Full Version: Helix (Betas) freezes on movie refresh.
I've been having an issue where if I "Refresh" the movie info for an item Kodi will freeze right after.
I started noticing this on my AFTV Stick that I just installed Kodi (nightly) on. However, I have also had this issue on my AFTV and Ouya since updating to the current nightlies (currently on kodi-20141124-968c624 on the Stick and kodi-20141124-216fbe1 on the AFTV and Ouya)
It doesn't appear to happen if I just Update, only if I refresh (change) the data on a single item.
Also, I wasn't able to use the Kodi log uploader because it kept throwing a Script Error, and pastebin only allows for <512KB for non-Pro users, but here's the last part of the debug log.
http://pastebin.com/znKgTWV1
If more info is required let me know.
could retry with a newer nightly? could be that we reverted a change that caused this.
I'll try the latest and see if that does anything to fix the issue and get back.
Is that what #5810 was about, or was that something different?
correct
