2004-06-11, 11:55
i would like this feature too but i got some other ideas.
protecting a folder or a share it’s fine but what about local media? the protection should be applied to a file according to a range of properties (pg-pg13-r-pr0n) which should be added the first time you try to play it. an example would be if i put a dvd or a cd that hasn't been authorized it will prompt for a password and after that it will let you apply the properties, otherwise it won’t play. (the ratings for movies could be downloaded from imdb)
other approach could be a user system where each user has his/her own password and settings. i am not much of a programmer but probably a phyton script that prompts for a user name and password when xbmc starts, then renames predefined xml files for each user and then restarts xbmc with the selected xml file. if phyton is able load and accept input from the onscreen keyboard it might be doable. i’m going to look at this second approach i might be able to write the script. it won’t solve the problem with local media but you could still protect shared folders.
