2014-11-25, 22:38
2014-11-28, 10:05
the cache for movie set artwork _should_ work already.. that is a little bit tricky because the artwork does not have any defined place where it will be (it can be either in the artwork dir or in the movie dir)..
nevertheless I will check the implementation
I'll have a look at the MP theme, where I "borrowed" the icon - maybe there is also a H265 icon there
2014-11-28, 20:08
Ups my bad, can I set a folder in the tMM settings where all the posters/fanarts for the sets are stored on my htpc. In my case that would be \\HTPC\Mehrteiler\Mehrteiler\ZZZ
Oh Man ich wünschte mein Englisch wäre besser.
Kann ich irgendwo in den tMM Einstellungen den Ordner festlegen in dem die Poster/Fanart der Sets gespeichert sind.
Bei mir wäre das z.b \\HTPC\Mehrteiler\Mehrteiler\ZZZ da ich von nem anderen PC meinen HTPC organisiere. nur wenn ich da was eintrage, bekomme ich die Poster/Fanart nicht zu sehen. Is mir vorher gar nicht aufgefallen:
Thanks/Danke
edit
The cache for the sets is working now, don't know why haven't changed something in the meanwhile
The H265 icon would be cool
Thanks/Danke
edit
2014-12-11, 17:44
I've just added the h265 icon - it will be in the next release.
