Hello everyone!
I have a problem with intro movie.
I changed the home.xml to start intromovie but I have the top menu bar and the time bar that appear.
I read that Xero has the same problem. (mp4 or mkv same problem)
link where i download the intro movie:
http://forum.kodi.tv/showthread.php?tid=209673&page=19
I use kodi Isengard with aeon nox silvo on windows 7.
thank for your help
I couldn't see the watched indicator too in landscape view and hadn't the overlay option in settings since I updated to 5.7.3-2.0.6.
I had set: Skin settings > Advanced > Watched status indicators
I've updated to the newest version from github today - it didn't work.
What I've figured out is that you have to change in guisettings.xml the line from:
<setting type="string" name="skin.aeon.nox.silvo.Overlay.Toggle"></setting>
to:
<setting type="string" name="skin.aeon.nox.silvo.Overlay.Toggle">2</setting>
Of course you can always delete the guisettings.xml file and setup from the scratch what is a good choice if you have upgraded from helix. Many settings have changed.
(2015-08-28, 22:22)boubou06 Wrote: [ -> ]Hello everyone!
link where i download the intro movie: http://forum.kodi.tv/showthread.php?tid=209673&page=19
thank for your help
Post the code you used to add it. Also post the intro you are using. The topbar should not appear since it is not available on the home menu...
(2015-08-28, 22:23)roger7 Wrote: [ -> ]I couldn't see the watched indicator too in landscape view and hadn't the overlay option in settings since I updated to 5.7.3-2.0.6.
to:
Changing that manually should not make overlays appear for landscape. I just tested everything again and it all works with the latest from Git. Not sure what problem you guys seem to be having but changing that setting will only work for some views and others need to be activated using the skin settings and then enabled in the view settings sidemenu. If you or anyone else is having issues with overlays post a
debug Log (wiki) and your complete 1080i folder for me to look at.
Also what os and Kodi version you have so we can see if it is os specific or a Kodi bug.
<onload condition="Window.Previous(startup)">PlayMedia(special://skin/skinextras/intromovie.mp4)</onload>
I use your code. i delete only comments tag.
I think I found why the overlay setting in the side menu might not be appearing in certain situations...
Official Kodi 15.1, Windows 7 SP1.
I couldn't see the watched indicator in landscape view and hadn't the overlay option in settings since I updated to 5.7.3-2.0.6.
But I could see the indicator in Panel or Icons view.
Changing guisettings.xml the line to
I could see overlay option after changing it, and then setting the overlay to enabled finally the watched indicator is visible.
(2015-08-29, 00:01)roger7 Wrote: [ -> ]Official Kodi 15.1, Windows 7 SP1.
That makes more sense
I will have a fix soon for the option not appearing, I am missing some conditions.
I haven't been testing as well as I should have.
(2015-08-28, 23:56)boubou06 Wrote: [ -> ]<onload condition="Window.Previous(startup)">PlayMedia(special://skin/skinextras/intromovie.mp4)</onload>
Debug Log (wiki) please. A link to the intro you are using might also be helpful...
(2015-08-29, 00:05)mikesilvo164 Wrote: [ -> ] (2015-08-29, 00:01)roger7 Wrote: [ -> ]Official Kodi 15.1, Windows 7 SP1.
And as I've written in the first post there is no problem when you delete guisettings.xml and setup from the scratch - overlay option is visible.
So I think it is the problem only when you upgrade from earlier version of your skin.
BTW: great work!
For Showcase view in tv shows sets (seasons) overlay option is visible (with no value set) but you can't change it to enabled or disabled. So watched indicator is not visible.
But it works for showcase in movie and tv shows.
Is there an option to show time remaining instead of time duration on the video player OSD ? I have looked but cant find anything. Or is there way to setup an advanced settings file to have it ?
