I'm having a strange problem... in my tv show viewtypes, I get no background fanart showing when I select 'FANART' in the 'background' option, but when I select 'FANART' and 'CYCLE FANART', it will show all extrafanarts... The library does have the regular fanart, because other skins show it, and the seies-info screen in Nox shows it...
Any ideas? Thanks!
(2015-10-23, 22:42)mikkelnl Wrote: [ -> ]I'm having a strange problem... in my tv show viewtypes, I get no background fanart showing when I select 'FANART' in the 'background' option, but when I select 'FANART' and 'CYCLE FANART', it will show all extrafanarts... The library does have the regular fanart, because other skins show it, and the seies-info screen in Nox shows it...
Any ideas? Thanks!
Missing script.grab.fanart maybe
(2015-10-23, 21:51)mikesilvo164 Wrote: [ -> ] (2015-10-23, 19:19)Alyy Wrote: [ -> ]Hi,
The option of choice to clearlogo the right, left, center, is blocked.
Probably from the test xml's that did not have the skin string localized.
Exit/Close Kodi
If on Isengard open userdata (wiki) guisettings.xml file and search for this line Code:
<setting type="string" name="skin.aeon.nox.silvo.VideoOSDImages">
and delete it.
If on Jarvis open userdata (wiki) addon_data\skin.aeon.nox.silvo\settings.xml file and search for this line Code:
<setting id="VideoOSDImages" type="string">
and delete it.
Restart Kodi
I have a RPI, I can not turn off kodi and edit the file. If I delete the line with Putty, at startup, it reappears
(2015-10-23, 23:09)mikesilvo164 Wrote: [ -> ] (2015-10-23, 22:42)mikkelnl Wrote: [ -> ]I'm having a strange problem... in my tv show viewtypes, I get no background fanart showing when I select 'FANART' in the 'background' option, but when I select 'FANART' and 'CYCLE FANART', it will show all extrafanarts... The library does have the regular fanart, because other skins show it, and the seies-info screen in Nox shows it...
Any ideas? Thanks!
Nope, it's there
/edit:
Strange thing is: the fanart does show up, when I enter the widgets...!? But it's not showing when browsing through movies or tv shows.
(2015-10-23, 23:26)Alyy Wrote: [ -> ]I have a RPI, I can not turn off kodi and edit the file. If I delete the line with Putty, at startup, it reappears
Try changing it to $LOCALIZE[31220] but Kodi is not an OS so you should be able to exit to Terminal or some kind of Command Prompt.
(2015-10-23, 23:26)mikkelnl Wrote: [ -> ]Nope, it's there
Using an older Git version of the skin?
(2015-10-23, 23:32)mikesilvo164 Wrote: [ -> ] (2015-10-23, 23:26)Alyy Wrote: [ -> ]I have a RPI, I can not turn off kodi and edit the file. If I delete the line with Putty, at startup, it reappears
Nope, but I just found something; it might be a corrupt textures db? I found these in the log:
NOTICE: LoadJpeg: unable to load
http://image.tmdb.org .... and so on.
I found another thread where people say a restart helps (for a while). I tried a restart and the fanart show up! Now I am not sure what to do, maybe delete the textures.db?
(2015-10-23, 23:39)mikkelnl Wrote: [ -> ]Nope, but I just found something; it might be a corrupt textures db? I found these in the log:
NOTICE: LoadJpeg: unable to load http://image.tmdb.org .... and so on.
I recommend setting up and using the
Texture Cache Maintenance Utility (wiki)
when i play music and the visualisation starts the info/widget only stays on for a few seconds , is there anyway to have it on permanantly ?
I have no line that corresponds to $LOCALIZE[31220] ?
It's not a big deal, I shall wait for a next update.
Do you guys know of a way to create a shortcut for the available Top 250 movies in your library?
(2015-10-24, 19:31)marhutchy Wrote: [ -> ]Do you guys know of a way to create a shortcut for the available Top 250 movies in your library?
Easiest I have found (and use) is creating a video playlist for movies that have the Top250 > 0, sorted by Top250. Then create a shortcut to your playlist
Regards,
Bart
(2015-10-24, 04:20)paulsk231 Wrote: [ -> ]when i play music and the visualisation starts the info/widget only stays on for a few seconds , is there anyway to have it on permanantly ?
This has to be the most repeated question... Added to the FAQ in the 2nd post on the first page of this thread.
(2015-10-24, 11:39)Alyy Wrote: [ -> ]I have no line that corresponds to $LOCALIZE[31220] ?
If the problem is what I think it is then it will never be fixed with an update. Does the lines mentioned previously have any thing after the > and is it in English? If so then there are only a few things you can do, delete guisettings/settings.xml file, modify the file as previously instructed with Kodi not running or add
<onload>Skin.Reset(VideoOSDImages)</onload>
to startup.xml and restart Kodi then delete the line and restart Kodi one more time.
I am pretty sure their is a built in skin playlist you can select: Video Library > Playlist > Top 250
edit: Nope my mistake I added one so long ago I thought it was built in
@MikeSilvo164
Well, vertical menu is available on isengard tree or just pushed in master (Jarvis) ?
(2015-10-24, 19:59)wilmans2m Wrote: [ -> ]@MikeSilvo164
Both master and isengard branches
really ? well so how to activate ? Don't see any option. Do i need to reset all settings ?
thanks
