2006-07-13, 01:43
i've been working on an update for a mod i did on the pmiii skin, which added infolabels to the dialog button menu(right thumbstick click), so you can check weather, time, system stats just by clicking the right thumbstick --> original x-scene post.
in the midst of updating to work with current builds i decided to add a button scroller for navigating windows and adding shortcut buttons for bookmarks, scripts, etc., partly inspired by slumberpods remix project. also i added 4 rss feeds that can be turned on/off.
the mod works by clicking the right thumbstick, which brings up the button menu, nav buttonscroller, rss feeds, and infolablels. you can switch between the buttonmenu and button scroller by pressing up/down on the d-pad. installing the mod is rather simple, since one just needs to ftp the customized dialogbuttonmenu.xml, rss.xml, and some images. however, the only thing a novice may find a little daunting is editing the dialogbuttonmenu.xml to get the shortcuts to work, though with a well written tut, it should'nt be hard to achieve.
here's a link to a demo video to give a better idea on how it functions --> link 6mb stream, .wmv format.
i'm basically just looking for feedback on whether or not this is a worthwhile implementation to release, or if it may conflict with future builds. that way, if the feedback is negative, then i at least wouldn't have wasted time packaging it for download, writing a tut, etc..
thanks in advance for any feedback.
