(2015-09-30, 01:56)Warner306 Wrote: [ -> ]@mike,
Are you interested in adding the mod below? I am removing my existing links for v16 and noticed you didn't have the following feature:
I've got it started in the attached files. What's missing is compatibility with the Logo toggle and a need to fix the list to be in the low position (it doesn't work without the poster in the lowered position).
The labels on the right side could also be adjusted.
Here are the files: https://drive.google.com/file/d/0B2LAr9I...sp=sharing.
Just finished this, if you want to test it out the link is below. Not sure what you mean by the labels on the right could be adjusted
LINK
If you think it is ready I will push it to Git
mike, one of your recent updates gave me a bit of a headache.
I updated via fetching your update.
I realized that you made quite a few changes. I had to re-add all my shortcuts and re-order my homescreen.
Anyone know how to get the Disc Art to show-up , my library is on a separate hard drive and all artwork is in the movie folder , i can see the option fake disc art - but i dont see my disc art , i have the default blue disc that floats on the screen , nothing shows up on info panel either , ive added art work in info to that doesnt work , im using the github version Aeon-Nox-SiLVO-isengard , so can anyone tell me what im doing wrong
(2015-10-03, 17:25)no-spam Wrote: [ -> ]Anyone know how to get the Disc Art to show-up , my library is on a separate hard drive and all artwork is in the movie folder , i can see the option fake disc art - but i dont see my disc art , i have the default blue disc that floats on the screen , nothing shows up on info panel either , ive added art work in info to that doesnt work , im using the github version Aeon-Nox-SiLVO-isengard , so can anyone tell me what im doing wrong
You have to use Artwork Downloader to get additional artworks to show up in your library.
Additional artworks are logo, clearart, character, disc, etc.
(2015-10-03, 20:11)marhutchy Wrote: [ -> ] (2015-10-03, 17:25)no-spam Wrote: [ -> ]Anyone know how to get the Disc Art to show-up , my library is on a separate hard drive and all artwork is in the movie folder , i can see the option fake disc art - but i dont see my disc art , i have the default blue disc that floats on the screen , nothing shows up on info panel either , ive added art work in info to that doesnt work , im using the github version Aeon-Nox-SiLVO-isengard , so can anyone tell me what im doing wrong
ive been using media companion for ease and it downloads the artwork -fanart - poster -disc art etc into the movie folder i working with at the time and just using nfo file
Mike,
Thanks for making this great skin mod. The one thing I miss from Aeon Nox 4 is the ability to hide the navigation buttons on the video OSD. Is it possible to add this to your skin? Example pics from Nox 4:
(2015-10-03, 20:35)no-spam Wrote: [ -> ] (2015-10-03, 20:11)marhutchy Wrote: [ -> ] (2015-10-03, 17:25)no-spam Wrote: [ -> ]Anyone know how to get the Disc Art to show-up , my library is on a separate hard drive and all artwork is in the movie folder , i can see the option fake disc art - but i dont see my disc art , i have the default blue disc that floats on the screen , nothing shows up on info panel either , ive added art work in info to that doesnt work , im using the github version Aeon-Nox-SiLVO-isengard , so can anyone tell me what im doing wrong
nevermind thanks , i just realised you can configure artwork downloader to look for nfo's for artwork .. ive been out of the loop for sometime , i havent used kodi since it was xbmc , i havent gone this far in adding things and for about 1yr so im abit rusty .. lol
thanks
(2015-10-03, 04:35)mikesilvo164 Wrote: [ -> ] (2015-10-03, 00:46)BobCratchett Wrote: [ -> ]As one of the contributors of the Skin Shortcuts script, I'm torn on this one myself. Balancing between being able to recreate any menu item that you delete, versus being able to hide an unused menu item (though if you don't have a PVR backend, most skins will hide the PVR menu's anyway, so they can just be ignored) is not easy.
If it's something anyone feels strongly about, feel free to post it as a feature request in the Skin Shortcuts thread in the Skinning forum. In terms of coding it, though, it's not an easy one as it would either require every skin using Skin Shortcuts to incorporate an additional GUI button to enable/disable any given shortcut, or would mean that you could disable a shortcut on a skin that supports it, but not be able to re-enable it if you switched to a skin that didn't support it....
I did have a thought, hopefully not a terrible one , since adding an additional required button seems like the wrong way to go...
What about adding an additional option to RunScript(script.skinshortcuts,type=resetall) to show a list of defaults?
Something like Restore All, Restore Single, Exit instead of just Yes/No. Then one could add back a deleted default menu item or restore it to it's defaults if it was modified. Perhaps make it an optional thing to enable in overrides.xml or even a new RunScript call
If something like the original request was to be implemented, I wonder if (though it's beyond my skill to do it right now, so not something that would be implemented quickly!) a context menu item would be the way to go.
I like the idea of an option to restore a shortcut that has been deleted, though I dread to think of the code changes needed to implement it! It's certainly something I'll look into when I have the time, and the feature request is now on the radar
(It also might satisfy, though not in the way requested,
issue 75...)
Thanks for the ideas
(2015-10-03, 16:22)marhutchy Wrote: [ -> ]@mike, one of your recent updates gave me a bit of a headache.
Yeah... Nothing can be done about that. That is why I added a warning to the changelog so you could choose not to update if you did not want to setup the main menu again. For future reference using GitHub versions of the skin could potentially have broken settings, menus, or other things due to changes. They are for development and testing. That being said... I have a feeling more will complain about the same thing when I push the update to the repo
Can't make an omelet without breaking some eggs
(2015-10-03, 20:41)hugepants Wrote: [ -> ]Mike,
Seems like a simple request so... sure, I'll add it when I can as long as it doesn't break something that I'd rather not spend time fixing
(2015-10-03, 07:42)mikesilvo164 Wrote: [ -> ] (2015-09-30, 01:56)Warner306 Wrote: [ -> ]@mike,
LINK
I prefer the animation when it starts hidden behind the poster, but it is up to you.
I couldn't find anything wrong with any of the view settings.
(2015-10-04, 07:43)Warner306 Wrote: [ -> ]I prefer the animation when it starts hidden behind the poster, but it is up to you.
I understand...
The reason for my choice is the IconCrossFadeTime looks really good while also being fast when scrolling through the library. I wanted to work around this so IMHO not seeing the discart briefly when scrolling seemed silly in comparison to any additions that I needed to add in order to hide this extraneous animation...
In order for the sliding disc animation to be added to all LowList choices including position (high or low) that needed to be considered.
I cannot realistically add everything, that is why I said it will most likely not be the same
(2015-08-28, 22:22)boubou06 Wrote: [ -> ]Hello everyone!
I have a problem with intro movie.
I changed the home.xml to start intromovie but I have the top menu bar and the time bar that appear.
I read that Xero has the same problem. (mp4 or mkv same problem)
link where i download the intro movie: http://forum.kodi.tv/showthread.php?tid=209673&page=19
I use kodi Isengard with aeon nox silvo on windows 7.
thank for your help
Hi , dont know if u fixed this , but i did it like this :
I disabled mouse support in kodi settings and added this to Startup.xml:
<onload>PlayMedia(special://skin/skinextras/intromovie.mp4)</onload>
This shows me the intromovie without player controls
(2015-10-04, 02:56)mikesilvo164 Wrote: [ -> ] (2015-10-03, 16:22)marhutchy Wrote: [ -> ]@mike, one of your recent updates gave me a bit of a headache.
That is so true, but I believe your Isengard branch isn't for testing. That's the branch I only fetch updates from.
Am I right?
(2015-09-30, 10:14)mikesilvo164 Wrote: [ -> ] (2015-09-30, 03:02)nwilloughby Wrote: [ -> ]I have this skin installed and love everything about it but for some reason under skin settings manage sub menu this panel is showing up with no background and is clear. Anyone have any idea what could be causing this is there a specific xml file for this portion of the skin?
Sounds like an OpenElec issue that has been fixed with a recent update... are you using OpenElec?
I am running the latest OpenELEC 5.95.4 it still has this clear problem, the only way I can get rid of it is to go back to Helix build and start fresh, a fresh install of Isengard and the skin does not solve this issue. Can you share if there is a specific xml that controls this specific panel under skin setting sub menu.
