I dont see enough "thanks"; "thank yous" and "Great Work" on the kodi forums/FB pages,etc.
I just installed your skin for my 1st build.
Thanks, Thank you and it looks great.
(2015-11-02, 14:45)TheBigRoberto Wrote: [ -> ]I think I found a bug, in movie info if I choose scroll from plot to cast, it gets stuck on the cast view and no way to get back to the plot. see picture
I cannot replicate this. Have you modded the info screen in anyway? Try downloading the
DialogVideoInfo.xml from GitHub, replacing it with your current one in the skins 1080i folder, and restart Kodi.
Thanks for the reply. I don't think I have modded the info screen. I tried what you said, but still no luck.
(2015-11-02, 23:50)TheBigRoberto Wrote: [ -> ]Thanks for the reply. I don't think I have modded the info screen. I tried what you said, but still no luck.
I am going to need some more info on your settings and what you are doing to cause the issue. The info screen onload should focus on one of two buttons, either play or cinemavision depending on your enabled settings in skin settings > video info section.
I have added a few screen shots of my setting
here. I tried a few different settings, using the "Replace with extra info" did make it usable but there is about a 3 second delay when I click on a film, and I prefer the way it looks in the screen shot I posted earlier.
After rebooting Kodi what steps did you take to cause the issue, how do I repeat what you did so I can replicate it? What Kodi version are you using? Maybe just post a
debug log (wiki) so I can take a look.
Hi , I use the vertical menu. When i add Trakt Trending Movies widgets i get the CD cover layout on screen , when i choose to have a widget from Add-On/Video Add-On/Extended info script/Upcomming movies (Rotten Tomatoes) i get square boxes on my screen , is it possible to have the CD layout on that to ? .... i hope u understand wat i mean ....
Hi Mike,
The option for choosing my own weatherfanart folder on the side menu is gone and the weather based condition on the homescreen isn't showing the weatherfanarts anymore.
Did something changed in jarvis or your skin?
i have the latest git installed here is a
debug
Once again been searching for an answer but haven't found it.
I would want to use Logo View, but I don't have the logos for my Shows or Music. Does one have to add these manually or is there a plugin that does that?
(2015-11-04, 22:23)Xemaniac Wrote: [ -> ]Once again been searching for an answer but haven't found it.
You have to configure (select) it in the Art work down loader Add-on.
Would you consider making the scroll bars in lists and such a bit wider? It's very hard to keep a mouse lined up on them being so very narrow. I like this skin very much and would use it on all my devices but some are used with a mouse and no keyboard and some are tablets and that narrow little scroll bar is tuff to keep a finger on. Yup, I know I can drag the list but scroll bar is way faster.
Thanks for your hard work on this skin it just keeps getting better!
(2015-11-04, 22:46)LFCFAN Wrote: [ -> ] (2015-11-04, 22:23)Xemaniac Wrote: [ -> ]Once again been searching for an answer but haven't found it.
I've done that already, that's why I'm asking. I just get the generic Skin font as the logo, not for the show.
How do I get it on music then?
