I added LowList and Shift as options for Advanced Launcher to Git. Definitely needs some testing.
I only quickly looked it over for bugs.
@mikesilvo164 what is the mrv_widgets branch for?
I have a question about the movie rating (upper right) in the movie info screens:
Are these IMDB ratings?
If not, is it possible to get IMDB ratings in the info screens or whereever?
(2015-06-28, 15:41)marhutchy Wrote: [ -> ]@mikesilvo164 what is the mrv_widgets branch for?
It is a branch including the first test release of the
customizable widgets created by MR. V
(2015-06-28, 17:52)rarazxp Wrote: [ -> ]I have a question about the movie rating (upper right) in the movie info screens:
That depends on your scraper and its settings. The rating could be from The Movie DB, IMDb, TVDB, or any other that is available and selected..
(2015-06-28, 18:00)mikesilvo164 Wrote: [ -> ] (2015-06-28, 17:52)rarazxp Wrote: [ -> ]I have a question about the movie rating (upper right) in the movie info screens:
I have both TheMovieDB and TVDB addons installed and both changed to IMDB scraping.
Restarted but still the ratingnumber is not correct imo. Seems the same as before.
When I press info on a movie, you can see the rating in the upper right corner. Below the rating is a number telling how many people voted.
Is that not static info? Or is it changeable depending on the scraper?
(2015-06-28, 18:41)rarazxp Wrote: [ -> ]I have both TheMovieDB and TVDB addons installed and both changed to IMDB scraping.
That info is added when scraped. You will need to refresh to see different info if the Item is already in your library. You can use
Rating Update to keep things updated from IMDb on a regular basis.
Pushed some updates to Git to hopefully squash the remaining issues with the Boxset and Showcase mods.
Anybody willing to test it out and report back?
Anything in particular we should look for Mike? Just did a few quick tests on my system, nothing unusual jumps out, looking good.
(2015-06-28, 21:54)gmantonz Wrote: [ -> ]Anything in particular we should look for Mike? Just did a few quick tests on my system, nothing unusual jumps out, looking good.
I was able to sort of reproduce what you had mentioned earlier about the discs not rolling when entering a set quickly and interrupting the animation so that is what I hopefully fixed. I redid how those animations trigger. I was hoping you would be one of the testers
There was also a problem entering a set when only the ShowCase mod was active and the Boxset mod was not.
Ok let me check on that more thoroughly now...
EDIT: Alright, confirmed, issue is fixed! Now when I enter a boxset even mid-way through the animation, the case inside starts off in a closed state and the animation plays out in full including rolling diskart.
Also no problems entering a set when Boxset mod is disabled. The case opens up, however it is empty. Perhaps if the boxset mod is disabled but Showcase mod isn't, it can default to the 1st movie disk in the set? Or roll in all of them starting with the latest movie and placing the 1st original one ontop? Just some thoughts...
(2015-06-28, 22:04)gmantonz Wrote: [ -> ]Ok let me check on that more thoroughly now...
On regular movies (ie not sets) it is supposed to open empty then the disc rolls in. The Boxset mod only changes the way sets are handled. It is not rolling in for you?
Hi Mike
Know you have alot on your plate pal, but something for the future don't know if possible but in movies and in right hand list view, for movie boxsets don't know if possible to get the disk show up somewhere on the left hand side poster if you know what i mean mate,
Just chucking out there for the future if you ever get time buddy
Thanks for all the work you put in on this skin for me the best one i have ever used :-)
(2015-06-28, 22:23)kizzer31 Wrote: [ -> ]Hi Mike
I could add the first disc in the set but any more might be problematic
(2015-06-28, 22:23)mikesilvo164 Wrote: [ -> ]On regular movies (ie not sets) it is supposed to open empty then the disc rolls in. The Boxset mod only changes the way sets are handled. It is not rolling in for you?
No, so what I am seeing if Boxset is disabled, and Showcase mod is enabled is... individual movies are working fine, the disk is rolling in. For boxsets, the case opens up empty, no disk rolls in, the case closes after a few seconds. Movies inside the boxset are all fine. If I enable Boxset mod, it works great, the boxset unfolds to reveal the diskart inside.
