@MikeSilvo164
I wonder if it's possible to add some info in the myflix view for tvshows.
When we navigate on a show, we can't see the status watched or not and the season/episode number. Is it possible to add those infos somewhere ?
(2015-08-10, 19:02)Alyy Wrote: [ -> ]I haven't managed to solve my problem of icons ?
Not a skin problem so I can't help you.
(2015-08-11, 13:29)wilmans2m Wrote: [ -> ]@MikeSilvo164
Added to Git
Let me know if you notice anything else missing or have any other suggestions
@Mikesilvo164
Thanks, will try the new git
Did you see my previous post page 158 about mpaa ?
(2015-08-11, 21:00)wilmans2m Wrote: [ -> ]@Mikesilvo164
The code is only where it is cause the images are colored and I do not have them in white. I need to fix them not displaying before I add them elsewhere. Working on it but my time is a bit limited right now. Hopefully not too much longer.
Thanks for the answer. I asked you this as it concerns coloredflag.
About last git, episode number is ok
But miss watch status as for the other views (episodes, rightlist...) => i don't see it.
Anyway. Big thanks
(2015-08-11, 21:15)mikesilvo164 Wrote: [ -> ] (2015-08-11, 21:00)wilmans2m Wrote: [ -> ]@Mikesilvo164
I think I found the problem... your nfo is using "Interdit au moins de 10 ans"
But the code says "Interdit aux moins de 10 ans"
(2015-08-11, 21:28)wilmans2m Wrote: [ -> ]Thanks for the answer. I asked you this as it concerns coloredflag.
About last git, episode number is ok ))
Anyway. Big thanks
I had a feeling this might be a thing... Here is my dilemma... The views you mention are all lists and using that box and checkmark wouldn't look right so I added the watched flags but you need to turn them on in skin settings > advanced > watched status indicator.
(2015-08-11, 21:29)mikesilvo164 Wrote: [ -> ] (2015-08-11, 21:15)mikesilvo164 Wrote: [ -> ] (2015-08-11, 21:00)wilmans2m Wrote: [ -> ]@Mikesilvo164
OMG !!!!! tested and....works. Sorry for this lost time.
(2015-08-11, 21:35)wilmans2m Wrote: [ -> ]OMG !!!!! tested and....works. Sorry for this lost time.
No problem... Its funny cause I copied the mpaa from the nfo when I tested it myself and I just didn't think to check it for a missing letter or anything
I Will try the option for watch flag tomorrow. Thanks.
Decided to make a change to the flags and add some additional ones like Season, Episode, and Unwatched count for TV Shows. Will most likely add a toggle to turn them off/on. Thoughts?
watch gallery
Personally I would rather see the TV season(s?) / episode(s?) / unwatched in the place of "Status". I think it's more important.Just my opinion
(2015-08-11, 23:28)martinconroy Wrote: [ -> ]Personally I would rather see the TV season(s?) / episode(s?) / unwatched in the place of "Status". I think it's more important.Just my opinion
So you do not like the items on the bottom in the pics showing season, episode, unwatched?
I just think of the flags as depicting "extra" information, typically technical e.g. resolution/audio whereas the "core" info e.g. descriptions are at the top. I would consider this type of info more "core" personally.
@mikesilvo164
try last version & i love it. Watch flag on fanart on flix view & season/episode number, all is good.
Big thanks.
