hello congratulations for your skin, I have a problem with extended-info script,
I can not find it in kody addon repo, i see it only if first manually install the version found on github
and reboot the system, however, 'if I update via kody repo addon i have a error: dependencies no met, plugin incompatible please contact the author.....
how resolve this? my system run openelec 5.0 on kody helix and aeon nox 5 mikesilvo 164
sorry for my english
saluti from sardinia island
(2015-01-20, 21:19)mastervan Wrote: [ -> ]hello congratulations for your skin, I have a problem with extended-info script,
I have had some time to think about this since your first post and I think if you download extended info from
here it should work if you install from zip from the addon manager since you are most likely missing the required dependencies that install automatically. They do not get installed automatically if you extract the files manually and copy them to the addon folder. Also just to be thorough if it still does not work delete all script.extendedinfo folders in addons folder as well as the scripts addon_data folder located in your
userdata folder and try installing the zip through the addon manager again.
(2015-01-20, 17:50)mikesilvo164 Wrote: [ -> ]I think they all look great... one suggestion though. The colored Yahoo! one may look better if the words are instead of white on purple background just purple words and no background The naming convention for the channels to match are correct if I remove colored from the filename?
No, I didn't pay any attention to the naming conventions when I named the files (you're referring to the network names on TVDB, right?). The actual TVDB network names of the shows in my collection that are missing logos are:
Yahoo! Screen
TV Asahi
MNN
YTV
As for the coloured Yahoo logo: hmmm. Can we try it as is first, and if it really looks crummy, I can redo it? It's just that it's tricky to find a good logo for that channel, so I'd have to do a fair bit of amateurish photoshop hacking to get it to be just purple words and no background.
(2015-01-20, 22:28)canadave Wrote: [ -> ] (2015-01-20, 17:50)mikesilvo164 Wrote: [ -> ]I think they all look great... one suggestion though. The colored Yahoo! one may look better if the words are instead of white on purple background just purple words and no background The naming convention for the channels to match are correct if I remove colored from the filename?
Yahoo! Screen
TV Asahi
MNN
YTV
I will add the logos to Git soon. I am not adding anything until I push the update today as I want to fix any noticed bugs before I add anything else. Just waiting for any last minute bug reports. I will post a new zip tomorrow with the added logos for you to see how it looks if you'd like.
I have pushed the next update to the repo. I have also updated the link in the first post.
Changelog
Hey just wondering if with the new coloured media and flag info if I should place mine somewhere else besides the media folder. I had them in a flags folder there I created. However, they stopped working when I toggled the colour option on.
(2015-01-21, 04:50)wordguy Wrote: [ -> ]Hey just wondering if with the new coloured media and flag info if I should place mine somewhere else besides the media folder. I had them in a flags folder there I created. However, they stopped working when I toggled the colour option on.
The icons for the colored mod are in the skin so no need to add or remove folders. If something is not working please reinstall the latest version.
(2015-01-20, 18:13)mikesilvo164 Wrote: [ -> ] (2015-01-20, 15:32)devilshura Wrote: [ -> ]This may be a bug in music visualization.
I can't replicate that... I have never had an issue when changing tracks. Does it happen often or just on rare occasions?
Try replacing this file in skins 1080i folder
That is ok when i update to the new from repo, may br i miss something when moding font for my local use.
(2015-01-20, 21:31)mikesilvo164 Wrote: [ -> ] (2015-01-20, 21:19)mastervan Wrote: [ -> ]hello congratulations for your skin, I have a problem with extended-info script,
I have had some time to think about this since your first post and I think if you download extended info from here it should work if you install from zip from the addon manager since you are most likely missing the required dependencies that install automatically. They do not get installed automatically if you extract the files manually and copy them to the addon folder. Also just to be thorough if it still does not work delete all script.extendedinfo folders in addons folder as well as the scripts addon_data folder located in your userdata folder and try installing the zip through the addon manager again.
ok
solved!!! delete all extendedinfo folder and installed from zip.. thank you for support saluti
I'd much prefer for the colour to be customizable rather than forcing someone's preferences on everyone who uses the skin...
(2015-01-21, 20:33)splice42 Wrote: [ -> ]I'd much prefer for the colour to be customizable rather than forcing someone's preferences on everyone who uses the skin...
The colour is customizable in the Helix Nox from the kodi repo.... you can choose red, blu and orange.....
(2015-01-21, 20:37)Warez Wrote: [ -> ] (2015-01-21, 20:33)splice42 Wrote: [ -> ]I'd much prefer for the colour to be customizable rather than forcing someone's preferences on everyone who uses the skin...
It is definitely not in the Kodi repo version. That is either a personal mod or a different skin mod.
Aeon Nox 5.5.6 Redux... and its in the Kodi Repo Helix 14 Openelec
