(2015-10-17, 16:20)mikesilvo164 Wrote: [ -> ]Still? Has it always done that? Either way, I will take a look soon and fix it it
Yep, it's always been like that for me, but it could be that I was missing some file. I downloaded the latest from github (isengard) yesterday however and it was like the screenshot shows. Thank you mike.
(2015-10-13, 23:05)Mario S. Wrote: [ -> ]Or use Icons!!
I like it
The only question is what style of icons to use?
(2015-10-17, 22:17)Mario S. Wrote: [ -> ] animated gif poster works on jarvis nightlies
Openelec Builds from Milhouse !! thx for the builds
Link: http://forum.kodi.tv/showthread.php?tid=238393
can I ask where you get the gifs from please?
Thank You
Calisto
I can Upload a pack of gifs later Today if you wish
(2015-10-18, 07:26)Mr. V Wrote: [ -> ] (2015-10-13, 23:05)Mario S. Wrote: [ -> ]Or use Icons!!
I like it
I like the ones from iconmonstr.com
(2015-10-18, 16:39)rudrood Wrote: [ -> ]I like the ones from iconmonstr.com
Quick look of the license seems they can be used for free... will look into using them if applicable. Thank you for the suggestion
I just pushed a fix for the MyFlix background.
Also for those that asked... you can now select "replace choose art button" for the location of the trailer button when you have chosen the default placement for the CinemaVision button (setting is in video info section of the skin settings).
Just did some quick testing so hopefully it all works
Wow, cool, thanks a lot for the quick coding. Will test the "choose art" replacement as soon as I can.
(2015-10-19, 21:31)Mario S. Wrote: [ -> ]Hy Mike i found two little things !!!
I do not know how to solve the first issue. My guess is that the second half of the variable is lost when opening the textbox viewer but I have seen the same disappearing issues when using a variable for the source flag and any dialog opens so unless I can think of something it will have to be one of those quirks. If anybody has a suggestion
Second issue looks like a missing entry in the string file... will check and fix if it is missing or mislabeled.
I think Mr.V has nailed the design for the Vertical Menu so I feel the need to show off how it currently looks
watch gallery
