I wasnt Planning on making the widgets any bigger. In fact i had to slightly reduce the size so i could fit in two widgets on each home item. I may consider it way in the future after the next release.
(2015-07-20, 09:41)wilmans2m Wrote: [ -> ]Hi MikeSilvo.
Always a great mod you've done
Maybe a suggestion but it's related to Mr V.
I think widget is a little bit too "small". Instead of 6 case, we have 7 but on my tv, it's a little small i think.
About the skin itself, well, i have some question about pictures mode.
If you want to add something, maybe the netflix view from madnox is a good adventure
Thanks again silvo, your mods are incredible!
Nothing happens when I click the shortcut i or click TV show information for TV shows, but it shows the info for movies.
I selected the option to replace extendedinfo.
(2015-07-21, 22:35)bsoriano Wrote: [ -> ] (2015-07-21, 19:21)smw6230 Wrote: [ -> ] (2015-07-20, 12:34)Mario S. Wrote: [ -> ] (2015-07-20, 11:00)wilmans2m Wrote: [ -> ]@Mikesilvo164
http://forum.kodi.tv/showthread.php?tid=232265 seems to be interesting too
+1
Hey Mike I was wondering if it is possible to tweak/mod the skin so that the movie duuration is reflected in hours and NOT minutes. So instead of 123 minutes being displayed it'd be 2h 3minutes.
Mike,
I would also like to see this implemented. There is a script already that does this: http://forum.kodi.tv/showthread.php?tid=220753
Regards,
Bart
Not sure about this one
I do not really like adding things that rely on addons
I'll think about it though.
(2015-07-20, 14:10)UsefulG Wrote: [ -> ]@Mikesilvo164
If you looking for stuff to do, is it possible you could add the Kodiflix view from the Madnox mod into your mod. I have hacked it into my local copy but it has none of the configurability of the original but it looks good.
There are a lot of variables that are checked and set in the Madnox skin which obviously aren't in your mod and I don't know how to set them, as I say it was 'hacked' in.
At the risk of telling the master what to do the steps I did were;
It needs
1) Some graphics from Madnox media folder views/kodiflix
2) Amends to the MyVideoNav.xml to add the view
3) Added the additional Kodilflix variables into Variables.xml
4) Amended the View_800_Kodiflix.xml to remove the variables checking to make things visible.
I had to disable fanart globally to hide the fanart in the view or it appears in the background, if I knew how to disable fanart per view it would be awesome.
I'm quite proud of my hacking so here is my version of kodiflix in your skin.
Kodiflix Silvo
Not a bad hacking job
looks pretty good. Here is my WIP view so far
Anybody have any suggestions?
I still have to add cases and a couple of other surprises
I would post it for testing but there is a major issue that I am having trouble solving
(2015-07-20, 17:10)bsoriano Wrote: [ -> ]Good morning Mike,
Would you be willing to look at BigNoids master branch of Nox 5, which is being dveloped for Kodi 16 already, and do something similar (perhaps in a new branch) for Nox Silvo? Two reasons for my asking:
1. As of today, the Kodi nightlies are based on Kodi 16, not Isengard.
2. In my testing of Nox Silvo with Kodi 16, there is a problem with side menus (like when you want to change viewtype options), in which the keyboard becomes unresponsive and some of the menu remains on the screen even after you leave the menu. Latest Nox 5 from GitHub does not exhibit this issue.
Thank you for considering my request.
Regards,
Bart
Not yet working on updating for Kodi v16 yet but I will start soonish.
(2015-07-20, 21:35)AshG Wrote: [ -> ]Mike - not something I have asked before, but the live TV could do with a bit of love....
1. When pressing record in EPG, the record icon appears at the top of the programme title and pushes the text down. In my opinion the red dot should be aligned to the left at the start of the text.
2 . In the channel list view, on the right hand side at the bottom you have the what's next and then the description of the programme that's on now. Again in my opinion this should be swapped around to show the description of now and then the what's on next...
Hope this isn't too vaige, doing this from memory as on my hols at the moment....
Live TV is on hold for a little while. Hopefully if Maniac has any available time to assist with updating to his current mod it can happen sooner rather than later but he is busy with other things so please, and this goes to everyone, do not bug him about it.
(2015-07-21, 05:53)meesham Wrote: [ -> ]Hi Mike,
I know your preference for the "paused" screen is for it to be uncluttered, but would it be much work to add an option to show the info screen (with the time remaining text) displayed when the video is paused?
I will think it over... but if you want, I can tell you what to add so you can mod it in yourself.
(2015-07-21, 10:57)Dave the Minion Wrote: [ -> ]Hi all. I just added this mod to my Aeon Nox 5.0 for the showcase view, which is pretty awesome, but found an issue. When you scroll through pages it only move 6 movies to the left or right, not a full page like all other views do. Is this a glitch or something that can be changed?
I looked into this and have no idea how to change that
(2015-07-22, 01:00)lozad Wrote: [ -> ]Thanks again silvo, your mods are incredible!
You're welcome
(2015-07-22, 05:54)marhutchy Wrote: [ -> ]Nothing happens when I click the shortcut i or click TV show information for TV shows, but it shows the info for movies.
Hmmm... can not replicate. Can you try updating ExtendedInfo from GitHub and if that does not work try opening the info for TV shows after enabling debug logging (please restart after enabling) then provide the link to the
Debug Log (wiki)
Hi Mike, hope you had a good vacation mate.
What's you kodiflix issue you have? and yes I know the code is a mess but it's me so! I have another update of it in the works but with things you probably don't want ;-)
(2015-07-22, 09:35)Mike_Doc Wrote: [ -> ]Hi Mike, hope you had a good vacation mate.
I actually did not use a single line of code from MadNox. I was trying to learn some of the new param and constant stuff and I learn by modding things to see how it all works so I completely redid phil65s showcasemovies.xml and the container.onnext and container.onprevious control groups are working right but the animations are jerky and I believe it has to do with the stationary group that is visible when not scrolling.... I did not want to use a traditional item and focused layout because I want to include window property stuff. I have been working on the issue for over 6 hours and nothing I've tried works... I may have to post and ask for assistance in the skinning forum
Well done for nextflix view mikesilvo.
We can use it for tv shows too or only movies ?
(2015-07-22, 10:05)wilmans2m Wrote: [ -> ]Well done for nextflix view mikesilvo.
If I can get the darn thing to work right. I'll make it for a a few different mediatypes
@mikesilvo164
Thanks for your kind words about my hacked view, I'm really standing on the shoulders of giants but I'm happy with it for now.
When you get it working (which I'm sure you will) can you add the option to choose between Poster art and landscape thumbs in TV Show Episode view?
I'm currently running Helix on my main box which I used for the hacked view but I have a second box running Isengard so I can test stuff as best I can if it helps.
I found a little thing ! (text overlapping)
It only happens with long movie titles which was in the imdb top 250 !!!
(2015-07-22, 07:36)mikesilvo164 Wrote: [ -> ] (2015-07-22, 05:54)marhutchy Wrote: [ -> ]Nothing happens when I click the shortcut i or click TV show information for TV shows, but it shows the info for movies.
Hmmm... can not replicate. Can you try updating ExtendedInfo from GitHub and if that does not work try opening the info for TV shows after enabling debug logging (please restart after enabling) then provide the link to the Debug Log (wiki)
Here's the
log.
Something comes up, but it must be invisible. When I clicked
i, everything froze. Nothing was moving when I pressed the direction keys, but started moving again when I pressed escape.
Something's there, but it's not visible.
(2015-07-22, 12:40)UsefulG Wrote: [ -> ]@mikesilvo164
I will go option crazy and add all sorts of stuff
Won't be for Helix though.
(2015-07-22, 19:07)Mario S. Wrote: [ -> ]I found a little thing ! (text overlapping)
What do you think, shorten the length or move up the mediaflags and lower the director and rating?
(2015-07-23, 00:51)JoeBlow42069 Wrote: [ -> ]Is there a way to turn off cases, and remove the poster art from the lowlist movie set view?
Something is not right with that image... You have the old cases but the new live background for sets... try reinstalling the skin and check your addons folder for more than one silvo skin folder.
Since Isengard is now released as stable I will start to push updates to the repo in the coming days. Releases will not be as frequent as I update the skin. GitHub will always have the latest.
I think shorten the lenght!!!
Not sure if this is the right place to ask. But I was trying the Aeon Nox Silvo h24 Glowbars Skin and it's really hard to see anything in the progress bar. The color of the bar makes it almost impossible to see.
Is there any way I could change that within the aeon Nox plugin.
