I think I have added most requests so far... If you requested something and it has not been added, request it again, cause I probably forgot about it
Post some new requests if you have any since I am running out of things to do
I've just been doing some cleanup of the inefficient code from when I started.
Still a little bit left to do but it all works so I'd rather work on adding stuff and skip the boring stuff for now
Please tell me about any bugs or anything that you notice to be misaligned , inaccurate, missing, annoying, or an opinion on changes to improve the skin.
Hi MikeSilvo.
Always a great mod you've done
Maybe a suggestion but it's related to Mr V.
I think widget is a little bit too "small". Instead of 6 case, we have 7 but on my tv, it's a little small i think.
About the skin itself, well, i have some question about pictures mode.
If you want to add something, maybe the netflix view from madnox is a good adventure
(2015-07-20, 09:41)wilmans2m Wrote: [ -> ]Hi MikeSilvo.
Mr. V is working on the widgets so it is up to him if he wants to add or change that... Could always say pretty pretty please with a cherry on top
What questions do you have about the pictures mode?
I like adding views so I will look into it but it will not look the same, there may be some big differences between the two.
@Mikesilvo164
If you looking for stuff to do, is it possible you could add the Kodiflix view from the Madnox mod into your mod. I have hacked it into my local copy but it has none of the configurability of the original but it looks good.
There are a lot of variables that are checked and set in the Madnox skin which obviously aren't in your mod and I don't know how to set them, as I say it was 'hacked' in.
At the risk of telling the master what to do the steps I did were;
It needs
1) Some graphics from Madnox media folder views/kodiflix
2) Amends to the MyVideoNav.xml to add the view
3) Added the additional Kodilflix variables into Variables.xml
4) Amended the View_800_Kodiflix.xml to remove the variables checking to make things visible.
I had to disable fanart globally to hide the fanart in the view or it appears in the background, if I knew how to disable fanart per view it would be awesome.
I'm quite proud of my hacking so here is my version of kodiflix in your skin.
Kodiflix Silvo
Good morning Mike,
Would you be willing to look at BigNoids master branch of Nox 5, which is being dveloped for Kodi 16 already, and do something similar (perhaps in a new branch) for Nox Silvo? Two reasons for my asking:
1. As of today, the Kodi nightlies are based on Kodi 16, not Isengard.
2. In my testing of Nox Silvo with Kodi 16, there is a problem with side menus (like when you want to change viewtype options), in which the keyboard becomes unresponsive and some of the menu remains on the screen even after you leave the menu. Latest Nox 5 from GitHub does not exhibit this issue.
Thank you for considering my request.
Regards,
Bart
(2015-07-20, 17:10)bsoriano Wrote: [ -> ]Good morning Mike,
Regards,
Bart
so far as I know master branch at github is for kodi 16
https://github.com/mikesilvo164/Aeon-Nox...ree/master
(2015-07-20, 19:12)Mario S. Wrote: [ -> ] (2015-07-20, 17:10)bsoriano Wrote: [ -> ]Good morning Mike,
Regards,
Bart
Thanks Mario! If that is the case, then the problem I mention has not been fixed yet in Nox Silvo. The issue is not present in latest Nox 5 from GitHub, or in Phil65 Nox branch experimental_widgets.
Regards,
Bart
(2015-07-20, 09:05)mikesilvo164 Wrote: [ -> ]I think I have added most requests so far... If you requested something and it has not been added, request it again, cause I probably forgot about it
Post some new requests if you have any since I am running out of things to do I've just been doing some cleanup of the inefficient code from when I started.
Mike - not something I have asked before, but the live TV could do with a bit of love....
1. When pressing record in EPG, the record icon appears at the top of the programme title and pushes the text down. In my opinion the red dot should be aligned to the left at the start of the text.
2 . In the channel list view, on the right hand side at the bottom you have the what's next and then the description of the programme that's on now. Again in my opinion this should be swapped around to show the description of now and then the what's on next...
Hope this isn't too vaige, doing this from memory as on my hols at the moment....
Hi Mike,
I know your preference for the "paused" screen is for it to be uncluttered, but would it be much work to add an option to show the info screen (with the time remaining text) displayed when the video is paused?
Hi all. I just added this mod to my Aeon Nox 5.0 for the showcase view, which is pretty awesome, but found an issue. When you scroll through pages it only move 6 movies to the left or right, not a full page like all other views do. Is this a glitch or something that can be changed?
(2015-07-21, 10:57)Dave the Minion Wrote: [ -> ]Hi all. I just added this mod to my Aeon Nox 5.0 for the showcase view, which is pretty awesome, but found an issue. When you scroll through pages it only move 6 movies to the left or right, not a full page like all other views do. Is this a glitch or something that can be changed?
this is a standalone skin (mod) you dont ned aeon nox 5 only these mod
Hey Mike I was wondering if it is possible to tweak/mod the skin so that the movie duuration is reflected in hours and NOT minutes. So instead of 123 minutes being displayed it'd be 2h 3minutes.
(2015-07-21, 19:21)smw6230 Wrote: [ -> ]Hey Mike I was wondering if it is possible to tweak/mod the skin so that the movie duuration is reflected in hours and NOT minutes. So instead of 123 minutes being displayed it'd be 2h 3minutes.
Mike,
I would also like to see this implemented. There is a script already that does this:
http://forum.kodi.tv/showthread.php?tid=220753
Regards,
Bart
