Thanks mikesilvo164,
Feel like a complete idiot but then again fantastic.....
While waiting for an answer , downloaded Aeon Nox 6 - which i like but from the main menu > movies > shows recent movies tag but the ( movies in progress tag is not there ).
Any way of including that tag ?
Thanks again.
(2015-08-08, 12:36)kdeuser Wrote: [ -> ]Thanks mikesilvo164,
Thanks again.
There is no Aeon Nox 6 yet... If you are talking about Aeon MQ 6 then that is a different skin and questions regarding that should be asked in that particular subforum. I have no idea about MQ, I myself have never used it.
Update to MyFlix view available on git. Can now be used for Sets, TV Shows, and Episodes.
To those interested, please test it out and let me know if it all works right and what options you think I should add
Hello. I love this skin but can't see the Manage Submenu when I'm trying to customize my main screen. I checked on the forum and noticed some people also having the missing Manage Submenu but I can't find a fix. Has anyone gotten this to show up?
(2015-08-08, 18:37)fernicus Wrote: [ -> ]Hello. I love this skin but can't see the Manage Submenu when I'm trying to customize my main screen. I checked on the forum and noticed some people also having the missing Manage Submenu but I can't find a fix. Has anyone gotten this to show up?
Sounds like you are missing one of the required scripts (script.skinshortcuts) and that usually happens if you manually installed the skin. The easiest thing to do would be to install Aeon Nox 5 from the Kodi repo since that should auto install all the required scripts or you can and should install all the scripts mentioned in the first post of this thread, both required and recommended, to get most of the skin functions.
(2015-08-04, 07:48)Warner306 Wrote: [ -> ]....
(2015-08-08, 18:49)mikesilvo164 Wrote: [ -> ]....
I just tried fetching updates from github, but got an error. On who's end is this?
EDIT:
Weird - I tried again, but this time it fetch, merged and pushed smoothly.
@MikeSilvo164
Try latest github
Thanks for this myflix view on tv shows
Works great on my laptop
(ATM)
@MikeSilvo164
I definitively adopted the fly view on tv shows
BUT
1/ Is it possible to display rating next to "genre" or below on the main tv show screen ?
2/ i have a bug with infos displayed for the shows (
http://i.imgur.com/VwOuv7R.png) and here (
http://i.imgur.com/JDb4UcV.png). Problems with rating. Nfo is correct (using french rating ofc. Maybe some adjustements on the code to display correctly french one.)
Thanks for all
(2015-08-09, 16:29)wilmans2m Wrote: [ -> ]@MikeSilvo164
BUT
2/ i have a bug with infos displayed for the shows (http://i.imgur.com/VwOuv7R.png) and here (http://i.imgur.com/JDb4UcV.png). Problems with rating. Nfo is correct (using french rating ofc. Maybe some adjustements on the code to display correctly french one.)
Thanks for all
I do not know what I am looking at with your photos... The pictures do not look right... I do not understand how you do not have simple things like audio codec... The info that appears is from what is scraped + what is provided by the TV Show Next Aired script so if you are missing things then you need to find out what info your system has and is not displaying.
I really need to see the NFO files and folder structure cause I have no idea how you have an overlapping textbox since that is supposed to change by the media type...
So much wrong with your photos
P.S.
If you are using Banned add-ons (wiki) then I will not be wasting my time troubleshooting this. If anybody wants free shit they can do the work to display it correctly, I myself have better things to do...
If you are not then disregard the previous statement.
@mikesilvo164
Thanks for the answers.
About the 2nd picture : Just to show you that rating is "NR" instead of "-10". "-10" works great for movies but does not work here. (it is not standard one like PG-13....You probably forgot that you had to ajust the code of variables.xml to display correctly french rating.
About first picture : Just to show you that some informations collapse together. Here is the nfo about dragon ball kai :
http://pastebin.com/CCRFT6a1
Hope it will helps. But about the Not Rated problem i am sure that it is just a problem with the code; I mean i suppose you just don't implement french code.
But only you know
And i don't have any banned add-ons. I opened your link but i don't have any of the addon mentionned.
Thanks. This flix view is really good
(2015-08-09, 18:32)wilmans2m Wrote: [ -> ]@mikesilvo164
About first picture : Just to show you that some informations collapse together. Here is the nfo about dragon ball kai : http://pastebin.com/CCRFT6a1
But only you know
I was not accusing you just explaining how much I hate them and do not wish to deal with issues from someone using them. I apologize if it was offending in any way.
If you can post a listing of all or at least the most common french TV ratings I can add them if I have the images available in the skin. You are most likely correct about missing french TV ratings.
Hmmm... The overlapping title... I do not see a tvshow title in the NFO maybe that is the problem
This particular issue has me stumped at the moment... It should not be displaying the episode title and the show title at the same time... Can you please try removing the show and re-adding it without using the nfo to see if the cause is the nfo itself and not the code?
Thanks mike. Will try this way. I do not use kodi anymore to add my files but...no choice here. Will do it.
About french rating, i will post you the most used. Thanks to take time to implement it.
Ps : Don't need any apologize, don't worry
no offense.
hi i am using Isengard and copy from github master , problem is i have no media flags at the bottom of movies any advice would be great thanks
[/img]
Mike, test done.
Here is the result :
http://i.imgur.com/TDLg16g.png
As you will see, rating appears (US), audio codec too. But titles always collapse. And if you see next to "time", info box collapses too.
Integration made with kodi & the tv db.
Thanks again for all
