1. so far I do not know without skin modding yes extendend info shows tmdb votes !!
3. My Movie files look like these "3 Engel für Charlie - Volle Power (2003).bluray" and cover are displayed correctly
(2015-07-13, 12:36)flowerpot Wrote: [ -> ] (2015-07-13, 12:22)Mario S. Wrote: [ -> ]cd art is for local Files!!
Can you tell me which files you have in the media folder ??
.xbt files or files ( android, flags, views..........)
thanks for your advice what we have done is to install the helix version , it seemed to be running ok but we wanted more out of the skin so we download the git version and replaced the media file from git to helix so we have all the files included in the git version xbt and flags etc etc , would it be better to start again i know i did come across a bug with the skin shorcuts module allthough i said to defult action a certain part of a addon it did not work but i looked around and found a fix , thanks for your advice and help
please let only the three .xbt files in the Media folder and restart kodi !!!
(2015-07-13, 13:25)Mario S. Wrote: [ -> ] (2015-07-13, 12:36)flowerpot Wrote: [ -> ] (2015-07-13, 12:22)Mario S. Wrote: [ -> ]cd art is for local Files!!
hi we have put in only the xbt files in the media folder and we are still getting the same problem as before thanks for your advice
(2015-07-13, 13:14)Bjur Wrote: [ -> ]Hi a couple of questions, since I'm started using this skin:
1. Is it possible to have extended info loaded at default when pressing info on a movie? Now I have to press + and choose extended info and afterwards I only get themoviedb votes and not IMDB as normal.
2. I don't get colored info in the button when choosing small icon list, however it does work in right list.
3. My covers are not recognized as bluray when I have an external disc and calls it movie.bluray.disc. Am I doing something wrong or it is just as it is?
1. I added an option to the Git version but needs some testing... Only works for Movies and TV Shows so you will still get the default for Seasons and Episodes.
2. I need a better description or a screenshot. Not sure what you are referring to...
3. You would need to rip the disc. Have no idea how to parse that to show a cover for disc based content. If your talking about an external drive and it is an iso file or BDMV folder you need to play it once so Kodi can get the resolution info.
(2015-07-13, 16:07)flowerpot Wrote: [ -> ] (2015-07-13, 13:25)Mario S. Wrote: [ -> ] (2015-07-13, 12:36)flowerpot Wrote: [ -> ]thanks for your advice what we have done is to install the helix version , it seemed to be running ok but we wanted more out of the skin so we download the git version and replaced the media file from git to helix so we have all the files included in the git version xbt and flags etc etc , would it be better to start again i know i did come across a bug with the skin shorcuts module allthough i said to defult action a certain part of a addon it did not work but i looked around and found a fix , thanks for your advice and help
hi just asking if there is a fix for the half media flag issue we have thanks
Looking for some help from an Image Making Specialist
I would like to have all descriptive rating images to look like this:
Instead of this:
I think the detailed movie descriptions are hard to read and not accurate for every movie with that rating.
I was hoping to just have the general "Under 17 requires accompanying parent or guardian" for R, "Some material may be inappropriate for children under 13" for PG-13, and "Some material may not be suitable for children" for PG.
If the sizing and padding around the images could be the same as the first that would be the icing on the cake
Any help with that would be greatly appreciated
(2015-07-14, 20:40)flowerpot Wrote: [ -> ] (2015-07-13, 16:07)flowerpot Wrote: [ -> ] (2015-07-13, 13:25)Mario S. Wrote: [ -> ]please let only the three .xbt files in the Media folder and restart kodi !!!
not without changing the xml file of the skin !!! and with original flags there is nu problem !!
I found a few small things Mike !!!!
the German FSK logos a little too big an cut of when colored icons chosen !!
and in right list view i think they are a the FSK logo little too small and maybe wen can have a fallback if there are no Studio Icons ( in other views we have text of the studio ) !!
and in video addons is something wrong
(2015-07-13, 21:43)mikesilvo164 Wrote: [ -> ]1. I added an option to the Git version but needs some testing... Only works for Movies and TV Shows so you will still get the default for Seasons and Episodes.
Hi Mike,
I've tried to implement this in Madnox but must have got something wrong as the skin version of DialogVideoInfo.xml seems to still open and flash up on the screen very briefly before it switches to loading Extended info. You come across that when testing?
And thanks for the mod.
EDIT: Nevermind, got it right after looking at it correctly! Idiot!
Mike.
(2015-07-15, 09:16)Mario S. Wrote: [ -> ] (2015-07-14, 20:40)flowerpot Wrote: [ -> ] (2015-07-13, 16:07)flowerpot Wrote: [ -> ]hi we have put in only the xbt files in the media folder and we are still getting the same problem as before thanks for your advice
hi thanks for your reply we only put in the files you said about in the media folder , would this not take it back to as it was ? since we used the git media folder we just getting half a logo as in post 2079 , or is there a problem with the skin it self , thanks
(2015-07-15, 12:13)flowerpot Wrote: [ -> ] (2015-07-15, 09:16)Mario S. Wrote: [ -> ] (2015-07-14, 20:40)flowerpot Wrote: [ -> ]hi just asking if there is a fix for the half media flag issue we have thanks
use only the original files from git (delete the skin folder and download the new one from git) report if the issue with original icons still there !!!
(2015-07-15, 12:49)Mario S. Wrote: [ -> ] (2015-07-15, 12:13)flowerpot Wrote: [ -> ] (2015-07-15, 09:16)Mario S. Wrote: [ -> ]not without changing the xml file of the skin !!! and with original flags there is nu problem !!
hi thanks for your reply ok we download git master , deleted skin and put the one from git on system , rebooted system we have no submenu items allthough they are in the skin settings , we have no flags etc to movies also we have had a extendedinfo script error since using the git master thanks for your advice
