yep. Will try without portable_data folder as other solution you give has been already tried.
Hope will resolve my problem.
Thanks anyway.
(2015-06-25, 19:21)Legion455 Wrote: [ -> ]Hey all, ...
Having trouble getting the Brochures to show on MovieSets. I'm probably doing something wrong, but I just can't figure it out.
Running Kodi, Isengard (latest nightly), Aeon Silva 2.04
Displaying Showcase, and have Boxset Mod - ON , Hide Brochure - OFF
Live case backgrounds for Moviesets work great, discart working great, ... but am only getting the Movieset cover to display, no brochures.
If anyone could point me towards a solution, I sure would appreciate it.
thanks
Allen
Remove all skin.info.service folders from your addons directory then restart Kodi
Update skin.info.service from this
LINK
(2015-06-25, 19:23)wilmans2m Wrote: [ -> ]yep. Will try without portable_data folder as other solution you give has been already tried.
Thanks anyway.
Good luck and I can try to help further if you post a
debug log (wiki)
(2015-06-25, 19:34)mikesilvo164 Wrote: [ -> ]Remove all skin.info.service folders from your addons directory then restart Kodi
Update skin.info.service from this LINK
Do I uninstall the service, or just delete folders? Note: I only see one folder - script.skin.info.service-master. Are there others to delete?
Also, your link is for version 1.0, which I already installed,... is there a later version?
thank you!!!!
(2015-06-25, 19:52)Legion455 Wrote: [ -> ]Do I uninstall the service, or just delete folders? Note: I only see one folder - script.skin.info.service-master. Are there others to delete?
thank you!!!!
If you only see one folder than you should just be able to install from zip or overwrite the folder manually. The instructions are to be sure it works the first time just in case you did have more than one folder for skin.info.service
(2015-06-25, 20:03)mikesilvo164 Wrote: [ -> ] (2015-06-25, 19:52)Legion455 Wrote: [ -> ]Do I uninstall the service, or just delete folders? Note: I only see one folder - script.skin.info.service-master. Are there others to delete?
thank you!!!!
Did it, still only getting the MovieSet infopanel 'dropdown'. Is the link you gave me supposed to be for version 1 or, ... a later version. (the link is for version 1, which I already installed)
thanks, sorry for the bother man.
Allen
(2015-06-25, 20:22)Legion455 Wrote: [ -> ]Did it, still only getting the MovieSet infopanel 'dropdown'. Is the link you gave me supposed to be for version 1 or, ... a later version. (the link is for version 1, which I already installed)
Allen
If it didn't work then close Kodi and delete all skin.info folders and install the one I posted a link to. If everything works but the brochure list it is because the newest skin.info.service is not installed. There has been no change with the version number so that may be why it does not correctly update when installing from zip.
(2015-06-25, 22:09)mikesilvo164 Wrote: [ -> ] (2015-06-25, 20:22)Legion455 Wrote: [ -> ]Did it, still only getting the MovieSet infopanel 'dropdown'. Is the link you gave me supposed to be for version 1 or, ... a later version. (the link is for version 1, which I already installed)
Allen
Stupid me, .... in View Options, I had Flatten - ON, which apparantly disables the Brochure.
Once I turned it off, ... the brochure worked fine.
Is there a way to make it ... when Flatten is ON, .... then force Hide Brochure = ON? just a suggestion.
This has prolly been said quite a few times, .. but you've really got the Aeon Skin to where it really POPS!!!!! thanks again!
(2015-06-25, 22:57)Legion455 Wrote: [ -> ]Stupid me, .... in View Options, I had Flatten - ON, which apparantly disables the Brochure.
This is an either or situation. If you want Flatten you can not have sets that open and display discs
(2015-06-25, 08:18)mikesilvo164 Wrote: [ -> ]I also would like some more request for additions and/or changes. If you have an idea tell me about it including changing any of the current views or adding any functionality. All the requests made so far are on my list. If I have said I would add stuff in the past but have not yet implemented it please post your request again as I may have forgotten about it.
I'd like to see:
1. Support for RCB or AL. Any or all of these views would be amazing (in order of preference): Low List w/ logo, poster, fanart, extended info, and game trailer window (auto play), Showcase w/ logo, poster, fanart, extended info, and game trailer window (in info panel fanart window), Wall w/ fanart, List w/ fanart.
2. Extra fanart in all views
3. Music fanart on home screen while music is playing.
(2015-06-25, 06:48)mikesilvo164 Wrote: [ -> ] (2015-06-25, 05:19)gmantonz Wrote: [ -> ]I think I am able to reproduce the problems Mike. 2 things I am seeing while testing this:
1) Boxset opens up fine when you first select it. I press enter to go into the set to look at the actual movies. Then when I press back to return to the main view, the boxset will open up in the background just like a regular movie case would and then a second later, the boxset will open as per usual to reveal the disks inside. This only seems to happen when you go into the set, then go back to the previous view. Tried it on a clean Kodi install and seeing the same issue.
2) Disks seem to stop rolling when you toggle the live background for movie sets option in skin settings. As soon as I do that, the cases open up fine, but the disks will not roll in. Restarting Kodi seems to fix the issue. Doesnt matter what live background is set to, just toggling it on or off, seems to break the diskart from rolling in until you restart Kodi.
Also wondering if its possible to have the fanart instead of the "grille" in the background for live background views. So the movie cases would display on the fanart rather than the silver grille. Perhaps the fanart could be a little faded so it does not overpower the cases. Just a thought on an additional feature...
The better the description the more likely I will be able to reproduce
I just updated Git which should hopefully fix issue number 1...
If you, wilmans2m, or anyone else could install and test it that would be extremely helpful.
Number 2 I cannot reproduce, I may have accidentally solved it by fixing #1 but the live background has no code connection between the disc animating so that bug is very surprising
Do you have a raspberry pi or something similar that might have low specs? I am trying to figure out if it could be a performance issue related to skin.info.service or something related to having lower spec hardware. I highly doubt it is connected to the script since it was created by phil65 but I like to rule out as many possibilities as I can no matter how unlikely they might be.
Not sure about the fanart for live background... I tried it and, to me at least, it seemed to not look or work as well.
Thanks Mike, confirming that #1 is fixed. Still seeing #2, but again, as soon as Kodi is restarted everything is fixed and back to normal. Tested on a i3 and i7 machines, lots of ram, etc, so definitely not low spec.
(2015-06-25, 12:09)wilmans2m Wrote: [ -> ]@MikeSilvo164
Well so i tested your solution. Unfortunately does not work too. Same Problems about rolling discart & opening cases.
Then i tried the last github.
Here was i found :
- 1/ Unfortunately same problems with rolling discart & opening cases. (3 movies work after opening a boxset. After does not work)
- 2/ Always with boxset mod, if two boxset are side to side, and if we navigate from one to the other, the second one is already opened.
- 3/ Mod delay does not seem to work. With 2 sec delay, cases always open immediately.
- 4/ you manage to correct the bug with normal case reflection & boxset opening
- If we deselect showcase mod, mod delay works, but point 2 remains.
So there is definitively a problem with the showcase mod. Hope you will be able to resolve it.
Again. Fresh install on 2 pc (htpc & desktop)
Don't know what to do.
Anyway, thanks again. Mr V. widget's work is really good
Tried testing these in a few different ways:
1) Can't reproduce. Opening a set like Harry Potter with 8 movies in it, all the cases open fine and diskart rolls in no matter how I scroll through them. Tried opening the boxset after it unfolds, tried opening it before it unfolds, can't reproduce this on my machine
2) Can't reproduce this either. Have 4 boxsets side by side, and scrolling through them, they all start from a closed state then unfold a second later. Again tried this a number of different ways and settings, can't seem to reproduce.
3) Not seeing it either, I have proper delays whether it's 2 seconds or 5. The only issue I found is: when you go into the boxset just as it starts unfolding, but you don't let it fully unfold and you press enter, the movie case inside the boxset will be open and have the disk inside already. But I think thats the limitation of the mod since you are going into the boxset midway through the animation. I honestly dont think its a big deal since this only happens if you time it right.
(2015-06-26, 04:39)gmantonz Wrote: [ -> ]Thanks Mike, confirming that #1 is fixed. Still seeing #2, but again, as soon as Kodi is restarted everything is fixed and back to normal. Tested on a i3 and i7 machines, lots of ram, etc, so definitely not low spec.
If possible can you please post a video and/or screenshot of the error? If you see it and I can't reproduce it is extremely hard to fix
(2015-06-26, 04:53)gmantonz Wrote: [ -> ]Tried testing these in a few different ways:
I thank you for the confirmation that you do not see the same issues of wilmans2m. I do consider all issues a problem to be solved so if you or wilmans2m can post a
debug log (wiki) it may provide some more insight. I must remind anyone that provides bug reports that I can not and do not support installing
Official:Forum_rules/Banned_add-ons (wiki) especially any banned repos as they often provide wrong or problem inducing versions of some required scripts. If you have any of them installed it can and usually does cause problems that can not be helped or solved by me. I recommend a fresh install without any included repos or addons from that list to help isolate possible causes of any problems you may experience. I am also not saying you are doing that but I need to say it as I spend too much time solving issues that can usually be traced back to something not supported by Kodi or myself.
Hey mikesilvo164, i made the buffer (cached/progress) seekbar in the osd menu a bit brighter, so it's easier to see how much a video has buffered (imo it was too dark before). If you decide to try it, just drop the file from the link below into the skins media/osd folder.
http://www.filedropper.com/midtexturecache
@MikeSilvo164
You will not believe me....For debbuging, i write on my advancedsettings :
"<loglevel>2</loglevel> <!-- Change this to "1" to hide the on-screen debug log text -->"
Then started kodi...no changing since yesterday....and all is working right. I'm fed up with those computers.....
Here is the debug log to see if something's wrong :
http://pastebin.com/Qc1NCGY7
REQUEST :
1/ Please update Mr. V mod to your last github
2/ Mediaflag : Re-added the expanded one please.
Thanks for all.
