Dug around and couldn't find the answer. I'm using the latest raspbmc image from the rpi site.
I have a Behringer UCA 202 USB audio adapter connected. I want AC3/DTS passthrough the SPDIF to my receiver.
In the audio config, selected ALSA/SPDIF for both audio and passthrough device, enabled passthrough, and enabled ac3/dts.
Result is that I hear the XBMC menu clicks and sounds correctly via SPDIF, but when playing back video there is no sound output at all.
Am I missing some configuration somewhere?
Ah. Thanks for the rapid response.
Any downside to using dvdplayer - does it still support hw decode?
I will also give Helix a try.
(2014-11-28, 21:01)rwom Wrote: [ -> ]Any downside to using dvdplayer - does it still support hw decode?
dvdplayer uses hardware decode, but the player logic runs on the arm.
omxplayer uses hardware decode, and the player logic runs on the gpu.
This means omxplayer is a little more efficient. dvdplayer should handle moderate bitrate 1080p video fine. You may need omxplayer for raw Blu-Ray images.
dvdplayer has been made a lot more efficient in Helix (both in memory and cpu), so moving to Helix is recommended.
(2014-11-29, 00:50)rwom Wrote: [ -> ]Thanks.
http://openelec.tv does not work for me - site down?
Seems to be. Was up earlier today. Expect it will be back before long.
Ok, so I installed the latest openelec beta (4.95.5).
Now, when I enable SPDIF passthrough there is a signal on the output, but it's just noise. I think I might be running into the problem here
http://www.ac3filter.net/forum/index.php...351#msg351 where the UCA202 needs the L and R streams reversed to correctly pass through AC3/DTS. I assume there is no easy way to do that in Kodi.
What would you recommend for a cheap USB/SPDIF adapter that'll work with Kodi/RPI ?
Thanks for the help.
(2014-11-30, 04:23)rwom Wrote: [ -> ]What would you recommend for a cheap USB/SPDIF adapter that'll work with Kodi/RPI ?
I would imagine a hdmi splitter (e.g.
like this) would have the least limitations (i.e. you can still use omxplayer or dvdplayer).
Otherwise the
HifiBerry Digi (or Digi+ if you have a B+) is quite popular.
Since I'm CPU constrained... assume HDMI passthrough would be less overhead than USB/SPDIF ?
I ordered a turtle beach USB s card, but will return it and get the HDMI splitter if that's the case...
(2014-12-02, 19:51)rwom Wrote: [ -> ]Since I'm CPU constrained... assume HDMI passthrough would be less overhead than USB/SPDIF ?
Yes, passthrough over HDMI is the lowest CPU option.
Just to update this....
Using an HDMI audio splitter is working well - I can now stream 1080p bluray streams from SMB shares over my wired network with DTS/AC3 passthrough. Running the latest RC build.
Thanks for the help, and thanks to the team for the hard work.
Out of interest did the Turtle Beach USB II work at all ?
And which HDMI Audio splitter did you use ?
