Hey Mike a quick question.
I guess I'm "that guy" but I'm running your latest push and I'd like to know how I can bring back the "choose art" button. Perhaps I missed a setting or something but IIRC I use to have an option to choose art right next to the reload button. I assume per requests above I now have a trailers button (which I never use) and a reload button. The thing is I sometimes need to organize my artwork for my devices and I'm at a loss as to how to do that now without a dedicated "art" button.
I don't even need the button per se. If there was some way to include a 'choose art' option in the extended dialogue menu, perhaps under Artwork Downloader that'd be fine with me.
Also since I'm here, I hate menu clutter. I have the trakt addon installed and one of the items that it adds to the extended dialogue menu is a "rate on trakt" that I never use and bugs the 'ell out of me. Would you be so kind as to tell me how I could get rid of that menu item.
Again, thanks for all the fine work you've done with the skin.
(2015-10-22, 03:21)smw6230 Wrote: [ -> ]Hey Mike a quick question.
If by "that guy" you mean an "Awesome Person who posts bug reports" then yes, you're "that guy"
I am guessing that you do not have the CinemaVision addon installed? Just pushed a change and I think you should be good to go now with latest Git. If not let me know.
Thanks for Reporting the Issue!
To remove the button delete:
<control type="button" id="90202">
<description>Trakt Rate button</description>
<width>510</width>
<textwidth>435</textwidth>
<textoffsetx>45</textoffsetx>
<texturefocus border="35,2,35,2">button_shutdown_focus.png</texturefocus>
<texturenofocus border="35,2,35,2">button_shutdown_nofocus.png</texturenofocus>
<onclick>Dialog.Close(1119)</onclick>
<onclick>Dialog.Close(MovieInformation)</onclick>
<onclick>RunScript(script.trakt,action=rate)</onclick>
<label>$LOCALIZE[31970]</label>
<visible>System.HasAddon(script.trakt) + [Container.Content(movies) | Container.Content(tvshows) | Container.Content(seasons) | Container.Content(episodes)]</visible>
</control>
from custom_1119_ExtrasDialog.xml
(2015-10-22, 05:22)mikesilvo164 Wrote: [ -> ]If by "that guy" you mean an "Awesome Person who posts bug reports" then yes, you're "that guy"
<width>510</width>
</control>
1. Correct, I did not have Cinemavision installed. Installed your latest push and the choose art button reappeared.
2. Edited the ExtrasDialog. xml and that pesky trakt menu item dissapeared.
Thanks so much.
So I'm good to go. Thanks.
One final question about a recently discovered skin oddity that perhaps you can explain, if you know about it.I notice sometimes the movie plot (popup) won't show the complete plot
for items that I have added. Say IMDB's plot for Movie X is a tad weak or doesn't exist at all. I may go to Rotten, find one online, or just use the Wiki synopsis. In those instances I'll paste the plot via the edit button, or in the movie nfo file.
Here's what's weird.
The full plot shows up in the skin itself but whenever I double click on the plot, to get the plot popup, what I'll get is "The Movie begins with Adnan ". That's it. It seems to break at that point. What I have been able to figure out is commas (,) from pasted text seems to break the plot popup. If you remove the commas, then you get the full plot but; for ex "The Movie begins with Adnan Harry and Dave entering a bank".
Its just weird. Hopefully I explained it well enough for you to understand. Perhaps, and I'll start making note of how I enter edited plots (via edit or NFO), pasting them in via the edit button triggers that comma bug. Its probably something like that but honestly I just kinda realized it was the commas causing the plot breaks about an hour ago. Not that I know that I'll make note of how I'm entering them to see which method is causing the break.
(2015-10-22, 06:14)smw6230 Wrote: [ -> ]One final question about a recently discovered skin oddity that perhaps you can explain, if you know about it.I notice sometimes the movie plot (popup) won't show the complete plot for items that I have added. Say IMDB's plot for Movie X is a tad weak or doesn't exist at all. I may go to Rotten, find one online, or just use the Wiki synopsis. In those instances I'll paste the plot via the edit button, or in the movie nfo file.
Try latest Git to see if it is fixed... I noticed some odd inconsistencies with the text viewer popup... I have tried escaping with '" "' and ESCINFO but neither seem to work for all use cases
(2015-10-22, 07:30)mikesilvo164 Wrote: [ -> ] (2015-10-22, 06:14)smw6230 Wrote: [ -> ]One final question about a recently discovered skin oddity that perhaps you can explain, if you know about it.I notice sometimes the movie plot (popup) won't show the complete plot for items that I have added. Say IMDB's plot for Movie X is a tad weak or doesn't exist at all. I may go to Rotten, find one online, or just use the Wiki synopsis. In those instances I'll paste the plot via the edit button, or in the movie nfo file.
Seems to work better, but the behavior is inconsistent. From a quick perusal, some of the ones that had display problems shows up with the full plot. OTOH, some, which may not (didn't note) have had display problems now don't show up at all.
/shrug
You seem to be a perfectionist so I bet this bugs you. I'd just point out that its cosmetic thing that's really not of fundamental importance to the skin. Sure its a nice (cosmetic) feature, but the plot shows up fine in the plot window. That should be good enough for 99.9% of the users. So what I'm saying is no need to devote too much energy to this issue.
I suspect it had something to do with how XBMC/Kodi formats punctuation and other like stuff. I say that because, as I'm sure you know, when I look at a movie's plot in the nfo file a word like "society's" show up in the NFO as society's
Again, you've done such a tremendous job with nuts and bolts of this skins that something like this is of minor importance.
Hey
first of all: Nice Skin! Thank you!
And then I have a question: The "Maniac" TV-Mod is now merged to the official Aeon Nox 5...
And i think, your silvo-skin based on the official one of bignoid, right?
Is there a chance, that the live-tv-mod from maniac will also be in your skin? If yes, when do you want to upgrade your skin?
Thank you very much!
The TV-Mod is already merged in SiLVO. Just use the lastest github version or wait until mikesilvo releases a new version, that you can install from the Kodi-GUI
ok, thanks, perfect
any idea, when a new one will be released?
ok, thanks, perfect
no idea, why it posts the post two times... :/
(2015-10-21, 20:22)mikesilvo164 Wrote: [ -> ] (2015-10-21, 18:21)Alyy Wrote: [ -> ]I change the whole folder, normally I should not have to worry ?
Yet the information is contained in the file guisettings.xml
The whole menu has been redone. Everybody who upgrades will have to re-setup there main menus again. Unfortunately there is no way to avoid it but if you do not want any new skin features you can downgrade to the previous skin version to get your old menus back.
IMHO this should not be an issue. I have had to re-setup my menus countless times during coding/testing... in the end it should be quick and easy while providing much more customization
Ok, If only the menus, it's ok. The parameters have not been affected so ?
I'm installed the last version (github) and in my windows PC it's everything Ok, I do it any mods , colors in cdart and write cd in music and rss with largest fonts, and others things, most friendly for me, well.
That said, in my windows Pc it's ok but in my raspberry with osmc I have many problems, in config menu, I can't put any background, I can't modify the menus.
I think that is a development version, but this it isn't normal, isn't it?
thanks in advance
Ps.- If you want my mod I can send you it
You need the latest skin.shortcuts from its GitHub page...
It seems like this could be a reason I miss my update day target.
I probably shouldn't push a skin update to the repo if the required script version needs to be installed manually from Git.
Mike, I just noticed that this thread now has the most posts of every thread in the Aeon Nox forum, including the official one.
Congratulations to you for an immensely popular and awesome mod, and to Bignoid for his original creation.
Carl.
The option of choice to clearlogo the right, left, center, is blocked.
(2015-10-23, 19:19)Alyy Wrote: [ -> ]Hi,
Probably from the test xml's that did not have the skin string localized.
Exit/Close Kodi
If on
Isengard open
userdata (wiki) guisettings.xml file and search for this line
<setting type="string" name="skin.aeon.nox.silvo.VideoOSDImages">
and delete it.
If on
Jarvis open
userdata (wiki) addon_data\skin.aeon.nox.silvo\settings.xml file and search for this line
<setting id="VideoOSDImages" type="string">
and delete it.
Restart Kodi
