2014-11-25, 14:16
Hi There
I've just invested in a NUC for my Windows 7 XBMC HTPC Setup
I would really like to use a IR remote if poss as the NUC i've gone for has the built in IR sensor.
I've been doing a little reading around and found out that the xbox 360 (black) remote control could be used with the NUC, however I cannot find a clear answer if it can or cannot.
Does anyone know if you can use this?
If not can the NEW Xbox one remote be used instead?
Cheers
Pete
Cheers
Pete
