(2015-08-20, 01:01)wilmans2m Wrote: [ -> ]Mikesilvo do not forget as soon as you have finished, to message me to translate to French Thanks.
Did not forget, will not forget
hopefully
I am almost finished adding the things I have been working on and once that is done I will feature freeze and alter some labels for consistency while adding the missing ones to the strings file. Once I've completed that I will PM you and probably Mario (unless he does not want me to
) and have him update the German ones as well.
Not too much longer to wait... A week tops. Might even be tomorrow... It all depends on the, currently random, free time I have available.
Why every time i i start Kodi using Aeon Nox Silvo i got a empty background with the menu, but when i click to any addon in the menu then i exit that addon o program i can see the imagen in the background.
Thank you
(2015-08-20, 20:20)REralte Wrote: [ -> ]Where it can be download it
It is available now on the Git version of the skin.
Link in the first post and to all interested parties make sure to check the README underneath the GitHub link.
Hello,
Not sure if this is in the latest build but could I please ask for a option, so when you pause a movie the movie info is also displayed.
Thank You
Hello Mike,
Does the mr v widgets v2 branch have changes for Kodi Jarvis? If not, would you consider making a Jarvis branch with the mr v widgets v2? Thank you for considering my request.
Regards,
Bart
(2015-08-21, 03:40)REralte Wrote: [ -> ] (2015-08-21, 03:13)mikesilvo164 Wrote: [ -> ] (2015-08-20, 20:20)REralte Wrote: [ -> ]Where it can be download it
Thank you
I download the Git and install it but continuing look the same do i change it
Still the best Skin/mod out there. Thanks Silvo!
Maybe someone can answer a question for me?
Using 15.1 Direct X11 Kodi, and whatever version of Silvo's skin I got from the link on the first page... I use the Gallery view for movie sets, I could swear that on the Helix version of the skin there was a way to add a Movie Set Logo to the set, and it would show up superimposed over the fanart on the Gallery view... I found the ability to change movie set poster and fanart, but last night I couldn't figure out how to add that damn logo -it looked cool before!
Any help would be appreciated!
(2015-08-21, 11:06)mamekid Wrote: [ -> ]Hello,
Thank You
I will not add anything to the pause screen. This is by design for a few reasons. Just press info while paused and all the options you have activated in the settings will be there. It is just one extra press of a button to get the info and images displayed while paused.
(2015-08-21, 13:18)bsoriano Wrote: [ -> ]Hello Mike,
Regards,
Bart
Might work. Try it. Let me know
I have made the fix for the side menus not working available on all branches except helix since that version is no longer being updated.
(2015-08-21, 14:41)REralte Wrote: [ -> ]I download the Git and install it but continuing look the same do i change it
You have to activate the alternate layout in the music OSD settings
This post will show you how to access those settings.
(2015-08-21, 16:10)jaydash Wrote: [ -> ]Still the best Skin/mod out there. Thanks Silvo!
Logos for movie sets are not natively supported so you either have to manually add them, use
Movie Set Artwork Automator or if you do not mind using command line the
Texturecache Maintenance Utility
(2015-08-21, 16:16)mikesilvo164 Wrote: [ -> ] (2015-08-21, 11:06)mamekid Wrote: [ -> ]Hello,
Thank You
Regards,
Bart
Thanks! I will try it tonight
Regards,
Bart
