43
2014-12-04, 21:32
(2014-12-04, 10:28)nickr Wrote: [ -> ]Well that depends on your hardware doesn't it.
That's on a N54L - slow hardware running from a slow drive. On my main machine it takes longer due to the splash screen (I know, I could disable it).
Very true.
(2014-12-04, 20:43)samfisher Wrote: [ -> ]Thanks!
@jjd-uk: agree, here's a black version
Black version 1080p 4s LINK
Black version 1080p 10s LINK
Could you make a version without the headache-inducing start? A black background throughout.
2014-12-04, 21:37
Great work samfisher, black is perfect.
2014-12-04, 22:26
(2014-11-28, 15:53)samfisher Wrote: [ -> ]Here's something from me. I liked the rotation of the 1st one so I did something similar for the intro, then made an X appears and transforms to K.
Had to cut out a part of the animation, original one is longer and 1080p.
Like it! Has my vote!
2014-12-05, 00:42
(2014-12-04, 20:43)samfisher Wrote: [ -> ]Thanks!No wonder you are now a member of Team-Kodi, you skills is magical and they discovered you quickly. i had said it before at the former logo thread.
IMHO
Samfisher > DogHouseMedia
2014-12-05, 02:32
(2014-12-04, 20:43)samfisher Wrote: [ -> ]@jjd-uk: agree, here's a black version
Bloody hell I wasn't expecting you to give it a try until we had agreed a way forward, I think I just peed myself a little bit at how good that is
