Full Version: How to install ZIP add-ons on Mac
Please help me, I want to install some add-on from ZIP. So I downloaded the zip file, I go to addons, install from zip file, find the files, but....I cannot click on OK, but the zip file goes to open, and I cannot to install it.
I am using KODI 14 beta 5 on MacMini iOS.
Thx very much.
Ales
sorry I got it, delete please.
Are you downloading the zip files with safari and is it indeed downloading as a zip file? I had the same frustrations this week and found out that safari extracts them automatically. You need to go into the preferences of safari and uncheck the box 'automatical extraction' (or whatever it is called. I'm not behind my mac currently). After that it will download a proper zipfile that you can install in Kodi
