Full Version: FireTV: XBMC 13.2 can not play m2ts files (Sony HD video camera 50 frames/s)!?
On my windows 7 pc I can play with XBMC my m2ts files from my Sony HD video camera (50 frames/sec).
But on Fire TV are problems with the sound, the first seconds are synchron and later asynchron!
(see attachment information with o key)
Can I play this files on FireTV?
If yes how (tricks/settings)?
anglo
information with o key:
D(Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 256 kb/s)
P(aq:99%, Kb/s 251.33, att:-1750.9dB)
D(Video: h264 (High) (HDPR / 0x52504448), yuv420p, 1920x1080[SAR 1:1 DAR 16:9
P(fr:50.000; vq: 0%, dc:amc-h264, Mb/s:23.13, drop:68, skip:221, pc:1)
C( ad: 0.000, a/v: 6.035, edl:-, dcpu: 0% acpu: 0% vcpu: 0% cache: 28.17 MB 100%)
W( fps:50.15 CPU0: 30.4% CPU1: 40,7% CPU2: 17,4% CPU3: 0.0% )
Most likely the decoder / render throughput is not good enough for 50 progressive frames, a FireTV dev needs to have a look.
does it work if you disable mediacodec under settings - video - acceleration?
Hey wsnipex,
I had exactly the same issues and your advice is the solution. Disabling mediacodec fixes this issue. But with disabling mediacodec comes another issue. These MTS-Files are now scaled some kind like 4:3 - not 16:9.
Thanks,
Phil
